 Write-Up: Fuel Pump/Tank Sending Unit Replacement
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sun May 03, 2009 2:04 pm
Thanks turtleman! Looking forward to it.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Mon Sep 21, 2009 8:43 pm
Did you get this sending unit for the Aurora, or is there a Riv specific unit?
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Mon Sep 21, 2009 10:26 pm
If I remember correctly when he bought it the seller had 98-99 Riv.unit for sale.
Also, remember he's in Canada and so is the vendor if that makes any difference to you. Some people don't like buying from Canadian vendors.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Mon Sep 21, 2009 11:33 pm
Canada? What's that? lmao
Good point, better to get it here in the states if possible. Rock Auto has a fuel level sensor kit for $128 - think I'd rather do business with the Canadians.
Not having much luck here.
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 22, 2009 12:24 pm
Did your sensor go out too? mine did cool
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 22, 2009 1:09 pm
It's not entirely out but it doesn't read right. It's still useful within the first half tank.
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 22, 2009 1:52 pm
mine fails... it read full and i went and put 17.8 gallons in my tank shout
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 22, 2009 5:07 pm
So what's the issue with ordering from Canada? VAT tax?
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 22, 2009 5:32 pm
Come to think about it I bought something from a Canadian Vendor last year without any troubles, although the price did include shipping.
The only issue was it seemed to take UPS a long time to get it here.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Thu Sep 24, 2009 12:22 pm
I contacted the seller. Apparently he's out of Rivi sensors. He suggested trying a Skylark sensor. scratch Wouldn't the Aurora sensor be a better bet? I'd rather not play "try it and see" either way if it's going to involve splicing wires
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Thu Sep 24, 2009 12:23 pm
I'm going to splice my wire's... and use hot glue to seal them than shrink wrap and electrical tape.. i don't want those exposed!!!
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Thu Sep 24, 2009 2:46 pm
Where did you find a sensor?
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Thu Sep 24, 2009 6:45 pm
At his prices, try one of each and let us know.
Splicing wires is not a problem at all. Just solder and heat shrink.
There is such little current in there it can't hurt anything or cause problems. If it could your existing worn rheostat would have already gone BOOM.
Just keep the wires covered and separated. Just like they are now.
I'm serious, there is nothing to worry about as far as explosions unless you cause an substantial arc in gasoline vapor.
This, the rheostat and wiring, is always in fluid gasoline.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sat Sep 26, 2009 2:58 pm
Can one of the shop manual guys check to see if the Riv and Aurora have the same tank (if it says?)
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sat Sep 26, 2009 3:37 pm
Doesn't say Jack, but there are two different sections for Tank Removal depending on which car, Aurora, or Riv. The Illustrative pictures look exactly the same though.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sat Sep 26, 2009 5:25 pm
The pictured tanks look the same? Surely they are. Could it be that there are two different sections for ease of use?
Let me know what you think, and I'll contact the seller again. He's offering a money back guarantee in case the part is wrong. I've got no idea how to tell if the part is wrong without installing it though.
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sat Sep 26, 2009 9:18 pm
The pictures they use look the same. No way to know if they are exactly the same, but it would stand to reason that they are.
Merit : 134
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sat Sep 26, 2009 9:49 pm
Maybe the difference is the pumps run different pressures for different engines? I don't know. Just a guess.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sun Sep 27, 2009 3:31 am
Duh, I just thought to check Edmunds. Edmunds says the Aurora and Riv both have a 20 gallon tank. Surely GM didn't make a unique 20 gal tank for each vehicle. I'll go ahead and order the Aurora sensor.
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sun Sep 27, 2009 8:42 am
I just looked on www.rockauto.com. 1998 Riviera fuel level sensor.
1998 BUICK RIVIERA 3.8L 231cid V6 MFI Supercharged (1) : Fuel/Air : Fuel Level Sensor Price Core Total Advice
ACDELCO Part # SK1037 {#25335941}
SENSOR KIT,FUEL LVL
* Non-stock item--shipping delayed up to 5 business days
$127.99 $0.00 $127.99
Add to Cart
And 1998 Aurora
1998 OLDSMOBILE AURORA 4.0L 244cid V8 MFI (C) : Fuel/Air : Fuel Level Sensor Price Core Total Advice
ACDELCO Part # SK1035 {DUAL PRONG LOCKING FEATURE WITH LOOSE CPA CLIP #25330713, 88963638}
SENSOR KIT,FUEL LVL
$107.89 $0.00 $107.89
Add to Cart
ACDELCO Part # SK1194 {DUAL PRONG ATTACHMENT FEATURE #19121313}
SENSOR KIT,FUEL LVL
$143.79 $0.00 $143.79
Add to Cart
Different parts, available though.
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sun Sep 27, 2009 8:48 am
Definitely cheaper though, worth a shot.
Link
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Sun Sep 27, 2009 1:58 pm
The last one's the one I was going to get. But now you've got me worried again wink
96Super
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 29, 2009 2:37 am
My Gauge works from full to half. Is this an easy fix?
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 29, 2009 10:26 am
I think so. Just open the hatch in the trunk floor, remove the pickup/sending unit and replace. You might need a new locking ring if it's rusty. While you are in there, replace the pickup screen to the fuel pump.
Merit : 83
PostSubject: Re: Write-Up: Fuel Pump/Tank Sending Unit Replacement   Tue Sep 29, 2009 12:49 pm
I've directed the eBay seller to this thread. I bet he could sell a few sensors if he could get the right ones available again.
Page 2 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
