| Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security | |
+74llamalor2112 ZEP Setton chitown_riv98 matt270avian gunmetalRED Lenrapkins sniperdude GreenJeanS mkarr rivieray c0reyl nvsteve dpmeeks SuperRivL67 DEMonte1997 riviera90 dtrumbo denim BatMobile 97 park ave 98riv Mikel bigdave canada Karma BlownRiv Derek BMD jonly lamluca flyineagle96 slacker2620 black shadow Jack the R Abaddon AA LARRY70GS billythekid7 moldymac rivren Eldo robotennis61 Jason jp8240 pearlwhite91 Ash Roberta Mr.Riviera rivparadise tomc dscott2000 1995 Riv 98RiviSC Rickw jenkkijussi KillaKeninaRiv SToP Ryan from Ohio 96RIVMANN albertj Fuzzy '96reese lionfish Chicken deekster_caddy ibmoses BillBoost37 TType_Riviera heyzelchi jhodges mcgusto82 SpaceBar RIVIGIRL1 78 posters |
96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
| Subject: Security light flashing? Fri Aug 08, 2008 7:21 pm | |
| The security light on my '96 starts to flash rapidly after I shut the car off and open the door. The DAB ACSRY relay under the back seat is clicking like crazy. I had the battery diconnected last night and I just pulled the pcm fuse but no luck. Also, I unplugged/plugged the module in the trunk up by the rear speaker. I checked the wiring going into the doors and I don't see any bare wires either .Anyone ever have this problem arise?
Thanks | |
96RIVMANN Fanatic
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Fri Aug 08, 2008 9:31 pm | |
| Does anybody know where the pass key II module is located? What is the black box under the driver seat? It chirps when you lock/unlock the doors with the key fob? | |
'96reese Fanatic
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Sat Aug 09, 2008 2:12 am | |
| the pass key decoder module is located behind the top right side of the dash..... look at your key and check out the double sided resistor chip. it will have a small silver strip that is the length of the black chip. look at that piece if it's worn down to the point where it almost blends in with the black, you might wanna replace that. cost like $40 per key. or you might have have to replace the igntion lock and both keys. there are 2 wires that run down from the cyclinder to 48 pin connector. it's best to have it taken to a dealer to have it checked out any gm dealer should have the equipment, but buick definitely does, because they are the only ones that use the double sided resistor chip. good luck | |
Ryan from Ohio Fanatic
Name : Ryan Location : Toledo, Ohio Joined : 2008-11-16 Post Count : 307 Merit : 7
| Subject: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 8:20 am | |
SToP Enthusiast
Name : Rob Location : SK, Canada Joined : 2008-10-27 Post Count : 100 Merit : 2
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 10:42 am | |
| Have a look here: http://www.the12volt.com/installbay/alarmdetail/373.html
It says: Factory Disarm Light Green (-) Driver's Kick Panel in Door Boot
I would assume you send a pulse to it from your aftermarket system when the doors are being unlocked? | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 11:07 am | |
| I didnt install the car starter and Im not sure how its is installed currently.
I looked at the 95-97 version and printed them off. didnt even think to look into how it was installed. i was moreso looking for a way to disable the factory security system.
I will have to see if i have the users manual for the car... Not sure if I do. | |
SToP Enthusiast
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 11:10 am | |
| Owner's manual is online, I'll find you a link. What year is your car? | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 11:25 am | |
SToP Enthusiast
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 12:10 pm | |
| I *think* this is the link. It's down right now though. Try it later on.
https://www.mygmlink.com/pdf/go2content/manual/US/en/buick/1995riviera.pdf | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 2:02 pm | |
| If you decide to disconnect the aftermarket system, as long as your BCM is in place (it is a box under the rear deck) and working you should be able to wire it backup, and get a remote (off Ebay) to program for the car. There are instructions in the FSM for that programming, don't need a Tech II (although it helps!)
SToP Enthusiast
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 7:07 pm | |
| I lied. The manuals are available here:
http://gmprotectionplanwarranty.com/owners-manual/buick/
I didn't see anything in the '97 manual about an option to permanently disable the factory alarm.
What model alarm do you have? Might be as simple as finding the control box and running one wire. | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 8:09 pm | |
| Thanks for the link i will review the manual as soon as I can. Outside that if anyone knows a way to disable it please tell. | |
SToP Enthusiast
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 03, 2008 8:55 pm | |
| It doesn't appear to be a programmable feature (at least in my '97). Looks like it's all run by the Remote Accessory Control (RAC) module in the '95.
There's a chance you could de-pin white A and lt. blue E from C2 at the RAC, then it wouldn't know when the door is locked and then it wouldn't arm.
The procedure to arm the system (in y '97 manual) is:
1. Open the door. 2. Lock the door with the power door lock switch or Remote Keyless Entry System. The SECURITY light should come on and stay on. 3. Close all doors. The SECURITY light should gooff after about 30 seconds. The security system is not armed until the SECURITY light is off. If the SECURITY light stays on or flashes when the ignition is turned on, there is a problem with the system and the vehicle should be serviced
I still think it would be easier and better to just run a wire to the kick panel from the aftermarket controller. Most controllers have wiring diagrams online, we could help you figure out where to run the wire from. | |
KillaKeninaRiv Addict
Name : Kenneth Age : 41 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
| Subject: Wiring Harness Issues - Imitates Security Passkey VATS Wed Dec 17, 2008 10:50 pm | |
| hey does anyone else have any personal experience in getting the security feature in the keys bypassed? this guy just told me the reason why my car started 3 times and immediately cut off right after was because the short in my ICM wire caused the computer to read that the car was being tampered with or something and sent it into security mode which disables the motor after three tries. so he said i should put the key in the ignition and wait 15 minutes. there should be the SECURITY light flashing 4 times, then pausing, and three more times as a fail code. Then he said to start the car becuase by waiting it would reset the code and allow it to start. If that didnt work he said it would be from the surge going into the ECM and frying it, meaning I would have to buy one from the junkyard from another 3800 and have it programmed at the dealer for $95 or so. Any truth to this? | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Wed Dec 17, 2008 11:33 pm | |
| Semi-true. Different years PASSKey systems work a little differently.
What is the ICM wire, and if it really exists how do you know it is shorted? Aftermarket alarm? Maybe the chip on your key is just dirty. It is only a resistor, actually. Maybe the contacts in your ignition switch are dirty. That's more common than you might think. If you search this editboard you will find I think an article on bypassing the PASSKey.
Please tell us more.
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Thu Dec 18, 2008 11:25 am | |
| the ignition wires that lead to the module underneath the coil packs. its the long flat metallic plate they sit on. theres a long wire harness that has a 7mm bolt through it holding it down. it MAY be a 7mm IIRC. but theres a long clip going into it at the bottom of the coil packs and a ground wire to ground it that goes into something underneath it and the ground is not there. im about to head over there and try to un-fuck the situation and go by the GM dealership and get there opinions too | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Thu Dec 18, 2008 11:52 am | |
| Sounds like what you might really need is a factory service manual, a warm garage and an entire Saturday.
I don't have the experience to understand what you're talking about here, so I have to pass on this one, sorry. Maybe someone else has dealt with this before and can help you better.
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Thu Dec 18, 2008 1:10 pm | |
| The securit feature inside the keys is a simple resistor.
Take a digital multimeter set to Ohm and measure the Ohms on the metal tabs on the key.
Goto Radio Shack and get the needed resistors to total measured amount. Install on lock cylinder there should be two wires running off it. | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Thu Dec 18, 2008 4:08 pm | |
| alright everybody i just had a mechanic come and take a look at it. it wasnt locked out after all. wire harness problems | |
jenkkijussi Amateur
Name : Johannes Location : Finland Joined : 2008-10-19 Post Count : 28 Merit : 0
| Subject: Security light stays on. Fri Jan 02, 2009 2:06 pm | |
| Riv-95. Does anyone know why "SECURITY LIGHT" stays on after starting the car? The light stays on sometimes for 30 seconds, sometimes it stays on for 30 minutes. It allways goes off eventually. No other problems found. | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Fri Jan 02, 2009 2:10 pm | |
| Security system malfunction. Don't know more than that on the 95's, I just know in my owners manual it says that the light staying ON indicates the system is not working. Further troubleshooting required. Maybe someone with the 95 Service Manual can help. | |
98RiviSC Member
Name : Ryan Age : 37 Location : New Lebanon, Ohio Joined : 2008-12-07 Post Count : 55 Merit : 0
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Fri Jan 02, 2009 10:21 pm | |
| I heard if your key has any moisture on it it will set it off. Mine does the same thing, i dont know why though. | |
1995 Riv Enthusiast
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Fri Jan 02, 2009 11:14 pm | |
| Johannes Does it stay on after you shut the car off? If so for how long? How many miles on your car and when did it start doing it? The light will light if the PASS-key II module has detected an open or short or incorrect resistance for 60 consecutive seconds while the vehicle is running. Does it do it when raining or melting snow? Is it more likely to do it when cold or hot? Don | |
dscott2000 Enthusiast
Name : Scott Age : 42 Location : Kansas City, MO Joined : 2008-07-27 Post Count : 160 Merit : 0
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Sat Jan 03, 2009 3:59 am | |
| My Bonneville security light stays on constantly. Except when the key is off. It has been like that since about 2-3 days after I bought it 3 years ago. I just put a dash plaque over it and it hasnt failed me yet! | |
jenkkijussi Amateur
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security Sun Jan 04, 2009 8:03 am | |
| To 1995 Riv. When I shut the car off the light goes off. The car has 140 000 miles and the problem has been there since I bought the car couple of months ago. It happens always, regardless of weather. Alarm system is checked and it works o.k. | |
| Subject: Re: Write-Up: No Start + 3 min delay / Disabling PASS-Key II Security | |
