xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: RPM numbers Sat Nov 22, 2008 11:19 pm | |
| ok..i hit a bump last week and if i didnt know better id say im idling a little high in park. some of my numbers were
in park-1000-1100 rpms in neutral around 8-900 in drive with break on - 600
it just feels like sumthing is off...it just got inspected and everything came out clear.....am i just paranoid? | |
| Subject: Re: RPM numbers Sat Nov 22, 2008 11:23 pm | |
| That seems right if the car is still cold. (when you first start it up) The idle in P should fall to about 800rpm when it's fully warmed and something like 650rpm in gear. | |
L67 Aficionado
| Subject: Re: RPM numbers Sun Nov 23, 2008 12:30 am | |
| Yeah i would have to assume its due to these recent frigid winter temps | |
| Subject: Re: RPM numbers Sun Nov 23, 2008 9:01 am | |
| Park and Neutral should be the same. Once the car is warmed up, you should be idling at 850 in Park or Neutral, and 650 or so in gear. If it's staying at 1000+ I'd suspect the Idle Air Control motor is not working right. | |
