| FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) | |
+39brettfavreisamonster jayeli farmboy92 gmann3001 robotennis61 BMD knuckled1 Bowersk LARRY70GS greg_anderson_78 Eldo ZEP 95RiviSC ibmoses GMfan1111 albertj Rickw L67 xxsupergman25xx tech408 curious riv BKRIV TonySmooth89 mrod7510 '96reese Joey98riv BillBoost37 deekster_caddy Jack the R SpaceBar 1998 Riv 1998rivman Jason urbsnspices 97rivman AA T Riley Mr.Riviera turtleman 43 posters |
mrod7510 Member
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 2:29 am | |
'96reese Fanatic
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 2:33 am | |
mrod7510 Member
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 30, 2008 11:55 pm | |
| Your Aldata diag chart worked. I could have changed parts till im blue in the face and still not fixed it. So the problem was and open or broken wire (sensor input) between the ICM and the PCM. now the traction light, along with the SES light is gone. BYE BYE P0341 thank you much. | |
BKRIV Enthusiast
| Subject: P0341 Cam position sensor help Wed Dec 24, 2008 10:50 am | |
| Happy holiday's all!
We've had a stretch of really cold weather (some nights below zero) my Riv's not liking it any more than I am.
I noticed last week that while at a stop light it wants to jump into neutral, I believe the term is "neutraling out". I've checked my fluid level and it's ok. about the same time maybe a week later I felt a stumble while in cruise at about 65-70mph, felt it one other time while approaching a rise in the road, not sure if it's transmission related....but just this week "service engine soon" lit up and throw's code P0341-cam position sensor.
Are there any write-up's or threads concerning anyone here that has successfully dealt with this code? Could it be related to a damaged belt or tensioner can someone help figure out what happened or is happening...it's too damn cold to be messing with it and I still have a bit of shoppin to do...I'm a last minute shoppper. | |
curious riv Addict
Name : Chris Age : 43 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Dec 24, 2008 10:55 am | |
curious riv Addict
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Dec 24, 2008 10:58 am | |
BKRIV Enthusiast
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Dec 24, 2008 11:31 am | |
| Thanks Curious Chris...I just changed the sensor, 10 minute job, it took longer for the one man show at AutoZone to wait on me (29.99 part)...light is still on but I think the PCM needs so may warm-up cylces to make sure all is well and clear the code...will keep my fingers crossed and the forum informed as that occurs...must be a weak link. | |
curious riv Addict
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Dec 24, 2008 11:45 am | |
| I was reading in the other links about the p0341 and i think i saw where someone changed out their wires and that got rid of the code. Good luck with it! I'll cross my fingers for ya too | |
tech408 Rookie
Name : tech408 Location : Saddle Brook, nj Joined : 2009-06-12 Post Count : 10 Merit : 2
| Subject: P0341 Cam Position Sensor Mon Jun 15, 2009 10:44 pm | |
| PO341 code, 1998 Riviera I found a broken wire in connector c101, pin a7, black 18 gauge wire to the ignition module. The wire was broken inside the insulation so it looked like it was good from the outside. C101 is the big 72 wire connector near the trans dip stick and A7 is the black wire on the bottom left side of the connector. It's a tight squeeze but you have to cut the wire before and after the connector to jump around it. Test the connection first with a meter between the connector then after confirming the open, gently pull on the wire with a needle nose from the front of the connector, and look to see that the insulation stretches indicating that wire inside is broken from the stress of the weight of the harness. | |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Mon Jun 15, 2009 11:32 pm | |
| how does this effect the car if not fixed? | |
tech408 Rookie
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Jun 16, 2009 12:15 am | |
| The PCM(power control module), relies on the last time it was able to get a reading from the cam position sensor and uses that recorded data to calculate the correct sequences for ignition and fuel injector pulses. The car should run well, but at a less efficient rate. The MIL(malfunction indicator light) will light and a p0341 DTC will register. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Jun 16, 2009 2:08 am | |
| i like this guy...ur way to smart for me. lol but im like 90% sure a couple weeks ago i got this error...the guy said he did sumthin and it actually went away for a little and would only periodically come on..but recently comes on all the time.....and my gas mileage is significantly worse... im not as crazy as i thought, matt lol
what type of job is this? (btw im not good enough at all to do my own) is it a long job? | |
tech408 Rookie
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Tue Jun 16, 2009 9:30 pm | |
| No, it should take about an hour but it's just very tricky to splice the wire since there isn't much slack to begin with. You have to remove the large connecting block off the firewall and trim back some of the harness to get to the wires. Radio Shack sells 3m UR2 connectors that really make it easier to splice the wires. Most telephone technicians have them on their truck. They call them "U R connectors" These red connectors make it so all you have to do is insert the wires and compress it. It would also help to join www.alldatadiy.com to see the wiring schematic and diagrams of the connector before you start. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Wed Jun 17, 2009 2:01 pm | |
| yupp...this is my problem. i got it scanned today. its this code(im guessing its the same code for obd1.5 as it is for 2) i have to spend a few hours at the shop 2morro getting the exact problem diagnosed. im hopin this isnt going to cost me much. but im seriously rocking like 10mpgs in the city and 20 hwy.. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Jun 18, 2009 1:05 pm | |
| yupp..need a new sensor...200 bucks more so lets see.. transmission 600 and now this 200 and this is just in 6 weeks | |
tech408 Rookie
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Jun 18, 2009 1:44 pm | |
| 200 is not bad at all. Is the wiring ok? | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Thu Jun 18, 2009 2:07 pm | |
| yes. he said he checked all the wiring. all was fine. | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Jun 19, 2009 11:02 am | |
| hey guys.. i just got home from gettin my sensor replaced...im not sure if its because it was runnin a few weeks with the check engine light on for the cam..but after it was replaced...it feels like its "gargling" if that makes sense...it doesnt feel as smooth as it did..is it supposed to be like that. the power is still there.. does the computer need to learn the new repititions of the cams for some amount of miles? | |
tech408 Rookie
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Fri Jun 19, 2009 12:51 pm | |
| No, it should run smooth right away. He could have reset the ECM(computer). Resetting the ECM does require the. system to pass all its readiness tests in order to keep the service light from turning on, but it should run smooth and not gargle from the start. Take it back and have him take a look at it. | |
L67 Aficionado
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 15, 2009 11:29 pm | |
| Well my ticking stopped after some good oil circulation so now its just on to figuring out this P0341 code. Bill thinks i knocked something loose while fiddling with the belts so hopefully I'll be able to check it out tomorrow since it was too dark to see after i got home from woodward. I was gonna scan to look for misfires but my DHP wasn't scanning right for some reason so I'll have to mess with that tomorrow as well. Good news is that it seems to be running smoothly now minus the SES. | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 15, 2009 11:38 pm | |
| - L67 wrote:
- Well my ticking stopped after some good oil circulation so now its just on to figuring out this code. Bill thinks i knocked something loose while fiddling with the belts so hopefully I'll be able to check it out tomorrow since it was too dark to see after i got home from woodward.
After you pop the valve covers and screw with the push rods its a good idea to unplug the injector harness and crank it over for two 10 second intervals.. to get the oil movin around.. than plug the injector harness back in... | |
L67 Aficionado
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sat Aug 15, 2009 11:47 pm | |
| - 98riviera98 wrote:
After you pop the valve covers and screw with the push rods its a good idea to unplug the injector harness and crank it over for two 10 second intervals.. to get the oil movin around.. than plug the injector harness back in... Wish I'd known it earlier, but at least its sorted out now. So anyone have any other suggestions for the cam sensor issue? | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sun Aug 16, 2009 12:24 am | |
After you pop the valve covers and screw with the push rods its a good idea to unplug the injector harness and crank it over for two 10 second intervals.. to get the oil movin around.. than plug the injector harness back in... Wish I'd known it earlier, but at least its sorted out now. So anyone have any other suggestions for the cam sensor issue? Turtleman and i had a similar issue check out these threads https://rivperformance.editboard.com/series-ii-engine-transmission-f4/the-big-problem-cam-sensor-timing-chain-t1503.htm | |
L67 Aficionado
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sun Aug 16, 2009 12:55 am | |
| Was your wire bad as well? | |
T Riley Guru
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) Sun Aug 16, 2009 12:56 am | |
| - L67 wrote:
- Was your wire bad as well?
yes the yellow wire going to the MAF to the PCM was bad and also a black (signal wire) going from the ICM to the PCM was bad... easy easy fix | |
| Subject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) | |
