 Fuel Line
Ryan from Ohio
PostSubject: Fuel Line   Wed Jan 07, 2009 8:42 pm
1995 Rivi Series 2 N/A
The fuel line in the rear thats got a 90 degree elbow into the fuel rail. Its leaking.
I cant seem to locate a part number on gmpartsdirect.com
Need fixed asap.
Can anyone comment on how hard it is to change such line? Also if anyone has the correct part number for the N/A model?
1995 Riv
PostSubject: Re: Fuel Line   Wed Jan 07, 2009 9:34 pm
It is one piece clear back to fuel filter by left rear wheel. There have been members splice it on here check topics there was one up lately. Good Luck
Ryan from Ohio
PostSubject: Re: Fuel Line   Wed Jan 07, 2009 9:37 pm
Yes I did a search. Seems consensus is to replace with OEM.
Im going to try that Dorman part #800-059
Apparently its a new elbow with some length of the plastic line and some sort of union connector to splice it together. Dont have much to loose at this point. Im going to check with dealer on pricing for the fuel line. If its not to costly I will go that route and replace the fuel filter while Im at it.
1995 Riv
PostSubject: Re: Fuel Line   Wed Jan 07, 2009 10:34 pm
I am not sure if that line goes to fuel filter there are three lines back there, others go to tank. Maybe it is marked on the lines. Hey Redline is parting out a NA 95 on here look him up and PM him on here he is in Texas though.
Ryan from Ohio
PostSubject: Re: Fuel Line   Thu Jan 08, 2009 9:47 pm
Well after some trial and lots of water boiling, Im done (I HOPE!).
I ended up going with the Dorman "fix".
Dorman #800-059
Direct link to Dorman site:
" class="postlink" target="_blank" rel="nofollow">https://www.dormanproducts.com/cgi-bin/vm91corp30r/item-dtl.w?sid=fPrIffWQMTtYlRjO008864173301285078&item=800-059&icrid=0x000516a0&clt=hwrap1&vsrch_str=&vsrch_brand=&vsrch_cat=&st_amount=&end_amount=&start=&vfrom=&prev=&vnext=&category_list=surprised
It will look like that have about 16" or so of tubing, a barb and some useless plastic "tool".
Anyhow I cut mine where the straight section was. Heres what I cut off:
I figured the length I needed for the new piece. Cut it with a SHARP utility knife. I soaked about 2" or so in boiling water for 5 minutes while it still boiled. THe union/barb slid in easily.
The part on the car was the real treat! (saracsm here)...
I dipped it in hot water, 4 pans worth to be exact. I got over the first barb and hung up on the second. Just couldnt get it hot enough. So we broke out the heat gun. We did it on LOW and about 6" away from the line, going all over the outside where I will be sliding on. I keep trying while my Uncle heated- as soon as it went on the heat was GONE. YOU MUST BE EXTREMELY CAREFUL OR BOOM!
So far so good, no leaks.
The original was leaking where it was pressed onto the barb of the elbow. Turns out where the elbow ends and its just the tube there is a bunch of small cracks and they were seeping...
1995 Riv
PostSubject: Re: Fuel Line   Fri Jan 09, 2009 12:18 am
Thanks for the details, it looks like the smart way to go. I bet the water wouldn't stay hot because it was 19 deg. Glad your out of it for now Ryan. Don
Ryan from Ohio
PostSubject: Re: Fuel Line   Fri Jan 09, 2009 10:14 am
Thankfully I had the use of a garage and some heat, but not to much... lol
She drove the car to school this morning and I didnt get any calls about gas odor, so Im hoping all is well. I will check tonight.
Fuel Line
