 Have you replaced your crank sensor?
Merit : 134
PostSubject: Have you replaced your crank sensor?   Sat Jan 24, 2009 6:17 pm
The crank sensor queston comes up from time to time on high mileage/old Rivieras. I though it might help people to know when folks replaced theirs, becaue the sensor's failure is so tough to diagnose.
So - please post the date and mileage at which you replaced your crank sensor.
I replaced mine at 165,980 miles on 6/8/2007.
lionfish
PostSubject: Re: Have you replaced your crank sensor?   Mon Jan 26, 2009 9:24 pm
The crank sensor (10456161) was replaced on 10/29/2007 with 223,079 miles.
PostSubject: Re: Have you replaced your crank sensor?   Mon Jan 26, 2009 9:43 pm
What do we post if we've never replaced them? Current mileage? (140,000) Or just wait until it needs changing, then post here... wink
PostSubject: Re: Have you replaced your crank sensor?   Mon Jan 26, 2009 10:40 pm
replaced mine 3/10/07 at 125000 miles
Merit : 134
PostSubject: Re: Have you replaced your crank sensor?   Mon Jan 26, 2009 11:03 pm
thanks guys, keep posting.
If you've never replaced cranksensor, just post current miles on the odometer and "not yet" or some such.
Point is that I am suspecting that "crank sensor craps out at so and so mileage" that I was told (and have been repeating) might be BS. I don't like BS not even my own - and the only way I knew how to Come Clean was to ask us all to take a moment plese and post some actual data. Then we can jsut look at the data and make up our own minds.
Thanks
racing007s
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 12:50 pm
203,000 when I took the car apart for dirt circle track racing and as far as I know, never been replaced!! (knock on wood)
Ps. First year racing the Rivi SC and 2nd in points at 2 local tracks!! Not bad...
http://www.hammerdownspeedway.com
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 12:55 pm
112k a still waiting.
knock on wood
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 1:31 pm
Here's a laugh for ya.
62,XXX miles.
Replaced in November after a many trials to figure out why it wouldn't turn over.
Replace Crank Sensor and Harmonic whatchamacallit
Cost around $600, but now starts every time.
The Riv I just bought was rarely used by the original owner and even less used by the guy I bought it from. And seeing as it is a 1995, things were apt to go awry for $1350.
But again, all is good now. Highly recommend suggesting it to the mechanic before he 'tries' his methods.
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 1:45 pm
95k and not yet.
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 7:07 pm
Thats great!
Is there enough left to race it again next year? I bet that Buick is rough on them little cars. 3gears
Bert tavis
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 7:57 pm
80k miles and not yet
97rivsc
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 10:16 pm
103000 and not yet
http://www.facebook.com/album.php?aid=2007661&id=1593150315#/pro
PostSubject: Re: Have you replaced your crank sensor?   Tue Jan 27, 2009 11:33 pm
replaced at 147k mi when the majority of my mods were done but it was working fine when I did the swap....just wanted to be safe.
Merit : 134
PostSubject: Re: Have you replaced your crank sensor?   Wed Jan 28, 2009 11:31 am
OK my impression so far is:
"Crank sensor craps out at so and so mileage" is not a good rule of thumb - but
"if you have a no-start with no codes set, replace the crank sensor" is a very good bet.
Further comments?
PostSubject: Re: Have you replaced your crank sensor?   Thu Jan 29, 2009 2:23 pm
Not yet 229,000
Merit : 49
PostSubject: temp   Fri May 03, 2013 6:51 pm
Mine just threw a code on the way to dinner. It was like it couldn't decide to shift (lurched a bit). Probably the crankshaft sensor. It's the only code I've gotten, and I've gotten it a couple times.
PostSubject: Re: Have you replaced your crank sensor?   Sat May 04, 2013 12:01 am
162000 not yet but plannin on it soon just as precaution
PostSubject: Re: Have you replaced your crank sensor?   Sat May 04, 2013 1:08 am
261,000 miles on the original crank sensor. When I had the engine rebuilt 15k ago, the builder checked the sensor and recommended it not be replaced. Considering he's in the business of replacing parts, I didn't question his decision.
96riv
PostSubject: Re: Have you replaced your crank sensor?   Sat May 04, 2013 9:51 am
Be careful of the replacement, A friend who fixes Turbo Buicks bought 5 from Rockauto and 4 were bad, they were grooved and or warped,
http://www.arizonagn.com
PostSubject: Re: Have you replaced your crank sensor?   Sat May 04, 2013 10:15 am
Yeah, I have no reason to think my OEM will ever fail. Lucked out, I guess.
PostSubject: Re: Have you replaced your crank sensor?   Sat May 04, 2013 11:16 am
The original is probably better than any replacement piece and might outlive the rest of the car. Not something to replace as a maintenance piece.
