 Write-Up: How to Remove/Install SC Pulley
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Tue Apr 06, 2010 6:52 pm
I guess i shouldn't post in this thread either.?
Merit : 171
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Tue Apr 06, 2010 8:21 pm
Huh? scratch
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Tue Apr 06, 2010 8:25 pm
Big Red Flag where I posted last.
I thought I pissed someone off again.
Merit : 239
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Tue Apr 06, 2010 10:09 pm
Hmm... maybe someone didn't agree with your info?
'98 SC Riviera • 280k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30
^^^ RIV IS FOR SALE! ^^^
'05 GTO • 49k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26
'95 Celica • 150k miles • 0-60: yes
Merit : 122
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Wed Apr 07, 2010 12:17 pm
SCbuick010 wrote:
Can you remove the stock pulley and install another press-on pulley with the supercharger still on the car?
It depends on the year of the engine.
1995 - NO, you have to remove the SC
96-99 - Yes
No reason to take the SC off for 95 to change the pulley. (you might have been thinking the coupler). The m62 from 95 is keyed, so its easy on and off with a normal pulley puller.
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Wed Apr 07, 2010 10:43 pm
I guess i do deserve the Big Red Flag after all.
I was indeed thinking about the requirement of replacing the coupler not the pulley.
My Bad, I hope I didn't cause any unnecessary labor for you Bryan.
Colten225
PostSubject: Replacing supercharger pully   Fri Mar 02, 2012 8:24 pm
I have a 96 rivi and I'm looking at purchasing a 3.5 pully to replace the OEM and replace the thermostat, and possibly some cooler spark plugs. But I was wondering how difficult it would be to replace the pully, and if I could do it on my own.
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Fri Mar 02, 2012 10:06 pm
You will require a pulley puller tool made specifically for this process. Your best bet may be to find someone with a tool near you and have them help you with the swap.
I would recommend installing an MPS and a larger pulley to start. Most pulley swaps have a lot of KR, even a lot of stock motors have KR.
Where are you located?
Colten225
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Fri Mar 02, 2012 10:15 pm
So maybe like a 3.6. And I'm in lincoln, ne, probably no one around me with one of those tools
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Sat Mar 03, 2012 7:06 pm
Check clubgp.com. There are GP clubs all over the place, you may be able to find someone local.
Also, here's someone on this board selling a puller!
http://rivperformance.editboard.com/t9090-fs-brand-new-35-zzp-mps
Colten225
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Fri Apr 27, 2012 10:24 am
damn. I wish i saw that earlier, looks like its already sold
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 11:18 am
yo yo yo. I put my 3.6" on yesterday and now I have some nasty belt chirping going on. At first I suspected it was some SC oil that must have dripped on it after cracking the snout off but now im not sure. It wasn't making any noise before I put the new pulley on. I figured if it was just oil then it would fix itself by now and it hasnt.
Any tips from the pros? Do I just get a new belt or am I missing some obvious like usual?
Merit : 239
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 11:29 am
Make sure you're using the correct grooves on the new SC pulley:
http://rivperformance.editboard.com/t971-intense-vs-zzp-sc-pulleys
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 12:29 pm
How's the belt tension? Did you replace the belt at the same time or just reuse your old belt?
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 2:10 pm
I am using ZZP pulley with my old belt. old but good condition. The belt sits in the middle of the grooves with 1 on each side of the belt. It's nice and straight. Tension is also fine. The only thing I can think of is oil on the belt from the SC oil change but i dont think it would make these sounds. CHIRP CHIRP CHIRP CHIRP SHUT UP!
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 2:46 pm
After my car sits I get a belt chirp from the SC belt and have brand new belts. A couple shots of WD-40 at the tensioner pulley gets rid of the sound until the next time it sits!
Merit : 239
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 3:02 pm
When you spray WD40, you're lubricating the belt, which stops the noise. This indicates a belt/pulley alignment issue. Check none of your pulleys are loose or wobbly. Spraying water will do the same thing. If the noise gets louder when you spray, it indicates a belt slip issue.
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 3:04 pm
Ahhh, thanks AA, I will definitely check on that!
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 3:10 pm
Ditto. P.S. Dave, the paint on your Riv is real niceee. Have I told you that already? cyclops
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 3:34 pm
The problem with WD-40 is that in addition to a little bit of lubricant you are also spraying a lot of penetrant and solvent. That can wash out the OE bearing grease and replaces it with a very light lubricant that won't last long. Use straight silicone spray instead, unless you specifically need to penetrate or dissolve something (rusty/dirty etc). WD-40 is great for cleaning and lubricating ratchet heads, for example... but not what you should spray on a bearing.
edit - I should read more thoroughly. You definitely don't want to lubricate the belt! It's most likely the bearing squeaking.
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 4:34 pm
Thanks Charlie! happy im sure my dad loves reading the compliments too!
And Is there anything that can be done to keep the belts from cracking thats safe for the bearings on the pulleys??
Merit : 239
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Mon Jan 14, 2013 7:15 pm
Change the belt. A new belt should last 90-100k miles without any special maintenance.
I agree with deekster on the wd40. if you're going to spray anything on the belts, use water only. This is actually the recommended procedure for troubleshooting belt noise - from Gates and Dayco.
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Thu Jan 24, 2013 2:07 pm
Just got that 4060720 Gatorback belt in the mail today. I am at the office and I want to get it on before I drive home. Anyone know what size torx socket the tensioner pulley needs?
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Thu Jan 24, 2013 2:51 pm
T50. I hope you realize that changing the belts on these cars is a bit involved unless you have cut the lower spacer in half.
PostSubject: Re: Write-Up: How to Remove/Install SC Pulley   Thu Jan 24, 2013 2:52 pm
Go on...
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» Write-Up: How to Remove/Install SC Pulley
» Write-Up: Northstar Throttle Body Install
» Shop Tools Explained
» Dr. Pully sliders installed
» Write-Up: How to install an aftermarket SC pulley (Series I)
