| FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) | |
+39brettfavreisamonster jayeli farmboy92 gmann3001 robotennis61 BMD knuckled1 Bowersk LARRY70GS greg_anderson_78 Eldo ZEP 95RiviSC ibmoses GMfan1111 albertj Rickw L67 xxsupergman25xx tech408 curious riv BKRIV TonySmooth89 mrod7510 '96reese Joey98riv BillBoost37 deekster_caddy Jack the R SpaceBar 1998 Riv 1998rivman Jason urbsnspices 97rivman AA T Riley Mr.Riviera turtleman 43 posters |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2177 Merit : 149
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Jun 25, 2012 10:15 am | |
| - gmann3001 wrote:
- WOW I feel like a jack ass. my SES light has been on and off for the past year.
I bought the kit online for using my lap top to read the codes... long story short it didn't work. so after several attempts on ebay I finally landed an Actron CP9185 auto scanner. and after doing the coolant drain, flush, water pump and thermostat then refill. I got to read the Manuel then tried it out... Now I read the posts about doing the water pump and while its all apart go ahead and change the camshaft position sensor. but I figured hell if it aint broke don't fix it right.... well here it comes! are you ready? The scanner said code p0341 the camshaft position sensor fault. Damn am I a Jack Ass! I should have just changed it when it was all apart! but no! I had to learn the hard way...
Well, before you beat yourself up too much, have a look at this thread. https://rivperformance.editboard.com/t4703p180-p0341-camshaft-position-sensor-cam-sensor-timing-chain?highlight=camshaft+position+sensorThere have been several of us who have had the same wire at the firewall connector break, and that is all it is. It is most likely not the sensor itself. I had that same code on and off for about a month. Finally found the wire broken internally right where it is pictured in that thread. Good luck. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: temp Mon Jun 25, 2012 10:44 am | |
| Recently had my engine rebuilt, decided to keep the original cam and crankshaft position sensors. They seem to be doing their jobs just fine so far. Ain't broke, don't fix it. But since you have the code, definately something's up. Check the wiring as Larry said, maybe that's all it is. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
gmann3001 Fanatic
Name : Glenn W. Peck Age : 50 Location : Orland Park, IL. Joined : 2011-11-16 Post Count : 389 Merit : 9
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Jun 25, 2012 7:08 pm | |
There have been several of us who have had the same wire at the firewall connector break, and that is all it is. It is most likely not the sensor itself. I had that same code on and off for about a month. Finally found the wire broken internally right where it is pictured in that thread. Good luck. Changed the sensor yesterday, cleared the codes. all checked out fine. now today the SES is on again... I guess Ill check that wiring harness now... where do i get my hands on that clip with the rubber gasket? if needed | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Jun 25, 2012 8:52 pm | |
Changed the sensor yesterday, cleared the codes. all checked out fine. now today the SES is on again... I guess Ill check that wiring harness now... where do i get my hands on that clip with the rubber gasket? if needed Not sure. My friend had a whole box of them, and a tool to back it out of the firewall connector. I think you will be able to reuse the one you have, including the rubber seal. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
gmann3001 Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Jun 26, 2012 8:22 pm | |
| I hope so... with all the broken wires in the door I can only guess that damn wire is broken | |
gmann3001 Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Jun 26, 2012 8:28 pm | |
| By the way, how do I disconnect that wiring harness? cant see to well in there... is there an nut or bolt... or is it just clipped on? | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Jun 27, 2012 8:47 am | |
| There is a front plastic cover that simply clips on. Then dead center is a small bolt (counter sunk in the hole) It's small, 10mm or smaller, I forget. Then the front half comes apart from the rear. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
gmann3001 Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Jun 27, 2012 3:34 pm | |
| Well I got that apart... but cant find any broken wires??? Has any one had a problem with that sensor... at the sensor end connector? | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Jun 27, 2012 3:48 pm | |
| - gmann3001 wrote:
- Well I got that apart... but cant find any broken wires???
Has any one had a problem with that sensor... at the sensor end connector? Mine didn't look broken either, but I could watch the cam sensor signal go in and out (on the Genesis Tech2 scan tool) as I wiggled that black wire. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
gmann3001 Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Jun 27, 2012 8:17 pm | |
| I Guess Ill try that tomorrow... Every thing looks nice and secure? although when I got it all back together the light was off again... | |
farmboy92 Special
Name : Aubrey young Joined : 2013-02-10 Post Count : 1 Merit : 0
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Feb 13, 2013 7:23 am | |
| Like to give a big thanks to you guys. Was looking to buy a 98 with a cam sensor code. Bought it and took a couple minutes when we got home and found the broken wire. I was able to get the stuff from work and fixed it for free. Now the wife has a car i trust. | |
jayeli Amateur
Name : Clint Age : 50 Location : casper, wyoming Joined : 2011-02-11 Post Count : 40 Merit : 1
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Jun 28, 2013 9:52 pm | |
| would this wiring issue apply to the 1990 as well? i have the service engine soon light on with 53k and the scan showed this to be the issue-just wanted to be sure this wiring issue isn't the problem before replacing the sensor. thanks. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sun Jun 30, 2013 9:38 pm | |
| - jayeli wrote:
- would this wiring issue apply to the 1990 as well? i have the service engine soon light on with 53k and the scan showed this to be the issue-just wanted to be sure this wiring issue isn't the problem before replacing the sensor. thanks.
It might. It's worth looking at the wiring before you replace the sensor, just to be sure. Remember that your wire harness is 23 years old now... | |
jayeli Amateur
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sun Jun 30, 2013 10:33 pm | |
| well i replaced the sensor and the light is still on. but the pics in this topic look different on my 90 3800...i guess i'll read through it again and see if i can figure anything out-thanks. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Jul 01, 2013 12:53 am | |
| - jayeli wrote:
- well i replaced the sensor and the light is still on. but the pics in this topic look different on my 90 3800...i guess i'll read through it again and see if i can figure anything out-thanks.
were you told to check the wiring before replacing the sensor... ? | |
jayeli Amateur
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Jul 01, 2013 4:22 pm | |
| no i replaced the sensor first-i'm checking the wires tomorrow. if i find a bad wire, i'll just put the old sensor back on then return the new one. but i wasn't sure the wire problem applies to the previous generation 3800 that i have-1990-everyone on this topic seemed to only talk about the last generation with the 3800 series 2. | |
brettfavreisamonster Amateur
Name : Huynh Location : LB, CA Joined : 2014-01-17 Post Count : 25 Merit : 0
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Nov 03, 2015 6:54 pm | |
| I have had the P0341 for 6 months now. I got it maybe a month after doing the water pump. This is what i have done so far. Tried two different cam sensor and different ignition coils from the junk yard. Changed all new spark plugs. Check spark plug wires. Check the wiring at the firewall for any broken wires. Rotated the fly wheel to see if the magnet is still there and it is. I have to smog check in 3 weeks. What else can i do? | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Nov 04, 2015 8:43 am | |
| - brettfavreisamonster wrote:
- I have had the P0341 for 6 months now. I got it maybe a month after doing the water pump. This is what i have done so far. Tried two different cam sensor and different ignition coils from the junk yard. Changed all new spark plugs. Check spark plug wires. Check the wiring at the firewall for any broken wires. Rotated the fly wheel to see if the magnet is still there and it is. I have to smog check in 3 weeks. What else can i do?
I bet that wire at the firewall is your problem. It can look OK from the outside, but inside, it's bad. Find some one with a Tech2 type scan tool. You can monitor the cam sensor signal with that tool. That is what I did, and when we wiggled the wire, you could see the the signal drop out. Here is a cut and paste of my previous post, - LARRY70GS wrote:
- Well, I replaced both my cam sensor and crank sensors while doing other work on my Riviera. I cleared the codes and sure enough, the next day, the SES light was on again. I pulled the cover off the wiring connector and moved the wires around, but it was getting dark and I couldn't see anything. The next day, the light went off and stayed off for more than a week. Took a ride up to one of my Buick friends in Connecticut yesterday. He has a Tech 2 type scan tool that we hooked up.
After hooking it up. We were able to monitor the cam sensor signal with the engine running. While moving the wires around, I watched the display turn from yes to no, then back to yes again. I knew it was the same problem documented in this thread.
We shut the engine down, removed the front half of the harness connector. I located the black wire and it looked intact. Pulled on it a bit, and sure enough, it broke right off.
The front half of the harness connector has a sort of locking mechanism for the individual terminals. Its a white tab visible in the second picture. If you pull that out a bit, the individual terminals can easily be pushed out of the connector. Each one has a small weather seal.
My friend happened to have a box full of these new, so we hooked up a small section of black wire, soldered the new connector on, inserted it back into the front block, and soldered it to the feed wire.
Buttoned everything back together, started the engine, and checked the signal. It was there. Another problem solved. This Riviera bulletin board rocks Saved me a lot of aggravation and work. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
kb54613@hotmail.com Special
Name : Kevin Location : Macomb, Michigan Joined : 2016-11-10 Post Count : 1 Merit : 0
| Subject: You guys are geniuses Fri Nov 11, 2016 7:22 am | |
| OK, my check engine light came on in my 98 Riviera 236,000 miles. I have had some stalling issues for a few months that I thought I had resolved with a new IAC sensor. Code P0341 cam position sensor, installed a new one, still set the code. Magnet looked perfect, no play in timing chain. So I read through some of this thread and was about to replace the camshaft sensor magnet because I thought it lost most of its magnetic strength. I reread all 9 pages of this thread which took a while and saw the last part about the mysterious black wire in the corner of the junction block at the firewall. I really did not want to remove the engine front cover and thought I would rule out the wire issue so I removed the junction block, looked at the corner wire, no problems, wire was intact. Flipped it around to the other side and sure enough, the black corner wire was broken off. Soldered in a jumper wire and reassembled and the problem is fixed!
Just wanted to say you guys are geniuses, thank you!
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Nov 11, 2016 8:02 am | |
| Yay! A fellow "Macombian"! Welcome to the site Now go introduce yourself in the "Welcome" section | |
al_roethlisberger Junkie
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Apr 07, 2018 10:00 am | |
| I'm having the same P0341 issue with our 95 SC. I replaced the camshaft position sensor first because it is cheap ($40) and easy, but like everyone else observed this did not fix the issue.
In my case the car went from fine to broken in just a day. Although it has been hard starting (not hard to start, but for the first few RPM seemed misfire/stumble then even out) for over a year now and no one has been able to tell why. This past weekend my son had driven it 3 hours home from school without any issue. Then we drove it around town a few times over the next couple days with no problems. Then I took it to work which is a 1 hour highway drive, and I noticed immediately that it didn't seem to have the power it normally had when trying to accelerate onto the onramp, although it did get up to 70mph reasonably well. Then on the drive up to work, although it would cruise as 70mph just fine, when I'd try to pass someone and use say 2/3 throttle, the engine would misfire very hard several times before then accelerating, but accelerate weakly. Once I let off the throttle back to just cruising at part throttle, all was good. This is the state it is in now. Other than misfiring on acceleration, the car starts, idles and drives fine albeit with not quite the power it normally seems to have. And when it misfires, the PCM sets the P0341 DTC.
So after reading all 9 pages of this thread I'll be checking that notorious black wire in the big through-firewall connector left of the brake booster. Hopefully the 95 wiring in this case is the same as the 96+ cars, and I too have the broken black or similar wire. Since I don't think anyone in this thread had a 95, I'll post what I discover so future 95 owners will know what to expect.
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Apr 07, 2018 2:50 pm | |
| My guess is that is what you will find. When my 98 had that problem, one of my friends hooked a Tech2 scan tool up and we were able to monitor the sensor value. You could see it drop in and out as you wiggled that wire. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sun Apr 08, 2018 11:00 am | |
| Larry is known as the wizard on V8 Buick site u have to be a wizard to find that wire!!!! | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Apr 13, 2018 5:41 pm | |
| - LARRY70GS wrote:
- My guess is that is what you will find. When my 98 had that problem, one of my friends hooked a Tech2 scan tool up and we were able to monitor the sensor value. You could see it drop in and out as you wiggled that wire.
Wish we had a Tech2 or similar scanner that could monitor that, but alas I do not and am not sure the Tech2 will work on a 1995? We do plan to get a Tech2 in the coming months for our recently acquired 2006 Saab 9-3 Aero, but don't have it yet. Thanks, I plan to start digging this weekend. I'm hoping the 1995 has the same wiring setup and defect. Al | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Apr 14, 2018 3:28 pm | |
Al Tech IIs were backward compatible but I forget how far - back to OBD I or ALDL? I really don't remember. Tech Is come up on eBay from time to time for short money. They will work on OBDII as well as OBDI but IIRC aren't as verbose. In order to do that Veetronix tacked on an adapter for each application. So a Tech I fully maintained until the Tech II became generally available, has more than a dozen clickety little parts and adapters. I forget when GM quit issuing adapters. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) | |
