| NEED HELP!!!! torque converter clutch stuck on :( | |
ericde Enthusiast
| Subject: NEED HELP!!!! torque converter clutch stuck on :( Mon Feb 23, 2009 9:12 pm | |
| I have a 2001 regal gs an im pulling a code P0742 i didnt notice any problems when i first got the code but now my cars shifting an not shifting at all need to see if any one has any knowledge on these trans please help | |
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Mon Feb 23, 2009 11:12 pm | |
| what happened to your red/chrome riv?
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Tue Feb 24, 2009 6:44 am | |
| I had the same problem. It means there is crud stuck in the valve body, causing the TCC solenoids to get stuck on or off. P0741 means TCC is stuck off, P0742 means TCC is stuck on. P0742 is the worse of the two because it probably means your trans is bucking as it downshifts, trying to deal with the torque demand of staying locked in overdrive. It may stall even. This could damage your trans if left unchecked, and in my case, the problem did not work itself out. It was really stuck. My transmission mechanic had to replace the valvebody to fix this problem. I think he dropped the unit to do it, but I've heard you can swap (or at least access) the valvebody on some cars without removing the entire transaxle. If you know someone with a Tech II, there may be a way to energize the TCC solenoid, maybe get it unstuck. I've heard of this being done, but it was not done to my car, and I do not know the procedure for doing it correctly. Good luck, feel free to read through my experience here: https://rivperformance.editboard.com/series-ii-engine-transmission-f4/diary-of-a-dying-transmission-t1594.htm_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BillBoost37 Junkie
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Wed Feb 25, 2009 3:52 am | |
| Do you have any other codes as well? | |
ericde Enthusiast
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Wed Feb 25, 2009 7:16 pm | |
| thanks AA my trans just started this an just started slipping but me an my dad opened the valve body an are going to replace the clutch converter hope that will do the job an oh yeah the rivs my moms car i ended up getting a regal | |
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Wed Feb 25, 2009 7:20 pm | |
| If you can replace the clutch solenoids, or at least move them on & off, that might fix the problem. Best of luck! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
ericde Enthusiast
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Thu Feb 26, 2009 10:34 am | |
| thanks going out in the shop today ill let you know what happens | |
ericde Enthusiast
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Thu Feb 26, 2009 12:43 pm | |
| does any one know how to take the c-clip off of the tcc solienod | |
ericde Enthusiast
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( Thu Feb 26, 2009 12:58 pm | |
| just got it off !will not me but my dad did.doesnt look like its plugged at all hope this is the issue thats throwing the code:( will its all finshed seems to be shiffting great:) just imagine if i took it to the shop it would have been like a 800 dollar fix an thye probably would have had me replace a bunch of other junk that i didnt even need glad i got a dad who knows about cars | |
| Subject: Re: NEED HELP!!!! torque converter clutch stuck on :( | |
