rabbit808 Special
| Subject: What hose is this?? Thu Dec 04, 2008 8:34 pm | |
| There is a hose under the supercharger pulley that i have coolant constantly leaking from. What is the name of this hose please? | |
rabbit808 Special
| Subject: Re: What hose is this?? Thu Dec 04, 2008 9:54 pm | |
ewolfe0050 Aficionado
| Subject: Re: What hose is this?? Thu Dec 04, 2008 10:02 pm | |
| Is it the one that goes back to the heater core? | |
| Subject: Re: What hose is this?? Thu Dec 04, 2008 10:10 pm | |
| what year is your car. it makes a difference. | |
| Subject: Re: What hose is this?? Thu Dec 04, 2008 10:19 pm | |
| Maybe a picture would help? Otherwise I guess it's a heater hose. | |
Karma Aficionado
| Subject: Re: What hose is this?? Fri Dec 05, 2008 1:14 am | |
| _________________ | |
rabbit808 Special
| Subject: Re: What hose is this?? Fri Dec 05, 2008 2:19 am | |
| ill see if i can get a picture but its a kinda S - shaped black plastic hose right below the SC pulley and leaks coolant. 1995 Riv series 1 | |
| Subject: Re: What hose is this?? Fri Dec 05, 2008 2:32 am | |
| Is this it? I do not know what it is called but any parts store should be able to look it up for you. Worst cast the nipple from the LIM to the hose has a crack and you might have to replace the LIM. I've seen some other posts here with that issue... | |
| Subject: Re: What hose is this?? | |
