 FAQ: Series I Performance Mods?
Go to page : 1, 2, 3, 4, 5  Next
TypetoHarry
FAQ: Series I Performance Mods? Empty
PostSubject: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyMon Dec 17, 2007 6:01 pm
I have a series I Riviera with a CAI and 95,000 miles. I'd like to mod it some more and was hoping to get some help with what to do to it. A series II swap is out of the question. I have $500 to put into it. Any help is appreciated!
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyMon Dec 17, 2007 6:13 pm
a FWI a 2.6 pulley auto light 104s and a custom cat back
TypetoHarry
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyMon Dec 17, 2007 6:21 pm
Can't do a FWI, I'm not cutting the car to make it fit.
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyMon Dec 17, 2007 6:53 pm
then just do a regular short ram intake
etosino2009
etosino2009
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyMon Dec 17, 2007 6:54 pm
everything corey said plus a 180 thermostat from intense
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 18, 2007 7:17 pm
I think most of the guys didn't have to do any cutting. I did on mine because I didn't want to have to go through the fender well everytime I needed to clean the filter. But even though I cut mine, the factory box will cover any enlargment to the opening I made if i decide to put it back stock.
TypetoHarry
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 18, 2007 9:17 pm
I have a CAI as it is. Could you explain a custom cat back? Also what about a KR scanner, do they have PCMs? thanks.
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 18, 2007 11:30 pm
If I had only $500 to spend on a series I, I'd do a CAI/FWI, scanner, mini AFC, AL104s, 180 t-stat, & 2.6" SC pulley... Make 15-20 HP and call it a day!
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 18, 2007 11:34 pm
custom catback would probably be eliminating the resonator put in a 3" pipe into a Y pipe with 2.5" exits to two hi flo mufflers... just an exhuast system...my guess is it would cost about 250 at most muffler shops.
TypetoHarry
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptySat Dec 22, 2007 12:00 am
Any sites to suggest ordering from?
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptySat Dec 22, 2007 12:19 am
what part are you looking to order
for the pulley
http://www.pulleyboys.com/gms1p.html
scanner
http://www.seriesoneperformance.com/pcm.html
FWI
http://www.bonneville.fearthepearl.com/index.php?page=mods
exhaust is up to you, go to you local auto parts store get autolight 104 IN COPPER shouldnt cost you more the 7 bucks for the plugs
EDIT, get a 180 t stat from your local store i got mine at advanced auto parts for 10.95 its a stant 180 thermostat
maggot
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 25, 2007 8:18 pm
you could go find a CAI that fits on another car but has the same bends that you would need. i think mine fits a acura or honda, cant really remember, bought it new and cheap off ebay.
BKRIV
BKRIV
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyWed Dec 26, 2007 11:55 pm
what is FWI?
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyThu Dec 27, 2007 12:00 am
FWI = fender well intake... the pipe routes into a conical filter in the fender well.... theres a bulletin with all the abbreviations somewhere... mps is modular pulley systed , dp is downpipe , pcm is powertrain control module.... those are some of the common ones.
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyThu Dec 27, 2007 11:00 am
superchargedmoney
PostSubject: Series I Mods   FAQ: Series I Performance Mods? EmptyWed Mar 05, 2008 11:05 pm
Does anybody make headers for the series I?
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyWed Mar 05, 2008 11:08 pm
Don't know, but this place may: www.seriesoneperformance.com
superchargedmoney
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyWed Mar 05, 2008 11:10 pm
Also I need some ideas for what to do with my series I. I don't realy want to swap it for a series II. I never had a blown engine before. Is it safe to run it on nitrous? If so how big of a shot is too big for these 6 cyl.?
superchargedmoney
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyWed Mar 05, 2008 11:11 pm
naw they don't even have an exhaust dept.
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyThu Mar 06, 2008 4:04 am
I have heard a guy run a 100 wet shot. I would make sure your fuel system is up to spec first.
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Mar 18, 2008 8:22 pm
call me crazy but the GN headers look the same. i know the GN is RWD. but im sure an exhaust shop could make it work
justins95riviera
PostSubject: performance mods   FAQ: Series I Performance Mods? EmptyThu Jul 31, 2008 8:46 pm
hey everyone, my name is justin and i own a '95 riv. i wanted to put a smaller SC pulley and a cold air intake on it. Any suggestions on what size and make? i want to go as small as i can without having to do a lot of other mods
jboer95RIV
PostSubject: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 09, 2008 7:24 pm
Can you put headers from a series ii on a series i and what other go fast bolt ons can you put on a 95 riv that will helpall i have is a CAI and straight pipes
Merit : 122
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 09, 2008 7:51 pm
fraid the series one is a bit scarce in the mod dept. Headers won't work from a series 2, because on the series 2 the exaust ports are evenly spaced. The series one has un-evenly spaced ports, so if you wanted headers on the series one, you really would have to get them custom done. For mods, start with the basics(tune-up etc), then move to cooler Tstat, and scan for engine knock. If you are knock free you can drop a pulley size. also you can consiter doing a port and polish on your lower intake manifold.
http://www.pontiacbonnevilleclub.com/forum/ has a bunch of good info on series 1 modding
jboer95RIV
PostSubject: Re: FAQ: Series I Performance Mods?   FAQ: Series I Performance Mods? EmptyTue Dec 09, 2008 8:11 pm
mmk then well i just had the whole motor redun jet washed with new rings and pistons and the crank was balanced so the motor has no knocks also what are some good handaling mods that can be done to a riv to reduce body roll and stuff like that
Page 1 of 5Go to page : 1, 2, 3, 4, 5  Next
» Reverse Mod For arctic cat manual shifts
» Mods to do to 450 2008 King Quad Suz,
» Power Mods ????
