| | Automotive Acronyms | |
+9Eldo deekster_caddy Rickw TonySmooth89 97rivsc L67 palermocorey90 NO 4 EVR AA 13 posters | |
| Subject: Re: Automotive Acronyms Mon Jan 04, 2010 7:37 pm | |
| - Rickw wrote:
- MFG = Manufacturer (always did in my neighborhood) and in the manufacturing world that I worked in.
Right now I'm trying to get that %#$*! brake pedal assy out of the car, to fix the MFG's lousy design in the first place, and out of 6 nuts, they put 1 right behind the steering shaft u-joint... So my vote is actually: MFG = More Fuckin' Grief!! (ALDL = Assembly Line Data Link) | |
| | | Eldo Expert
| Subject: Re: Automotive Acronyms Tue Jan 12, 2010 1:56 am | |
| Actually, ALDL & DLC should be put on the list... And I just remembered another one: CHMSL - Center High Mounted Stop Lamp, AKA 3rd Brake Light. | |
| | | AA Administrator
| Subject: Re: Automotive Acronyms Tue Jan 12, 2010 11:17 am | |
| MFG, ALDL, DLC, and CHMSL have been added, thanks. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Ironclad-454 Enthusiast
Name : Nate Age : 40 Location : Oklahoma Joined : 2008-11-22 Post Count : 162 Merit : 9
| Subject: Re: Automotive Acronyms Wed Jan 20, 2010 10:04 pm | |
| Heres a few more Acronyms not on the list
EFI- Electronic Fuel Injection PROM- Programmable Read Only Memory EEPROM- Electronically Erasable Programmable Read Only Memory RAM- Random Access Memory AFR- Air / Fuel Ratio OBD (I or II)- On Board Diagnostics (Gen 1 or 2) BOV - Blow Off Valve (see also POV) POV - Pop Off Valve (see also BOV) MS - Multi-Switch HU- Head Unit BDC- Bottom Dead Center BTDC- Before Top Dead Center ATDC- After Top Dead Center | |
| | | Eldo Expert
| Subject: Re: Automotive Acronyms Wed Jan 20, 2010 10:34 pm | |
| Not a bad list. I would add that EFI is analog electronic injection, preceding DFI, Digital or computerized Fuel Injection. Think optional Cadillac injection in the 70's, versus the ECM type that began in 1980. | |
| | | Sponsored content
| Subject: Re: Automotive Acronyms | |
