| 6 disc changer install | |
Ironclad-454 Enthusiast
Name : Nate Age : 40 Location : Oklahoma Joined : 2008-11-22 Post Count : 162 Merit : 9
| Subject: 6 disc changer install Wed Dec 17, 2008 7:52 pm | |
| I know its kind of retro, but the CD player on the HU doesn't work and I have a 6 disc changer that I could install. I know that a remote CD changer was an option on these cars and am wondering how hard it would be to install this in the riv. I'm kinda on a fixed budget so I want to use this in loo of a new head unit since I already own it. Opinions and suggestions welcome. | |
mdhall1 Member
Name : Matt Age : 45 Location : New Braunfels, Texas Joined : 2008-06-15 Post Count : 58 Merit : 1
| Subject: Re: 6 disc changer install Wed Dec 17, 2008 11:57 pm | |
| My 95 doesn't have cd changer controls on the head unit. I'm guessing your doesn't either. You would have to connect through a FM modulator. This basically turns your cd sound into a FM signal and you tune your stereo to that signal. I put one in my Jeep and used 87.1 FM. As far as a mounting location under the passenger seat is where i have mine fits great and is pretty convienient. It's a six disc but I put in a Alpine stereo that has Changer controls. If you want specific install sugestions let me know what changer you have and what modulator you are planning to use. I've done alot of installs and may be able to help. | |
| Subject: Re: 6 disc changer install Thu Dec 18, 2008 12:22 am | |
| Its just a cheap Koss KCD-003A. Its kind of old I bought it years ago to put in another car but never did. It came with an FM modulator, controller, and mounting brackets. It has 2 frequencies 89.1 and 88.7mhz. I know very little about audio equipment, this is just until I can afford something better. Any help would be greatly appreciated.
Last edited by Ironclad-454 on Thu Dec 18, 2008 12:24 am; edited 1 time in total (Reason for editing : misspelling) | |
| Subject: Re: 6 disc changer install Thu Dec 18, 2008 11:47 am | |
| That makes it clearer.
You have to install the Koss CD unit, the controller and then tune your FM radio to the freq. you will use (most likely 88.7).
The OEM head unit will control a GM changer if you get the cable to run it.
If you do not have the instructions for the unit (I am guessing you don't else why would you post this) you are probably hosed. If you do you are probably in good shape, there should not be any surprises.
| Subject: Re: 6 disc changer install Thu Dec 18, 2008 12:21 pm | |
| I didn't have the instructions when I first posted, but I was able to find them in the closet this morning, so its off to to see if I can install it. Thanks albertj and mdhall1. -Edit- To damned cold went out and the thermometer reads 19 degrees before the windchill | |
dscott2000 Enthusiast
Name : Scott Age : 42 Location : Kansas City, MO Joined : 2008-07-27 Post Count : 160 Merit : 0
| Subject: Re: 6 disc changer install Thu Dec 18, 2008 4:05 pm | |
| - mdhall1 wrote:
- My 95 doesn't have cd changer controls on the head unit. I'm guessing your doesn't either. You would have to connect through a FM modulator. This basically turns your cd sound into a FM signal and you tune your stereo to that signal. I put one in my Jeep and used 87.1 FM.
As far as a mounting location under the passenger seat is where i have mine fits great and is pretty convienient. It's a six disc but I put in a Alpine stereo that has Changer controls. If you want specific install sugestions let me know what changer you have and what modulator you are planning to use. I've done alot of installs and may be able to help. This will work! All you have to do is get a FM modulator for the CD changer itself. And then it should work out just fine. | |
sqrivi Fanatic
Name : scott Location : madison, al Joined : 2008-03-15 Post Count : 375 Merit : 52
| Subject: Re: 6 disc changer install Fri Dec 19, 2008 12:06 am | |
| You will need antenna adapters as well. | |
| Subject: Re: 6 disc changer install Fri Dec 19, 2008 12:25 am | |
| I have the FM modulator for the disc changer. I was able to borrow my dad's garage and stay out of the weather a little more, still a cold install. It works great, I just need to re-route some wires so the HU will fit back in its slot (its about an 1/8th inch to far out) I may just do away with the plastic behind it since I already had to cut a hole behind the HVAC controls to stash the Modulator. I'll try re-routing the wiring first and go from there. This isn't as involved as I first thought, I'm going to have to mount the changer in the trunk because of the electric seats there wasn't enough room to mount in the cabin itself, kind of a PITA but at least I have a CD player now. | |
| Subject: Re: 6 disc changer install Sat Dec 20, 2008 5:23 pm | |
| Okay, I ran into a little snafu when I went to put everything back together, the controller came unplugged so I had to remove the modulator. I found a new head unit in RC yesterday when I went shopping so I just bit the bullet and bought it ($75plus tax) I pulled the 6-disc changer and installed it. I also cut the plastic behind it and cured the wire fitment issues for good. Thanks everyone for your help. I greatly appreciate it. | |
| Subject: Re: 6 disc changer install | |
