| FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) | |
+39brettfavreisamonster jayeli farmboy92 gmann3001 robotennis61 BMD knuckled1 Bowersk LARRY70GS greg_anderson_78 Eldo ZEP 95RiviSC ibmoses GMfan1111 albertj Rickw L67 xxsupergman25xx tech408 curious riv BKRIV TonySmooth89 mrod7510 '96reese Joey98riv BillBoost37 deekster_caddy Jack the R SpaceBar 1998 Riv 1998rivman Jason urbsnspices 97rivman AA T Riley Mr.Riviera turtleman 43 posters |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Feb 27, 2008 9:48 pm | |
| http://www.3800pro.com/forum/pcms-tuning/3-how-can-i-get-case-learn-done.html
A CASE learn basically synchronizes the crank and cam position sensors. It should be done after a PCM installation or crank or cam position sensor replacement, or camshaft installation.
It can be done with DHP PowerTunr, HPTuners or any GM dealer with a TECHII and a nice service guy. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Feb 27, 2008 10:21 pm | |
| - deekster_caddy wrote:
- Thank you for the update. Have you had a CASE learn done? Pat, you too? Since the cam have you had a CASE learn?
I have a 97 so no case to be learned | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Feb 27, 2008 10:30 pm | |
I have a 97 so no case to be learned THANK YOU SOOO MUCH GUYS..................... i have access to a TECH II at my school.......... i will give it a whirl............. i hope this works man................ BUT i do need to know if it is safe to drive everyday until i do the case learn??? what does it do when they are off calibieration | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Feb 27, 2008 10:40 pm | |
| It's safe to drive. Worse you can get in the area of the MAF sensor is inoptimal fuel economy / performance and perhaps a MIL on. If I remember right, the computer runs some kind of safe set. | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Feb 27, 2008 10:47 pm | |
| - turtleman wrote:
- It's safe to drive. Worse you can get in the area of the MAF sensor is inoptimal fuel economy / performance and perhaps a MIL on. If I remember right, the computer runs some kind of safe set.
i did notice HORRIBLE gas mileage!!!!......... like less than 10 miles to the gallon AHHHHHH | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Feb 28, 2008 11:29 am | |
| For what it's worth, I have re-written my PCM at least 50 times, and have never performed a CASE learn. No lie! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Feb 28, 2008 11:51 am | |
| Aaron, you can do that as long as you are continuing to use the same PCM. It's only after a replacement you are supposed to do it.
Some people have never had to do it. Others have endless problems until it's been done... | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Feb 28, 2008 12:09 pm | |
| According to DHP, you are supposed to do it when you do a full rewrite, or if you get an SES light telling you to sync. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
1998rivman Amateur
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Feb 28, 2008 12:11 pm | |
| Your clue is that it stopped for a while when you "messed" with the spark plugs. I had the p0341 CPS code for something like a year. Changed the sensor twice. Changed plug wires and the ICM and coils. Tested ALL wiring from the PCM to the ICM and sensor (even put it under load with a 12volt halogen bulb). Ordered a new crank sensor, but the old one tested ok. Then I decided to do a minor tune up. Changed the front plugs and then drove it. No more p0341!!! The plugs that came out looked just fine, normal color, minor wear, no ash, no stray carbon tracks. They were, however NGK plugs. Put in 605 platinums and no more problems with cam sensor. Go figure. | |
BillBoost37 Junkie
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Feb 29, 2008 8:31 am | |
| Did you happen to notice if the NGK's ends were unscrewing and causing the issues? | |
1998rivman Amateur
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Feb 29, 2008 6:05 pm | |
| Can't say that I specifically looked for that. I honestly did not expect plugs to be causing that problem and only did a tuneup type inspection of the plugs. I was talking with one of our technicians he thinks it might have been an internal short in the plug, sending a spike through the ground path and giving a false signal to the ICM | |
Joey98riv Amateur
Name : Joey Age : 37 Location : Wyoming Joined : 2008-02-07 Post Count : 30 Merit : 0
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Mar 03, 2008 7:42 pm | |
| If it keeps persisting you may have lost your cam shaft interrupter. It is a magnet held into the cam sprocket but some plastic clip deals. This will throw a bad Camshaft position sensor code. There is a write up some where on how to fix it without taking the timing cover off and using JB weld. How ever in my experience Oil+Heat+JBweld= not so good. You can check for the interrupter by taking off the sensor and slowly turning the engine over by hand and use a mirror to look through the hole at the cam gear. If you see a hole with some plastic bits and debris around, gg. If you see a whole with a little black magnet cylinder shape still in it, nice you don't have to pull the timing cover! | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Mar 04, 2008 11:23 pm | |
| turtle!!!!!!!!!!!!!!!!!!!!!!! so how did you run the wire........... could you PLEASE take a picture or something..... i want to replace this wire first before i tackle the timing cover | |
SpaceBar Aficionado
| Subject: p0341 code Fri Apr 11, 2008 7:33 pm | |
| I'm having a p0341 code pop up and I remember somebody having this same code and there was a thread about it but I can't find it and its not popping up in the search.
Does anyone remember this or have any info on the code?
I have changed the cam sensor and the codes still popping up. | |
'96reese Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Apr 11, 2008 10:23 pm | |
| Camshaft position senor circuit performance is what i pulled up on my mitchel repair disk. there is about 25 steps to diagnose it. it looks like it will be a fun one to fix cause it starts off with disconnecting the pcm harness to test the voltage between the censor harness and the pcm conector. if you want me to send you the steps lemme know your email and i'll send it. | |
mrod7510 Member
| Subject: P0341 Camshaft Position Sensor help Sat Aug 30, 2008 12:14 am | |
| Could some one please post for me a P0341 DTC code diag. Trouble Shooting Chart? Thank you Much | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 12:28 am | |
| - mrod7510 wrote:
- Could some one please post for me a P0341 DTC code diag. Trouble Shooting Chart? Thank you Much
pretty sure its camshaft position sensor! but don't quote me on that! | |
TonySmooth89 Aficionado
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 12:39 am | |
| - 98riviera98 wrote:
pretty sure its camshaft position sensor! but don't quote me on that! HA! Owned! | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 1:11 am | |
pretty sure its camshaft position sensor! but don't quote me on that! HA! Owned! me or him........ unsure about who got OWNED | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 1:34 am | |
| You, You said don't quote me on that and i quoted you. | |
mrod7510 Member
| Subject: P0341 not the sensor. Sat Aug 30, 2008 1:45 am | |
| Hello, I would like the Trouble Chart, i hate changing parts or guessing you know? | |
'96reese Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 1:51 am | |
| this is what all data says,"The camshaft position PCM input is produced by the ignition control module. The Ignition Control Module (ICM) produces the camshaft position PCM input by filtering the Camshaft Position (CMP) sensor pulses when the engine is running and Crankshaft Position (CKP) sensor sync pulses are also being received. The PCM uses the camshaft position PCM input pulses to initiate sequential fuel injection and to determine crankshaft position for the misfire diagnostic. The PCM constantly monitors the number of pulses on the camshaft position PCM input circuit and compares the number of camshaft position PCM input pulses to the number of 18X reference pulses and the number of 3X reference pulses being received. If the PCM receives an incorrect number of pulses on the camshaft position PCM input circuit, DTC P0341 will set and the PCM will initiate injector sequence without the camshaft position PCM input with a one in six chance that injector sequence is correct. The engine will continue to start and run normally, although the misfire diagnostic will be disabled."
i personally prefer my mitchell on demand disk but i let my buddy borrow it. so pretty much if the camshaft positioning sensor is not reading about 5 volts then replace the sensor. if you know someone with a scanner that can read live measurements have them hook it up to see what the voltage is on the cmp or camshaft position sensor. | |
'96reese Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 1:57 am | |
| the camshaft position sensor sits at the top left of the harmonic balancer | |
mrod7510 Member
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 2:17 am | |
| if I had the step by step diag. for my car 96 Riv SC would not need snap-on scanner just a volt meter and test light. Just for kicks, the sensor is new. | |
'96reese Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 2:25 am | |
| i jus sent you a personal message mrod. or you can put your email address so i can send you the complete step by step procedure i pulled up | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) | |
