 Battery Light
Go to page : Previous  1, 2
1995 Riv
Battery Light - Page 2 Empty
PostSubject: Re: Battery Light   Battery Light - Page 2 EmptyMon Dec 22, 2008 12:18 am
Mine did that took to Dealer they told me it was the 800. 00 part on the divers frame rail and to not have it fixed because of the cost. 95 had a problem with them. I believe there was a service bulletin on it can't remember off hand. Hope yours is something small.
Bushytea
PostSubject: Re: Battery Light   Battery Light - Page 2 EmptyMon Dec 22, 2008 12:24 am
Wow, I hope it isn't that but worse case it just stays that way.
I plan to check the simple things like the connectors and wires suggested by albertj but I would probably have to go with Rick and say since it happens everytime around the same time it's probably a malfunctioning part somewhere.
Ill know more once it warms up some and I can go through each connector wheel by wheel. Also need to change the spark plugs on it once it warms up as well.
Thanks guy!
Mike
Battery Light
» Compass not happy
» GP 3000 with Light weight Lithium Battery system
» New Minelab GPX Lightweight Battery
» battery failures
» GP3000 - info on Lucky Lark Battery and Coil
