FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info556
Go to page : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Merit: 230
PostSubject: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Tue Mar 20, 2007 8:44 am
Thanks to Jason, nothincame2mind, and Jelorian.
Wheel/Tire Size Comparer:
http://www.wheelsmaster.com/rt_specs.jsp
or:
http://www.rimsntires.com/specs.jsp
Tire Size Calculators:
http://mcgrefer.com/sizeinfo/
http://www.miata.net/garage/tirecalc.html
Wheel Bolt Pattern Cross Reference:
http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp
Lug Bolt Pattern Chart (dead link):
http://www.willysoffroadsupply.com/Wheel_Spacer_Chart.html?sid=f816d06972c62f3471cd1bdd3169e9b0
Other links that could be useful?.. please post 'em.
Merit: 5
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Sun Apr 15, 2007 10:43 pm
3D Wheel Visualizer (Includes Riviera):
http://www.wheelenvizio.com/?wheel=Envizio
okiedrifter
Merit: 2
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Fri May 11, 2007 2:56 am
RIVIERA 86-89 14 X 6 5X115 12mmX1.5 70.3
RIVIERA 93-on 15 X 6 5X115 12mmX1.5 70.3
RIVIERA FWD 79-85 15 X 7 5X120.7 12mmX1.5 70
http://www.myspace.com/okie_drifter
¤DoughBoy¤
Merit: 0
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Tue Jun 26, 2007 11:36 am
This is real helpful.......Thanks!
jrocha
Merit: 0
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Tue Aug 28, 2007 1:20 pm
Thanks to Jason and nothincame2mind.
Tire Size Calculator:
Lug Bolt Pattern Chart:
Do you know what the offset is for the 6.5" wide chrome rims (Riv stock rims)?
Thanks,
http://www.24quilates.net
Merit: 98
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Tue Aug 28, 2007 10:03 pm
dont quote me, but i think it is around +32 offset
Merit: 119
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Wed Oct 17, 2007 6:41 pm
Anyone know the offset for the stock 16x7 wheels?
would a +40 make a huge difference from a +30 for example?
Merit: 98
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Wed Oct 17, 2007 7:31 pm
i think it is like +32 or +35 depending on wheel.
texasfan010
Merit: 1
PostSubject: dimensions   Sun Apr 06, 2008 10:37 pm
what are the dimensions to the 1996 stock wheels. what by what
Merit: 16
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Sun Apr 06, 2008 10:40 pm
16x7 i believe.
Merit: 98
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Sun Apr 06, 2008 11:33 pm
the 8 spokes are 16x6.5 and the 12 spokes are 16x7
all run 225/60/16 tires and have +32 offset i believe
to me the 12 spokes are "stock" since they are the rims specifically for the riv, while the 8 spoke design was offered on other buicks as well. the base wheels are ugly mono wheels with lots of little spokes around the edge, but those were only put on 95/96's with no s/c or other options.
jrocha
Merit: 0
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Thu Apr 17, 2008 6:56 pm
The one that says 93-on, is that correct?
Aren't our rims 16 x 6.5 or 16 x 7.0?
Merit: 98
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Thu Apr 17, 2008 7:42 pm
i dont know why it says 93-on for that size b/c ours (95-99) are 16X6.5 for 8 spoke design, or 16X7 for 12 spoke design still 5x115 bolt pattern.
Merit: 8
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Sat Jun 28, 2008 8:14 pm
..I'm pretty sure our bolt pattern is 5x115
Merit: 81
PostSubject: Re: FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info   Sat Jun 28, 2008 8:16 pm
With an adaptor, but not with the stock bolt pattern:
Link
Page 1 of 10Go to page : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
» FAQ: Wheel & Tire, Lug, Bolt Pattern, Center Bore Info
» ? wheel bolt pattern
» Bolt pattern on a '94 Caprice w/4.3L V8
» Bell housings bolt pattern
» Head Bolt Pattern Measurements & Clutch Plate Thickness
Riviera Performance ::  :: -
