 Check engine oil light
Sweepspear
Sweepspear
Check engine oil light - Page 2 Empty
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 12:15 pm
The one in my '96 stays on for about 15-20 seconds no matter what.
I find it to be the most idiotic of idiot lights. dunce
If I ever have the dash apart I'm pulling the bulb out!
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 12:16 pm
Or you could replace the sensor. Then you'll know if you're ever low on oil!
7901mark
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 12:51 pm
True, but if its failing I would think it would happen more often than just at the start up, could be wrong.
Sweepspear
Sweepspear
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 1:06 pm
I know I am never low on oil.
These 3.8 engines have never been known to have oil loss issues that I know of. Aside from leaking oil pans.
A warning light ? Sure. One that goes on when the engine really is in dire need, but not one that nags everytime you start the car and head out the driveway.
I find it odd that these cars don't have the oil change minder like even my old '92 Park Ave. has.
scratch
Merit : 153
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 1:14 pm
scratch
I was told once they have the capability (in the ECU) but not the interface (no display). If you have the FSM, look at the Aurora's set-up for details (it has the display). Personally, i doubt it but would not be surprised if it were true.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 1:35 pm
Mine has never come on, it doesn't nag me because the sensor works.
If you took your car in to get your oil changed, you might check the dipstick next time you popped the hood. But if they didn't put a full 5 qts in, the car would tell you right away by turning that light on. It only comes on when you're low. I wish more cars came with that kind of insurance.
7901mark
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 1:57 pm
If the sensor is in the oil pan, then I would think the sensor would read the most oil on start-up since that is where all the oil is after the car has been sitting. Its just strange. If the sensor was failing, I would expect to see it at least once during driving.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 2:14 pm
That's a good point, Mark. Maybe the computer knows to only trigger the lamp if the oil level sensor sees low oil on start-up? It could be programmed to ignore all readings during driving - that's when the oil pressure sensor is on duty.
7901mark
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 2:18 pm
very true smile Who knows....I just wish it would either stop or fail out right so Id know for sure. Until then, Ill just keep my eyes on the oil levels.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 2:22 pm
I think if the oil level sensor fails, the result is a low oil light for 30 seconds every time you start up. If it only happens sometimes, to me it means the sensor is behaving erratically.
Sweepspear
Sweepspear
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 2:34 pm
I guess I just assumed that having it linger was the way they meant it to
be. headshot tongue
I still change my own oil, and formed the habit many years ago of checking all the fluids and tire pressures on my cars at least once a month.
I am impressed that after 200,000 miles It doesn't use any.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 2:46 pm
That's impressive. Mine's over 200k and it uses a little, but not more than a quart every oil change. I top it off about once per month and I do ok. I mean, oil is a lot cheaper than gas, so I don't mind!
My other car w/455 V8 from '70, 112k miles - it never burns or leaks a drop of oil.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 3:43 pm
Correct...
The computer can 'see' the level sensor at all times - at about a half-quart down my scanner can see it switch from OK to LOW after startup, because of the pump-up and the windage. However, just like with the OBD Readiness Tests, there is a set of parameters that must be met before the light is actually turned on... Before & after coolant temps and/or time between ignitions cycles is used to make sure the oil is drained back to the pan before taking the measurement.
If the low reading is valid, the light will stay on up to 7 minutes after the computer makes its decision.
1996RIV CALI
1996RIV CALI
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyFri Apr 30, 2010 4:16 pm
mine is alway on i was told it was a bad sensor---- so i always ckeck my oil to be on the safe side.
7901mark
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon May 03, 2010 1:00 pm
thats good to know! Thanks!
LaFlare
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 1:28 am
sig check
LaFlare
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 1:30 am
hey, i think i am having this problem. the check oil light stays on for 30-45seconds after start up. it only comes on when i start up and never during driving or anytime after that. my oil level is fine and yes i only check it on level ground. but from what i've noticed, when my car has been parked in the driveway (slightly inclined) and i start up, the light does not come up. do you think its just the sensor? where exactly is the sensor located? hopefully it just needs to be cleaned if thats the case, but worse case if needed where could i buy a replacement? thanks
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 1:53 am
It's screwed into the front side of the oil pan, and is a simple magnetic float. They're fairly cheap to buy, but one thing doesn't make sense: parking the car pointed uphill should actually make it worse...
LaFlare
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 1:57 am
hmm, then what do you think it could be? but yeah everytime i park in the driveway(inclined), the light doesn't stay on. opposed to when i park inside the garage(level), the light stays on.
Merit : 153
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 7:53 am
Check the wiring to the sensor with a voltmeter, for continuity and shorts to the chassis. If you need further instructions on how to do that please post. The idea here is that the wire's got a problem that only shows up when you are parked level.
Beyond that, IIRC the sensors are not all that expensive, just replace it so it does not surprise you in a bad way one day by being correct but you ignoring it. If you're feeling ambitious, might want to pull the oil pan and clean it out (you may or may not find sludge), replace the oil pan gasket. If your oil pan seeps (pan looks oily) this isn't a bad idea, actually, if you've a little time on your hands.
As for replacing the sensor - - think of it as one less thing to worry about.
LaFlare
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 5:11 pm
actually i lied, i guess its a matter of "sometimes" about the whole parking in the driveway thing. my car was parked in the driveway today and on start up the light stayed on. so yeah, but its definitely 90% of the time the check oil level light will stay on for the extra 30-45seconds. i guess im gonna go and check the sensor whenever i get time
oh and a related question i've been meaning to ask. i'm sure its not the reason the light is going on but;
when checking the oil level on the dipstick, is the oil full when it reaches just BEFORE the letter F or AFTER the letter L? when i changed my oil i used the filter PF-52(if that matters, cuz i know you could add extra oil when u use this correct?) and i used only about 4.5 quarts. light showed up, and when i checked the oil level it was just under the letter F. then added a bit more, but not a full 5quarts, and it now sits just after L.... shouldve asked that before, but still the light shows up so i'm sure that irrelevant ?
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 5:30 pm
From what I remember about the switch, it doesn't have a helluva lot of space for the float to move up & down... If, as the oil commercials say, you are a victim of SLUDGE afraid, I suppose it could be interfering with the movement of the magnetic ring.
So yeah, before buying one you can slide under the front of the car with a big crescent wrench and remove the switch, and maybe a blast of BrakeKleen will fix it. (of course, then you should probably be thinking about a can of Rislone and an oil change, too...)
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 6:13 pm
The car should hold exactly 5 qts when using the PF-52. 4.5 qts is the OEM spec.
LaFlare
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 6:18 pm
oh geeze i thought i was trippin, but i guess an admin or mod WAS editing/deleting my posts lol ? sorry
i wanted to word it better if it makes a difference or not then nvm
when checking the oil level on the dipstick, is the oil full when it reaches right before the letter F, or right after the letter L? when i changed my oil i used the filter PF-52 and i used only about 4.5 quarts. when i checked the oil level it was just under the letter F. then added a bit more, but not a full 5quarts, and it now sits just after L.... shouldve asked that before, but still the light shows up so i'm sure that irrelevant.
edit- ^ yeah i wasnt sure if i shouldve put the full 5quarts in, but at the end of the day i ended up putting total about 4.75quarts in. and i just checked my oil level and it already seems full. oil covers the word "full" and sits right after the letter L.
is that the proper way to know if its full? and what if i used the regular suggested OEM filter, where would the oil level sit after 4.5quarts.
sorry just curious and just wanna make sure
PostSubject: Re: Check engine oil light   Check engine oil light - Page 2 EmptyMon Aug 02, 2010 9:58 pm
Well Golly,
As far as the Quantity of oil your putting in after an oil change your OK.
4.75 -5.0 quarts with the larger filter is good.
The fact that you have an oil level LOW light on is a level switch issue and for what they cost just remove it and replace with new and more than likely your problem will go away. Period.
» Check Engine light jus came on ?? Help !!
» RZR Problems
» Temp light on when engine is cold??
» How do I check if I'm getting spark?
» RZR trouble codes.
