| code P0300? | |
dreww Junkie
| Subject: code P0300? Mon Feb 16, 2009 12:07 am | |
| So I was driving home and gave it a punch on the highway (pegged the speedo)
During WOT acceleration the trac light and SES light came on (SES light flashing). Got a code P0300. What is that ? Couldnt find it with a search. Is it a misfire. The engine pulled fine
And whats up with the trac light coming on?
Only difference is I saw 5* of KR. I did up my timing just a tad, but I wouldnt think it would cause that much KR. Guess I was wrong. Or is something else up? | |
| Subject: Re: code P0300? Mon Feb 16, 2009 5:36 am | |
| KR number is 'double' what the needed timing reduction is. How much is "a tad"? | |
dreww Junkie
| Subject: Re: code P0300? Tue Feb 17, 2009 12:21 am | |
| - deekster_caddy wrote:
- KR number is 'double' what the needed timing reduction is. How much is "a tad"?
upped it 5% across the entire band. so maybe 1* if that under WOT timing. If I knew what the code is that would help. I will reduce timing back to stock and replace plug wires as mine are still stock at 112K miles. | |
TonySmooth89 Aficionado
| Subject: Re: code P0300? Tue Feb 17, 2009 12:24 am | |
| Looked it up...Random multiple cylinder misfire detected.
How is your fuel pump doing? | |
dreww Junkie
| Subject: Re: code P0300? Sat Feb 21, 2009 12:27 am | |
| - TonySmooth89 wrote:
- Looked it up...Random multiple cylinder misfire detected.
How is your fuel pump doing? to my knowledge it works fine, you can hear it running and its the same volume its always been. How would I know if its going out? Ive read the stock pump is good for 300+ WHP. Im just assuming Im around that point, but Ive never pushed my car as hard as I did the other night, just some WOT runs through 1st and 2nd. | |
BillBoost37 Junkie
| Subject: Re: code P0300? Mon Feb 23, 2009 8:11 am | |
| That code can be from a few different things. Give the reduction a try and see fi that cures it.
If that doesn't the usual suspects are a bad coil, wires and plugs. | |
| Subject: Re: code P0300? Mon Feb 23, 2009 9:04 am | |
| - dreww wrote:
- I will reduce timing back to stock and replace plug wires as mine are still stock at 112K miles.
you are still using stock heat range OEM plugs with your mods? i'd get those and the wires changed asap. then rescan for KR. like tony said p0300 is a random misfire code, the trac light probably came on also because it reads off the engine's timing too. if it misreads then it will turn off. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
dreww Junkie
| Subject: Re: code P0300? Tue Feb 24, 2009 12:41 am | |
| - Mr.Riviera wrote:
you are still using stock heat range OEM plugs with your mods? i'd get those and the wires changed asap. then rescan for KR. like tony said p0300 is a random misfire code, the trac light probably came on also because it reads off the engine's timing too. if it misreads then it will turn off. its not in my sig anymore, but Im using 104's Im pushing a little over 13psi on a cold night so I could go to 103's but doubt thats the issue. I got new plug wires on the way, mine are original with 13 years and 112K miles on them. Thats the first place Im gonna look. ' | |
| Subject: Re: code P0300? Tue Feb 24, 2009 10:36 am | |
| You don't want to run 103s. Not if you drive the car on the street. Let's see what happens with the wires and go from there. Does it come right back after you clear the code? Have you done a case learn? | |
dreww Junkie
| Subject: Re: code P0300? Thu Feb 26, 2009 12:29 am | |
- You don't want to run 103s. Not if you drive the car on the street. Let's see what happens with the wires and go from there. Does it come right back after you clear the code? Have you done a case learn?
the light never came back when I cleared the code, but I also haven't had it WOT down the highway again. Ive never done a case learn on my car - at least not to my knowledge. | |
| Subject: Re: code P0300? | |
| code P0300? | |
