| Write-Up: How to Remove/Install SC Pulley | |
+28deekster_caddy Colten225 Karma SCbuick010 Eldo robotennis61 Abaddon Rickw robertwolf86 Jack the R TonySmooth89 Buapo BoattailBob 98riv65lark SpaceBar 1998 Riv 1998rivman Mr.Riviera TType_Riviera turtleman AA Jason NO 4 EVR 98riv SoCal Riv pwmin urbsnspices T Riley 32 posters |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Thu Jan 24, 2013 3:00 pm | |
| - charlieRobinson wrote:
- LARRY70GS wrote:
- T50. I hope you realize that changing the belts on these cars is a bit involved unless you have cut the lower spacer in half.
Go on... https://rivperformance.editboard.com/t725-write-up-replacing-belts-and-pulleysBasically, the motor mount and engine bracket gets in the way. The bracket is fastened to the engine by 3 studs/nuts, and 2 spacers. The first time you do this requires unbolting the mount and lifting or dropping the engine so you can get the stud and spacer out. The stud hits the frame otherwise, and you cannot get the spacer off the stud. If you cut the spacer in half, you can back the stud out enough to drop out half the spacer, giving you room to squeeze the belt through. Read the linked write up. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
charlieRobinson Expert
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Thu Jan 24, 2013 3:04 pm | |
Basically, the motor mount and engine bracket gets in the way. The bracket is fastened to the engine by 3 studs/nuts, and 2 spacers. The first time you do this requires unbolting the mount and lifting or dropping the engine so you can get the stud and spacer out. The stud hits the frame otherwise, and you cannot get the spacer off the stud. If you cut the spacer in half, you can back the stud out enough to drop out half the spacer, giving you room to squeeze the belt through. Read the linked write up. Wow. How naive am I?! Should I take this opportunity to replace pulleys too? Dammit, I thought this was going to take the T50 socket and 5 minutes!!!@ RARAWRARR! | |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Thu Jan 24, 2013 3:11 pm | |
Basically, the motor mount and engine bracket gets in the way. The bracket is fastened to the engine by 3 studs/nuts, and 2 spacers. The first time you do this requires unbolting the mount and lifting or dropping the engine so you can get the stud and spacer out. The stud hits the frame otherwise, and you cannot get the spacer off the stud. If you cut the spacer in half, you can back the stud out enough to drop out half the spacer, giving you room to squeeze the belt through. Read the linked write up. Wow. How naive am I?! Should I take this opportunity to replace pulleys too? Dammit, I thought this was going to take the T50 socket and 5 minutes!!!@ RARAWRARR! I would. The first time you do this is the worst. After that, not so intimidating. You can easily replace 3 of the pulleys. It's the 4th one down low that is blocked by the bracket. Murphy's law says that's the one that will start squealing after you do the belts. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Thu Jan 24, 2013 3:23 pm | |
| Dammit, Murphy! You're right. I should replace all the pulleys. 142k miles and I hardly doubt they've been replaced before.
Wait, this crazy drop the engine belt change is for the alternator belt, right? I am doing the supercharger belt...
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Thu Jan 24, 2013 5:15 pm | |
- Wait, this crazy drop the engine belt change is for the alternator belt, right? I am doing the supercharger belt...
Both belts. Sorry Charlie _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Thu Jan 24, 2013 11:58 pm | |
| - Quote :
- Dammit, I thought this was going to take the T50 socket and 5 minutes!!!@ RARAWRARR!
Haha! Enjoy. I'm on my 3rd set of belts! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Fri Jan 25, 2013 3:38 pm | |
- Quote :
Haha! Enjoy. I'm on my 3rd set of belts! GOB BOBBIT! It's too cold to be doing crazy shit like this for a belt swap!!!@#!@! WHY GM!?! WHY!?! | |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Mon Jan 28, 2013 9:50 am | |
- yo yo yo. I put my 3.6" on yesterday and now I have some nasty belt chirping going on. At first I suspected it was some SC oil that must have dripped on it after cracking the snout off but now im not sure. It wasn't making any noise before I put the new pulley on. I figured if it was just oil then it would fix itself by now and it hasnt.
Any tips from the pros? Do I just get a new belt or am I missing some obvious like usual?
Moved my belt from the middle ribs to the outside ribs and BLAM! No more chirp. ZZP MPS, by the way. | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 37 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
| Subject: temp Sun Aug 17, 2014 1:37 pm | |
| I need help, my mps, the s3 does not have the bolt in the middle just a threaded hole in the middle. the two part puller is bending my pulley up and I don't want to ruin anything | |
Johnny5 Fanatic
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Tue Aug 19, 2014 7:31 pm | |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Tue Aug 19, 2014 8:56 pm | |
| What kind of puller are you using?
If the pulley is hard to come off, you can heat it up with a heat gun. Just don't heat the S/C itself...just the pulley | |
Johnny5 Fanatic
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Tue Aug 19, 2014 10:18 pm | |
| Im renting matt07 puller from him but I had a two jaw puller but the pulley is getting bent out of shape...and the series III sc dont have a bolt in the middle of the pulley itself its a plastic tab and a threaded center...how do I bolt the mps on if it's nothing there to bolt on too | |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Tue Aug 19, 2014 10:42 pm | |
| The mps doesn't bolt on. The hub is just pressed on like the pulley is. You'll use that threaded hole with the tool to press it on. That threaded hole is only there for pulley installation, not to hold it on. | |
Johnny5 Fanatic
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Wed Aug 20, 2014 9:14 am | |
| Ok thanks dont got a lil worried that's all don't want to mess up my big supercharger over something little | |
Karma Aficionado
| Subject: Re: Write-Up: How to Remove/Install SC Pulley Wed Aug 20, 2014 9:25 am | |
| Yup, you can't use a jaw puller on any of the m90 scs. M62 is keyed with a bolt on the end, all m90s are press on. Hopefully you didn't pull the pulley too far bent with the 2 jaw, or its going to be a PITA with the proper puller. To pull off properly it needs to be supported across the back so it pulls straight. Jaw pullers, even 4 jaw will mangle it.
And when using the threads in the snout to squeeze the MPS hub on, be sure that whatever you are screwing in there has nice clean threads. _________________ | |
| Subject: Re: Write-Up: How to Remove/Install SC Pulley | |
