'96reese Fanatic
| Subject: head bolts Thu Jan 22, 2009 1:31 pm | |
| hey i forgot which head bolt went where? do the shorter ones go on the lip of the head or do the long ones go on the lip of the head? help please its been 4 months since i took these heads off and i cant remember. its a 96 superchargered riv if that matters. | |
palermocorey90 Expert
Name : Corey Age : 34 Location : Rome NY Joined : 2007-10-03 Post Count : 2968 Merit : -24
| Subject: Re: head bolts Thu Jan 22, 2009 1:57 pm | |
| im pretty sure its the long bolts that go inside the heads that hold them on. but you should have new head bolts anyway | |
| Subject: Re: head bolts Thu Jan 22, 2009 2:27 pm | |
| Once you drop the head on it should become pretty obvious if they aren't all the same length. Usually if the shorter bolts go anywhere it'll be the outer corners or the outside (nearest exhaust). It's been a while since I had heads off a L67.
I'm pretty sure the longer bolts will go nearest the intake and the shorter bolts nearest the exhaust... | |
'96reese Fanatic
| Subject: Re: head bolts Thu Jan 22, 2009 4:34 pm | |
| thanks guys got it figured out....the new inners are the long bolts and the new outers are the short ones | |
1995 Riv Enthusiast
| Subject: Re: head bolts Thu Jan 22, 2009 6:15 pm | |
| How are you going to tighten the bolts without the J36660 Gm tool Torque angle meter or do you have one? Or does the series II not need it ? Just curious about the procedure Reese. Don | |
| Subject: Re: head bolts Thu Jan 22, 2009 8:47 pm | |
'96reese Fanatic
| Subject: Re: head bolts Thu Jan 22, 2009 10:48 pm | |
| i have a snap-on 3/8 ft. lb torque wrench, and as far as the 130 and 30 dgree angle turns i jus used a compass and 1/2 breaker bar. | |
1995 Riv Enthusiast
| Subject: Re: head bolts Fri Jan 23, 2009 12:03 am | |
