 Yet another problem....
dscott2000
dscott2000
Yet another problem.... Empty
PostSubject: Yet another problem....   Yet another problem.... EmptyTue Jan 06, 2009 6:01 am
I will start off by saying a BIG thank you for your help with my thermostat! Ok, Im not sure that I am posting this in the proper place or not. If so, please let me know! On my 1990 Riviera, only during acceleration, the car has a pretty fierce wobble. Kinda like a bent wheel or something.. I checked the trueness of both wheels up front and they are straight. Now, when I had the wheels off, I checked the tightness of all possible bolts, nuts, etc. But, what I found was when I checked the ball joints, on the drivers side, I had about 2mm of play in the ball joint. I know I need new ball joints. My question is, Do I need to compress the spring when I go to replace the ball joint? If so, is there a cheap alternative to getting the spring compressor? On my car the strut is connected to a 2 piece A arm. it looks as if the ball joint itself seperates from the a-arm. Thank you again for any advice given and previous advice!
http://www.cardomain.com/ride/3061543
dscott2000
dscott2000
PostSubject: Re: Yet another problem....   Yet another problem.... EmptyTue Jan 06, 2009 6:03 am
OOPS! I did post this in the wrong place! SORRY!
» Another heating problem or vent problem...
» Brake Light and Chime (ding-ding-ding)
» A/C Problem.
» new problem
» got a problem...
Riv Performance ::   N/A 3800 Tech :: Pre-Series I Engine & Transmission-
