98RiviSC Member
Name : Ryan Age : 37 Location : New Lebanon, Ohio Joined : 2008-12-07 Post Count : 55 Merit : 0
| Subject: Transmission problem ! Sun Dec 07, 2008 8:09 pm | |
| I have a 98 riv and the transmission has been acting weird lately. It is hard to get out of park when i first start it up, and after i have been driving it for a while it is hard to get into park. I didnt know if this was a minor thing ? I have owned the car 4 years and it just started. It shifts fine while in gear. Thanks ! | |
Ash Enthusiast
Name : Marty Age : 46 Location : S. Central Indiana Joined : 2008-05-21 Post Count : 115 Merit : 4
| Subject: Re: Transmission problem ! Mon Dec 08, 2008 11:37 am | |
| Does it feel as if it maybe the shifter itself causing the hard movements? Are you pushing the brake pedal enough to allow easy movement of the shifter to or from Park? (maybe try pushing it harder and see if it changed the resistance.) Just some things to try to eliminate before heading to the transmission itself.
Best of luck. | |
98RiviSC Member
| Subject: Re: Transmission problem ! Mon Dec 08, 2008 1:03 pm | |
| I dunno, i push the brake in and push down on the button on shifter and it gets stuck in park, and going out of park. | |
| Subject: Re: Transmission problem ! Wed Dec 10, 2008 8:40 pm | |
| Hopefully it's just a cable. | |
| Subject: Re: Transmission problem ! | |
