 Porting & Polishing Gen III Blower
Merit : 171
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 11:03 am
69GSColorado wrote:
Pics of polished Gen V?
http://rivperformance.editboard.com/t7085p135-abaddon-s-
Scroll through for pics. More on Page 9 and previous
Merit : 49
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 11:05 am
I tried using flap wheels when I was messing with the manifold. They didn't work too well. I don't know the correct term for the bit I used, but it was shaped like a marble and was somewhat rough. For the tighter areas I used one shaped like a cone.
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 1:59 pm
Flap wheels aren't gonna cut it yo. Trust me, I've done it. I bought "flap wheels" for that purpose. I didn't even use them. Using those sanding wheels, you're going to sand ruts and grooves into the flat surfaces. You won't notice them until you get to the final polish. Then allllll the imperfections and dimples go HEELLLLOOOOO!!!!!!!
Just buy my already polished GenV  happy
WTF Codith said he used an 80G flap wheel!!! CODITH, WTF !?
Merit : 122
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 2:10 pm
Codith did his inlet. not the outside of the blower. Flaps are handy for the inlet cause, well, its round. If I'm not boring with a machine, I start gently with a burr bit, then a rock bit(careful they can load with aluminum get hot and "pop"), and finish up with 80/120 flappers on the inlet.
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 2:27 pm
Thanks, Andrew. Will you please paste a pic of what my best bet is for polishing the outside of the blower?
Merit : 171
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 2:42 pm
Charlie, I think you're embarking on a journey that might be best left untraveled. It's a very, very tedious job, and takes TONS of labor hours. Unless you're building a show car, I wouldn't bother. The only reason I polished mine is because I had nothing better to do at my old job...it's still sitting in a box in a bench here at work. I regretted starting it on the very first day. Once you start digging in, there's no turning back.
I started with 2" 36 grit cookies on my 90* die grinder. Then I switched to the 150 grit cookies. I also used various stones and burs to get in all the edges and corners. I had to do the top mostly by hand because of the shape. I used my Matco Metal Polishing kit with Jewelers Rouge to finish it off. All done with air tools.
Merit : 122
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 3:26 pm
Listen to Abaddon. I've never done the outside of a blower, task seemed too daunting for something under the hood. Add to that trying to *keep* it clean after install... yeah... I'd suggest spending time playing with the inlet and outlet, I find it more rewarding and not so much that you wish you never started.
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 5:04 pm
Sorry guys......... i had a dirt plog that a brought back from the dead and polished to a mirror finished. I was so happy with the meditative process that I instantly envisioned doing a blower. That's why I bought the gen V so early when I saw a good deal.
I will have a mirror polished blower under my hood and it will be glorious.
Last edited by charlieRobinson on Tue May 06, 2014 5:23 pm; edited 1 time in total
Merit : 49
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 5:18 pm
What do you want for your GenV Abaddon?
Merit : 171
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 5:23 pm
My "dreams" exactly  lmfao
More power to ya man. You have access to an air compressor?
Merit : 239
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 6:09 pm
Just curious - when you are finished polishing the outside of your blower, are you going to have it clear anodized, or will you re-polish it twice a year to keep away the white speckle?
'98 SC Riviera • 280k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30
^^^ RIV IS FOR SALE! ^^^
'05 GTO • 49k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26
'95 Celica • 150k miles • 0-60: yes
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 7:33 pm
I planned on sealing it somehow. Not sure what options I have yet but I want to seal and protect it.
Why yall hating on me?! Cheer me on maybe?
Merit : 20
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 7:34 pm
I'll have to look, but I have some "stuff" that I polished my motorcycle rims with several years ago that has kept them clean....
PostSubject: Re: Porting & Polishing Gen III Blower   Tue May 06, 2014 8:41 pm
Yes, sir. But I was planning on using an electric rotary grinder.
Merit : 122
PostSubject: Re: Porting & Polishing Gen III Blower   Wed May 07, 2014 7:33 am
Best of luck! Not hating at all, just being sure you know what your in for. Polished outside blowers are the tits.
Merit : 171
PostSubject: Re: Porting & Polishing Gen III Blower   Wed May 07, 2014 8:22 am
Agreed with Karma. I'm not hating on ya man. I'm just trying to make you fully aware of the project you're about to take on. Consider this a preemptive "I told you so" lol.
Merit : 49
PostSubject: Re: Porting & Polishing Gen III Blower   Sun Apr 19, 2015 11:45 pm
I found some free time tonight, so I put some more work into my spare Gen 3. Still needs the outlet smoothed and the silencer ports filled, but I made some good progress. The jigsaw was my friend. I plan on putting all new bearings into it, so that's why nothing is covered.
Do you guys think a router with a bit made for cutting metal would work well for smoothing.rounding the outlet?
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 11:03 am
shocked Dang..
Merit : 122
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 11:36 am
er, don't mess with a router. You won't get decent results with it, not to mention its downright dangerous to try and "machine" with one. It WILL hook and kickback causing all sort of gouges, chatter, and generally try to remove your fingers. If you don't have a mill you will get the best results by hand. Use a dremel with flex shaft or pencil grinder. Use oval, and flame shaped carbide burr bits. The aluminum will carve away pretty easily, and then you can hit it with flappers of various grit to get the finish. With a careful hand you can get it to look like it was machined. Take your time, you can always remove a bit more, but never add mack material if you take too much. Start at any sharp edges and high spots, and gently round them taking a bit at a time. The biggest thing will be keeping symmetry. Alternate side by side of the triangle, doing an angle or section, then do its mirror. That will give you the best chance of a decent result.
Whats your plan for the silencers?
Merit : 49
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 11:50 am
shocked  Dang..
Is that a good or bad "Dang"..?
First off, thanks for the advice.
I plan on making a sheet of aluminum to fill in the entire bottom of the blower, then using quiksteel to bond it to the blower and to fill the silencers. This way, even if the quiksteel dislodges the aluminum sheet wouldn't let it move at all. I've seen some people use thermal coatings like you use with success, so that might happen as well. Going to start working my butt off and hopefully get an intercooler and headers soon. Of course, the front coilovers have to happen somewhere in there as well.
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 1:37 pm
shocked  Dang..
I dont know know yet. Gotta wait and see how it goes and what happens after you install it.
I dont think I would ever attempt a port job without CNC machining and someone who has done it with tested results.
Everything Ive read says stock gen V > best port job possible on gen III. I'd just go with that and save the headaches for other things.
Best of luck, tho! thumbsup
Merit : 49
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 3:23 pm
Believe me, if any of the junkyards around here get a GP with a Gen V I'm all over it. I can be out the door with a whole Gen V setup for less than $100 (SC is $50, LIM is $35 or modify my spare).
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 5:36 pm
Matt, gen Vs are all over online for less than $200.
As for the aluminum plate+Quicksteel, unless you are using an intercooler, DO NOT DO IT.
Merit : 49
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 5:41 pm
Yeah, but I can get it local for less and get more with it. Just have to keep watching the local yards for one. I do plan on intercooling though.
PostSubject: Re: Porting & Polishing Gen III Blower   Mon Apr 20, 2015 5:43 pm
Yes, around me gen Vs seem to be taken from cars at the junkyard the day they get in. Good that you're intercooling.
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Porting & Polishing Gen III Blower
» Port polishing a Briggs & Stratton L-head
» Double HP
» Athena Big Bore - Installation question
» FAQ: Ported Blower vs. Gen V?
