 intermittent hard steering
14yearownerof95riv
Merit: 0
PostSubject: intermittent hard steering   Wed Mar 04, 2009 3:33 pm
my son just called and said the 95 riv steering tighened up on him a couple of times today. any ideas on what I should check for other than fluid when I get home tonight? thanks
Merit: 172
PostSubject: Re: intermittent hard steering   Wed Mar 04, 2009 3:50 pm
To start: check serpentine belt and pulleys. Listen to power steering pump for noise, check power steering fluid level.
- John R. White, Boston Globe
14yearownerof95riv
Merit: 0
PostSubject: Re: intermittent hard steering   Wed Mar 04, 2009 3:53 pm
will do. thanks for the help
» intermittent hard steering
» Hard steering to the left K100RS
» Knocking noise when pulling away hard. any ideas??
» Hard horn button on the steering (on Logan with airbags)
» K100 steering heavy
