 lighting wiring diagram! help
Merit : 135
lighting wiring diagram! help Empty
PostSubject: lighting wiring diagram! help   lighting wiring diagram! help EmptyTue Mar 20, 2007 12:11 am
does anyone have access to a wiring diagram particularly for the instrument illumination paths
i blew a fuse (i think) by accidentally shorting the door handle light and it looks like its on the same circuit as the gauge lights because they both dont work now. I am goin crazy. i've looked through all the fuses in all locations and cant find a bad one.
PostSubject: Re: lighting wiring diagram! help   lighting wiring diagram! help EmptyTue Mar 20, 2007 10:05 am
there has to be a blown fuse. run a ohm meter to every fuse reguarless of what it says on the diagram, sometimes they run more than one thing to the same fuse and they have nothing in common. door panel, 2 under rear seat and one in the engine compartment.
lighting wiring diagram! help Dsc_0110
Merit : 135
PostSubject: Re: lighting wiring diagram! help   lighting wiring diagram! help EmptyTue Mar 20, 2007 11:01 am
i figured the wiring diagram would tell me what other circuits are associated with it
Merit : 135
PostSubject: Re: lighting wiring diagram! help   lighting wiring diagram! help EmptyWed Mar 21, 2007 2:45 pm
i have replaced every mini fuse in the car and still nothing
» 4 pin solenoid wiring diagram?
» wiring diagram/pic
» Briggs Engine Wiring Diagram
» wiring diagram for a 18hp vtwin b&s I/c
» Minelab DD and MONO coil plug pin wiring diagram
