 Check engine oil light
Check engine oil light - Page 3 Empty
PostSubject: Re: Check engine oil light   Check engine oil light - Page 3 EmptyMon Aug 02, 2010 10:10 pm
The car should hold exactly 5 qts when using the PF-52. 4.5 qts is the OEM spec.
Actually, the larger filter doesn't hold anywhere near an extra half-quart...
Think about it: A pint can of beer is larger than the whole filter, especially when you consider the volume consumed by the guts inside the filter.
Having said that, you'll come to no harm if you overfill by a half-quart. Just use the hash-marks or dots on the dipstick as a gauge of how far over you are. (By the way, those are what you should be looking at, not the actual word FULL.)
PostSubject: Re: Check engine oil light   Check engine oil light - Page 3 EmptyMon Aug 02, 2010 11:11 pm
Exactly, A little here a little there, by god quit cutting hairs.
A little over the line, a quarter of a quart over the line, a half a quart over the line, will not kill the motor nor cause any damage.
You old lady's need to stop splitting hairs.
I use the larger filter and always just put 5 quarts in. Yes it is over the line. But by the time I'm ready for another oil change it is at or below the line. Yippeee.
Or am I now putting in 6 quarts since i changed the oil pan to aluminum, I can't remember and i only did it 6 months ago, but haven't changed the oil since.
I gather I'm abusing my motor with Mobil 1 and their equivalent of the larger filter. Yes I did put 6 Qts. in it and it was a 1/2 qt heavy.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 3 EmptyTue Aug 03, 2010 1:11 am
You guys are right, it's probably 4.75 qts with P-52, but I'm like Rick, I go over a lil' bit so it stays good until the next change. None of this matters, though, because the OIL LEVEL lamp won't come on until it's 1.5 qt low.
PostSubject: Re: Check engine oil light   Check engine oil light - Page 3 EmptyTue Aug 03, 2010 1:38 am
Not that anyone really should wait until the light comes on, but yes, an extra pint is nice insurance... especially since GM should have provided a larger oil capacity.
» Check Engine light jus came on ?? Help !!
» RZR Problems
» Temp light on when engine is cold??
» How do I check if I'm getting spark?
» RZR trouble codes.
