 E-brake, Parking Brake will not reset to home position!!
PostSubject: E-brake, Parking Brake will not reset to home position!!   Wed Jan 14, 2009 9:40 pm
AS the title says MY riv will unlock the brakes so they will not be LOCKED.. BUT the little pedal for the parking brake WILL not like click to the home position. WHICH in return leaves me with an annoying bell....i wanna shank it... but really anyone got any ideas?
PostSubject: Re: E-brake, Parking Brake will not reset to home position!!   Wed Jan 14, 2009 10:52 pm
Mine was doing the same thing, I ordered a new Parking Brake Control assembly from www.monsterpartsonline. GM OEM part for $30.32.
The spring gets weak and can't return the lever. I got tired of holding it up with my left foot to stop the dinging. You can try removing the assembly and messing with the spring or try and replace just the spring, but I figured if I was going to go thru the hassle of removing it I'd just replace the whole thing.
PostSubject: Re: E-brake, Parking Brake will not reset to home position!!   Thu Jan 15, 2009 12:27 am
I hear ya cool
Merit : 131
PostSubject: Re: E-brake, Parking Brake will not reset to home position!!   Thu Jan 15, 2009 3:06 pm
Let's just say why do you think the brake mechanism replacement is so cheap...
just get one from gmpartsdirect or monsterpartsonline and be done with it... and Rick if you have the monster p/n handy please post. I don't have.
PostSubject: Re: E-brake, Parking Brake will not reset to home position!!   Thu Jan 15, 2009 4:32 pm
Monsterpartsonline doesn't provide a P/N.
You just have to go to "Brakes" section, then "Parking Brake" and it will list the Control and cables, but no part numbers.
I ordered everything from the Control Assembly and every cable to the rear wheels and changed them all. A couple of them were frayed and stretched so I replaced everything with new while I was doing my rear brakes.
PostSubject: Re: E-brake, Parking Brake will not reset to home position!!   Thu Jan 15, 2009 8:42 pm
mine will release sometimes but the light will still be on. I just tap it up with my foot and the light goes off.
PostSubject: Re: E-brake, Parking Brake will not reset to home position!!   Fri Jan 16, 2009 9:45 am
I found the P/N for the Parking Brake Control Assembly,
GM # 25658073
Also, I forgot to suggest adjusting the parking brake cables first as there are springs on each cable that help with the retraction.
As I mentioned mine were stretched and a couple of the cables were fraying so i replaced them, but i was just trying to adjust when i noticed the problem with the cables.
The adjustment is on drivers side of car. Easy to get to. The nuts may be corroded so spray with penetrating spray a couple of times before trying the adjustment and don't over adjust.
