| | Do you need to rewire for a stereo and speaker install? | |
| Author | Message |
EASHER Apprentice
Name: ERIK M. ASHER Age: 43 Location: BLOUNTSTOWN, FL Joined: 2008-10-24 Post Count: 85 Merit: 0
 | Subject: Do you need to rewire for a stereo and speaker install? Wed Dec 10, 2008 7:06 am | |
| I went to Best Buy to check on the cost of replacing my stereo.
The tech in the install area said that the system install would require a complete rewire because the stock system used proprietary wiring and speakers.
I was also told that I would have to have a 4ch amp installed since my speakers are 2ohm and it would fry my stock head unit.
Are they just trying to rip me off?
has anyone had to completely rewire their system for installing new speakers? |
Ryan from Ohio Member
Name: Ryan Location: Toledo, Ohio Joined: 2008-11-16 Post Count: 310 Merit: 7
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Wed Dec 10, 2008 8:33 am | |
| if your system is Bose or anything upgraded over the Concert Sound 2 then they are probably right.
If you have CS2 then you just need a wiring harness. I know theres two speakers in the front doors. if they are both 2 ohm and wired in series which Im about 99% positive they are, you will be fine.
If you have something greater than cs2 then you probably will need a rewire in terms of running new speaker wire from either a new deck or by adding an amp. |
envus87 Trainee
Name: Nick Age: 29 Location: STL Joined: 2007-11-01 Post Count: 40 Merit: 0
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Wed Dec 10, 2008 8:58 am | |
| had to run new wires to the rear speakers on my friends riviera, harness wouldnt match up. He had cs2, but was also a 1995.
post is here somewhere |
deekster_caddy Guru
Name: Derek Age: 40 Location: Reading, MA Joined: 2007-01-31 Post Count: 6091 Merit: 83
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Wed Dec 10, 2008 8:20 pm | |
| Didn't need to touch the speaker wiring in my '98 with CS2. It works great. |
Mr.Riviera Aficionado
Name: Matthew Age: 25 Location: Florida Joined: 2007-01-17 Post Count: 4008 Merit: 82
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Wed Dec 10, 2008 9:14 pm | |
| both front and rear wires worked fine for aftermarket speakers and head unit. btw, i think you can get 2ohm aftermarket speakers but i dont believe there is a need to. _________________  |
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Thu Dec 11, 2008 7:32 pm | |
| I have a 95 and the wiring harness worked perfect. American international brand.
You dont want 2 Ohm speakers...
Just buy the fit kit and take your time. Its not a fun one, thats for sure...
I got an American international fit kit also. Its better than the others they have and has a nice EXTENDED mounting plate.
Get the GM-K434 and you can use the extended mount. Then use the factory "cradle" and use the back screw that came with your radio. makes for a SOLID mount! |
EASHER Apprentice
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Thu Dec 11, 2008 7:47 pm | |
| I have the speakers already. Infinity kappa series speakers and they are 2ohm speakers.
Can I just splice in a 4ohm resister to each speaker to not have a problem with my stock CSII? |
deekster_caddy Guru
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Thu Dec 11, 2008 10:03 pm | |
| No resistor needed for the kappas. Do your homework. It's discussed on the infinity website. |
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Sat Dec 13, 2008 6:14 pm | |
| Thats a pile of bull shit if Ive ever read any.
Theres no damned way in hell that 10' or less of factory wiring is going to equate to 2 Ohms.
Furthermore even if it did add resistance its DC resistance, not AC Impedance.
I would use these with extreme caution or return them.
Check the calculator... 20 Ga wiring, 10 feet = .1 Ohms.
BS |
deekster_caddy Guru
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Sun Dec 14, 2008 7:29 pm | |
| What is BS?
They sound great to me anyway, and that's all that really matters. A lot better sounding than the factory speakers that's for sure. |
Rickw Expert
Name: Rick Age: 53 Location: Lancaster, MA Joined: 2008-09-13 Post Count: 5957 Merit: 96
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Sun Dec 14, 2008 7:47 pm | |
| Ryan, What is the formula for figuring out resistance based on AWG and length of wire ? It seems I have forgotten the basics. |
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Sun Dec 14, 2008 9:46 pm | |
| http://www.stealth316.com/2-wire-resistance.htm
All that is, is some strange/stupid marketing gimmick. AC Impedance (what a speaker is) is different than DC Resistance (How you measure the wire). Theres no way in this green earth that theres 2 Ohms resistance in that wire...
Thats what Im calling BS on.
I wonder what the DC Resistance is on those speakers...? |
Rickw Expert
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Mon Dec 15, 2008 5:20 am | |
| Ryan, Thanks for the link. That's just what I've been looking for. |
EASHER Apprentice
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Mon Dec 15, 2008 6:42 am | |
| So to be clear. Can I use my 2ohm Kappa speakers with my stock CSII HU or do I have to wait until my new HU is installed? |
deekster_caddy Guru
 | Subject: Re: Do you need to rewire for a stereo and speaker install? Mon Dec 15, 2008 9:56 pm | |
| | EASHER wrote: | | So to be clear. Can I use my 2ohm Kappa speakers with my stock CSII HU or do I have to wait until my new HU is installed? |
You shouldn't have a problem. |
