 I am guessing this is not the stock antenna...
NO 4 EVR
Merit: 1
PostSubject: I am guessing this is not the stock antenna...   Sun Mar 25, 2007 7:40 pm
Roadworks? Is this what GM put in here?
The reception on the radio sucks and sometimes the antenna does not come up at all.
The whole thing is being held up by some weak ass erector set bar I can bend with a finger:
At least my bonneville had a very sturdy angled bar that held things in place. Does anyone have a pic of this area or can confirm that this is right/wrong?
How much does a new factory antenna cost?
NO 4 EVR
Merit: 1
PostSubject: Re: I am guessing this is not the stock antenna...   Sun Mar 25, 2007 8:02 pm
Water leaks in because I think this is not the proper assembly. I fixed it the best I could but its not a perfect fit.
Anywhere I can get a working used one?
SilverArrow102
Apprentice
Merit: 1
PostSubject: Re: I am guessing this is not the stock antenna...   Mon Mar 26, 2007 6:05 am
Nope, not the stock antenna assembly. I recently had to replace mine as the core rod broke. I bought an aftermarket model similar to the one pictured and it broke within 2 weeks of installing it. Claimed to be universal for fit but needed the "erector set" bracing. Was NOT impressed. I located a used but working antenna assembly from an Aurora. It's identical to the Riv antenna. The mounting bracket for the Aurora is different than the Riv though so make sure you get the right bracing.
http://home.kc.rr.com/mirage/
SoCal Riv
Merit: 0
PostSubject: Re: I am guessing this is not the stock antenna...   Tue Mar 27, 2007 11:25 am
Mine stopped functioning when it was under warranty, and the dealership replaced it with a factory new one. However, the new one was not like the old one as GM had superseded the replacement. It still works well, but it does not have the girth, and the visual quality of the original antenna.
Merit: 4
PostSubject: Re: I am guessing this is not the stock antenna...   Wed Apr 04, 2007 3:30 am
Does anyone have a GM part number for the power antenna assembly?
Merit: 4
PostSubject: Re: I am guessing this is not the stock antenna...   Wed Apr 04, 2007 1:01 pm
Power Radio Antenna Module
GM p/n:
88891021
List price: $193.80
crazy
$100 on gmpartsdirect though.
» looking for a mini stock for rent
» Genuine Magpul UBR stock for m4 in black
» ShopNBC, Sans Host Jim Skelton, Floats Stock Offering
» Presentation Folders Printing At Cheap Rates on 100lb/80lb Card Stock
» I am guessing this is not the stock antenna...
