| FAQ: Shocks & Struts Options | |
+64EyeDoc1 nickwon High Chaparral jbird skatterbrane Oldschool79 LARRY70GS brettfavreisamonster RvieraRider KnottyEagle Abaddon 69GSColorado matt270avian Johnny5 al_roethlisberger pbrktrt Karma dboydakid charlieRobinson highwaywarrior The Roadmaster ZEP Z-type billy1290 RidzRiv werdstrave DEMonte1997 97 park ave BMD Jamax crlombardi69 turtleman J. Chris Davis robotennis61 manofmany Derek bullseye-shawn VJD2 brian10962001 Lumenstein98 Ash Eldo texasfan010 Mr.Riviera TonySmooth89 curious riv 97rivsc EASHER Rickw Natesriv '96reese Buapo Joey98riv Fuzzy deekster_caddy albertj Jack the R SpaceBar dreww 1998rivman SilveR AA 1998 Riv jhodges 68 posters |
| Subject: Re: FAQ: Shocks & Struts Options Fri Jul 03, 2015 11:35 am | |
| - Karma wrote:
- Whats the difference left to right? Weird to have a $1.38 difference.
The position of the upper mount and the air fitting. If you tried putting the left on the right (or vice versa) the fitting would be facing forward instead of rearward. I drove the car after installation. They aren't mush at all. When I set the car down, with no air in the system, the car was at normal ride height. I actually think there may be a spring inside. When compressed, it goes right back to fully extended unlike a standard shock that takes a few seconds. | |
| Subject: Re: FAQ: Shocks & Struts Options Fri Jul 03, 2015 3:53 pm | |
| Nice find. They do look like a better quality part.
I've noticed Rockauto's pricing isn't always consistent. The price difference between L/R shocks is coincidental. I think I paid $5 less for my left control arm compared to the right. A month later, the prices could reverse. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
charlieRobinson Expert
| Subject: Re: FAQ: Shocks & Struts Options Fri Jul 03, 2015 4:12 pm | |
| If '07 max -air- like air shocks fit then this airless conversion should fit too? http://www.strutmasters.com/products/2006-2011-buick-lucerne-rear-air-suspension-conversion-kit-cl1rb/ | |
| Subject: Re: FAQ: Shocks & Struts Options Fri Jul 03, 2015 4:28 pm | |
- Nice find. They do look like a better quality part.
Thanks! I took it out of the box and went I didn't even know they existed lol. - charlieRobinson wrote:
- If '07 max -air- like air shocks fit then this airless conversion should fit too?
Yep. Mounting all looks the same from the pics! Lucerne is our exact car underneath. I have quite a few pics of the suspension/underside of Lucernes....basically for my own research. Totally not related, but I think I'm going to get a cradle out of a 3.8L '07 Lucerne. Use the control arms and everything. Very beefy. I just have to measure the track (width) first.[/quote] | |
KnottyEagle Fanatic
Name : Daymon Age : 26 Location : Battle Creek, Michigan Joined : 2014-08-29 Post Count : 284 Merit : 3
| Subject: Re: FAQ: Shocks & Struts Options Sun Jul 26, 2015 12:00 am | |
| Do Oldsmobile Aurora (the first generation) struts fit in these cars? | |
KnottyEagle Fanatic
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 4:32 pm | |
| - KnottyEagle wrote:
- Do Oldsmobile Aurora (the first generation) struts fit in these cars?
I guess we'll find out. They're both G-Bodies, weigh pretty much the same, and are exactly the same length so I'm lead to believe they will. | |
RvieraRider Member
Name : Curtis Age : 41 Location : Atlanta, GA Joined : 2012-07-10 Post Count : 58 Merit : 0
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 4:53 pm | |
| KnottyEagle according to Oriellys the strut assemblies are not the same. The only compatible struts that can be used are from a 98-99 Riviera or a 98-2005 Park Avenue. I hope this helps. I would like to change mine too, I saw a good pair at the yard, I know they are now new, but right now I'm strapped for cash and anything is better than the rusted ones I have.
KnottyEagle Fanatic
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 6:35 pm | |
| The reason I ask is because these ones were basically brand new and I got a deal on them. I have trouble justifying a brand new pair of struts when I'm going to be leaving for awhile without my car. I also need new tires and an alignment, but there's no point in getting either of those when the struts are bad. I suspect they're original, but I can't tell.
EDIT: The junkyard had the Aurora struts compatible with the Riviera, but websites like Rockauto don't have them compatible. I wonder why that would be. Maybe they were compatible from the factory, but aftermarket options aren't? | |
matt270avian Expert
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 6:56 pm | |
| - RvieraRider wrote:
- but right now I'm strapped for cash and anything is better than the rusted ones I have.
From my experiences junkyards usually charge a lot for struts, especially since most don't let you separate them from the springs/top mounts. It might actually be cheaper (or around the same price) for you to buy new struts/mounts and reuse everything else. Right now RockAuto/Monroe has a deal where you buy 4 shocks/struts and get 20% of your purchase price back in a gift card. It comes out to $143.57 plus $39.05 shipping (to my zip code, may vary for yours) for the struts/shocks. You would end up with a gift card worth $28.71. Offer expires 7/31. EDIT: I noticed the admin made a mistake in merging these threads (KnottyEagle's name is shown twice). Admin can feel free to delete this edit after it's fixed. | |
RvieraRider Member
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 7:15 pm | |
| If the struts are from a 97 Aurora then the mount will be different. The mounts are the same for 98-98-2001-2003 model years, according to oriellys the actual struts are not the compatible for any model year of the Aurora.
I have brought struts from junk yards before, not saying that they are best, but they run about 30 bucks for the assembly. Not too bad if your on a tight budget.
matt270avian Expert
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 7:22 pm | |
- but they run about 30 bucks for the assembly.
Around here they go for ~70-90 per assembly at certain yards. ONE yard charges 20/assembly but they specialize in imports, don't have too many American cars. | |
KnottyEagle Fanatic
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 7:41 pm | |
| I got these struts with the top mount and everything put together for $45 each + tax. They're from a 1998 Aurora. | |
RvieraRider Member
| Sorry to hear that. The going rate down hear is about 25 to 30 bucks. But we have a lot of junk yards here. We have 3 pullaparts and several smaller junk yards. I was seeing Rivieras every time I went when I didn't have one, now that I have one. I can't find one. | |
RvieraRider Member
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 7:45 pm | |
| If they are from a 98 the mounts will work, but strut are not the same. It be something as minor as the bolt they used. If you really want to use them the only thing that you can do is just try it and see if it works. Good luck, I hope it works out for you. | |
KnottyEagle Fanatic
| Subject: Re: FAQ: Shocks & Struts Options Mon Jul 27, 2015 7:49 pm | |
- If they are from a 98 the mounts will work, but strut are not the same. It be something as minor as the bolt they used. If you really want to use them the only thing that you can do is just try it and see if it works. Good luck, I hope it works out for you.
I'm not concerned about the strut being different because anything at this point is better than the struts currently on the car. The mount holes look the same and look to be the same distance apart so I think It's worth a shot. | |
KnottyEagle Fanatic
| Subject: Re: FAQ: Shocks & Struts Options Mon Aug 03, 2015 10:17 pm | |
| Well, got around to throwing in the "new old" struts and there's a world of difference. I can actually throw the Riv around in the corners and there's no more obnoxious clunking coming from the front right. Braking feels fantastic now that the car doesn't nose dive. Ride height was raised about an inch on both sides, but I'm sure that was just from the old struts being so worn out. I could actually compress the struts with my hands. One of the coils from the spring had actually broken off too.
I was really worried about the "new" struts making it look like a monster truck, but I'll warm up to the slightly heightened look. I'll take all of the other positives from this job over the looks any day. Now It's time for some new tires and an alignment! | |
brettfavreisamonster Amateur
Name : Huynh Location : LB, CA Joined : 2014-01-17 Post Count : 25 Merit : 0
| Subject: Re: FAQ: Shocks & Struts Options Fri Dec 11, 2015 12:43 am | |
| Hey guys, going to do the struts for the first time in my 97' riv. It has more than 190k on the original struts and tires started blowing chunks at 185k. What do i need? New struts (of course), new strut mounts and what else? what brand of strut mounts do u guys recommend (delco, kyb, monroe, or moog)? what struts do u recommend (delco or kyb)? | |
| Subject: Re: FAQ: Shocks & Struts Options Fri Dec 11, 2015 8:01 am | |
| _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
matt270avian Expert
| Subject: Re: FAQ: Shocks & Struts Options Thu Dec 24, 2015 12:55 pm | |
| Hey guys, just found out something interesting someone can try if they want to be a pioneer. When I was doing the rear shocks in my BMW (2002 325xi Sedan) I tried one of the shocks from my old coilover setup on the Riv, and guess what? They fit almost perfectly! The mounting hole was exactly the same size, the rod was the same diameter, almost the same length, etc. If someone made brackets to mount the bottom of the shock to the control arm (see the coilover thread for examples) pretty much any rear E46 shock should work. Have fun experimenting! I would have no problem shipping a shock or two out to someone who wanted to experiment. | |
| Subject: Re: FAQ: Shocks & Struts Options Thu Dec 24, 2015 2:26 pm | |
| - matt270avian wrote:
- Hey guys, just found out something interesting someone can try if they want to be a pioneer. When I was doing the rear shocks in my BMW (2002 325xi Sedan) I tried one of the shocks from my old coilover setup on the Riv, and guess what? They fit almost perfectly! The mounting hole was exactly the same size, the rod was the same diameter, almost the same length, etc. If someone made brackets to mount the bottom of the shock to the control arm (see the coilover thread for examples) pretty much any rear E46 shock should work. Have fun experimenting! I would have no problem shipping a shock or two out to someone who wanted to experiment.
Thats interesting.I love stumbling across stuff like that | |
| Subject: Re: FAQ: Shocks & Struts Options Wed Jan 27, 2016 11:33 pm | |
| Subject: Re: FAQ: Shocks & Struts Options Wed Jan 27, 2016 11:40 pm | |
Oldschool79 Special
Name : Oldschool79 Location : ILLINOIS Joined : 2016-03-11 Post Count : 3 Merit : 0
| Subject: Re: FAQ: Shocks & Struts Options Fri Mar 11, 2016 3:42 pm | |
Oldschool79 Special
| Subject: will ready struts for a 98 fit a 97 ?? help Fri Mar 11, 2016 3:49 pm | |
| Good afternoon. I am new to the site and am trying to get the hang of it. I am the proud owner of a 1997 Riviera with 62,000 original miles. I have a question about the Front struts. I have been up and down the Internet trying to find ready struts for my 97 . No dice. Dose anyone know where I can get a set of ready struts for my 97? 2nd question will the struts from a 98 Riviera work on a 97? What is the difference between 97 and 98-99 struts? Thanks for your time! | |
| Subject: Re: FAQ: Shocks & Struts Options Fri Mar 11, 2016 4:19 pm | |
| The strut mount on the 97 has different attachment spacing than the 98-99. In addition, the 98-99 uses bolts where the 97 uses nuts. The mount actually has studs. It's a shame because the loaded struts make the job so quick and easy. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: FAQ: Shocks & Struts Options | |
