 FAQ: Adding Supercharger to NA 3800 V-6?
Go to page : Previous  1, 2
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 7:18 pm
I'd say if you run 16 flat you're doing pretty well. That's what a Regal LS (same engine) runs, and it weighs 300 lbs less.
gosloriv
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 7:21 pm
Damn i was hopein for a little better answer tham that !!!
Guees we all will find out here in a couple of weeks when i hit Norwalk !!! I was thinkin atleast 15 secs!!!
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 7:30 pm
Run it stock for a baseline, then we can see what the mods do!
Racing at Norwalk on April 29th.
gosloriv
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 7:37 pm
Well i have already done sum half ass mods !!!! As you can see in my signature.I dont really know what else is available for these engines. As it is not supercharged and there arnt to many people tryin to do anything with the N/A. neutral
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 7:50 pm
I see your mods there. If you build a custom CAI or FWI, and I'd bet for sure you'll be in the mid-high 15s.
There's a N/A race class at IDD, so might be some people there with some tips on modding your engine.
gosloriv
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 7:55 pm
U know what? i did sorta start on this by adding a peice of 3and1/2 inch pvc pipe in between the box and throttle body wich made a big diff but def need to finish this with the fender well mounted K/N filter !
Wich will be done b4 April 29th. Cant think of anything else i can do with out big money !!! dunno
gosloriv
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 9:19 pm
What plugs should i run !!!???
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 9:22 pm
Just your recommended stock ones. Maybe Autolite 605s if you drive like a crazy person, WOT every other light.
gosloriv
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Fri Mar 23, 2007 9:32 pm
yeah that would be me wot !!!! 3gears
PostSubject: Re: FAQ: Adding Supercharger to NA 3800 V-6?   Sun Jun 22, 2008 7:51 pm
i belive im currently the only riviera with the conversion
