 96 to 97 PCM swap?
4 posters
mrod7510
96 to 97 PCM swap? Empty
PostSubject: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyMon Sep 22, 2008 11:52 pm
I really want to use HP tuners being thats what i already have. HP as you know does not support 96 tried it. Other than 2 wires on C1 and 8 wires in C2 (PCM pinout) all them bieng transmission circuits which the 96 rivs does not have, everything eles is the same . My question is Anyone out there done this? would hate to plug it in and smoke something. OH and yeah my SES light might come on because of the missing trans sensors but who cares.
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyTue Sep 23, 2008 12:21 am
Oldsman105 has done it , but he also updated the transmission too so idk. Since the trans is mostly vacuum controlled , i think you'd be fine on that. As far the SES lights , if its anything like DHP , you can tune out SES codes.
mrod7510
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyTue Sep 23, 2008 12:28 am
Yes sir, you sure can tune it out. I was just reading that thead. and i guess when it comes time to smog it because of the vin number change ill just swap back to my 96 A?
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyTue Sep 23, 2008 12:30 am
Yeah well idk. I think you can change the vin too.
mrod7510
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyTue Sep 23, 2008 12:45 am
Thank you ill let you know how it goes this weekend. Hey tony, why does no one here on this sight talk to much about Nitrous? AS for me im for sure gonna add that 50 shot sitting on my kitchen counter, what do you think? its a wet system. should be okay.
BillBoost37
Merit : 26
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyWed Sep 24, 2008 11:13 am
I gave olds a hand with the swap. It's cake. And sets you up in case you want to change the trans in the future.
Easy way would be to get a bin from something like a 97 bonne NA for most of the trans parameters, then tweak the shift speed and pulses per mile.
mrod7510
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyThu Sep 25, 2008 12:45 am
the PCM from the 97 I had my eye on in the junk yard of course is gone now. what luck so if anyone has one ill buy it? ebay wants vin number to flash and it over 70 bucks. so
BillBoost37
Merit : 26
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyThu Sep 25, 2008 9:36 am
You should be able to have anyone with a DHP reprogram either a 96 or 97 for you.
Its a car part now
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptySun Feb 01, 2009 2:11 pm
So a ebay '97 pcm would work in '96, if extra wires are just not hooked up and codes removed with Hptuner?
Any problem from anti-theft?
I have a friend that wanted to go 50/50 on hptuner till we found it would not work on '96
mrod7510
PostSubject: Re: 96 to 97 PCM swap?   96 to 97 PCM swap? EmptyWed Mar 11, 2009 12:39 am
Update, 97 PCM idea in a 96. Well I did try it and plug it in, everything worked fine...... untill i drove it, only first and second gear. so without maybe piggy backing PCMs or swapping transmissions wont work. Im sure someone already knew that, im so hard headed. My HP tuners sucked the tune out but no good with only two gears. Okay the good news.. our new employee has TUNER CAT smile i bought a credit and BAM!! 1996 RIV now being tuned. will report my progress, also now installing my 3.10 pulley (Currently have 3.4) and a meth kit. Great right? Granny Riv with a blower,Nitrous,and Meth..
96 to 97 PCM swap?
» Aurora/other V8 engine swap?
» Write-Up: L32 (Series III SC) Install/swap, the saga continues
» Will the power antennae off a 95 PA fit my 99Riv?
» L36 top swap
» PCM swap
