 Gauges, Odometer, Climate Control No Longer Working
GMFreak8
GMFreak8
Merit : 15
Gauges, Odometer, Climate Control No Longer Working Empty
PostSubject: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyTue Mar 17, 2009 7:01 pm
Ok, so I go out to start fixing some of the issues with the Riviera. First thing (which I thought would be the easiest) was to reprogram the remote for the doors. Well I jumped 8 and 4 on the OBD!! like in the directions. Nothing happens. I made sure that they were the right pins. Now I notice the doors will not lock when the button is pressed, the climate control only displays C and F for Celsius or Fahrenheit, and the gauges no longer function nor does the odometer come up. The dash gets lights, just nothing is functional. Did I blow a fuse or do something else to screw things up? Not really sure what I could have did. Any help would be greatly appreciated.
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyTue Mar 17, 2009 10:14 pm
Lol Same thing happened to me when i tried it too!
Its a blown fuse. But i don't remember which one.
I ended up going to the dealer and got it programmed for like 40 bucks or something later.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyTue Mar 17, 2009 10:31 pm
So it wasn't a fried computer or anything? What exactly was reprogrammed if it was just a blown fuse though? I went through every fuse I could find on the drivers side fuse panel and both fuse and breaker boxes under the rear seat and didn't find one fuse or breaker that needed to be replaced. Am I missing a fuse location?
I fixed a few things and broke about ten other things or so it seems. lol
Any additional details on what the dealer did to fix it would be greatly appreciated. happy
Merit : 154
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 4:10 am
there is small fuse panel in the engine compartment...
wonder if anyone is selling a Tech II cheap.
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 10:48 am
Actually my neighbor specializes in auto electric , and he fixed it for me , so i have no specifics on what fuse it was exactly.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 12:47 pm
As long as it's just a fuse, I can find it. I just don't want to put $200 into a new computer. lol Thanks for easing my mind. smile
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 12:52 pm
Lol no problem. I freaked out quite a bit myself when it happened.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 2:28 pm
You wouldn't happen to be able to walk over to your neighbors and ask him exactly what he did? I've gone through every fuse box I can find and nothing is blown. I did both the boxes under the seat, the fuse panel on the drivers side, and the fuse panel in the engine compartment. Nothing whatsoever wrong with the fuses. If you could find out a little more detail on exactly what he did I would truly appreciate it. Thanks.
Merit : 154
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 6:58 pm
You might be looking for a busted wire. Does your car have aftermarket alarm, remotestart or radio? Start there.
Hey folks - Is it possible there's a fusible link involved?
manofmany
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 7:52 pm
Do you have a test light? You could hook that up and test the fuses. Alternatively, the manual should say which fuse is responsible for operating the gauges.
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 8:35 pm
It sounds to me like you did something other than a fuse...
On my wifes 99 I blew the fuse that controls the climate control and it would not lite up at all. Yours is displaying some data...no idea what could be your problem.
If it were me I guess I would try removing the batt. cable for a while and see if that helped. no
Bert tavis
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyWed Mar 18, 2009 8:49 pm
I gave up. I went over every thing electrical that I could think of and didn't find anything. I'm just going to bite the bullet and pay the local buick dealer $68 an hour to find my screw up. I guess you live and learn. I'll definitely never try to reprogram a keyfob again on the Riviera. oops I will let everyone know how things go and what it was. Unless of course Tony can convince his neighbor to post here. wink
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyThu Mar 19, 2009 12:33 am
He probably wouldn't remember but i'll try if i can find him home at a reasonable hour.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyThu Mar 19, 2009 4:54 pm
Alright let me know either way. I don't have an appointment with the stealership until the 24th, so if he can remember in the mean time it would definitely save me some cash.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptySat Mar 21, 2009 12:59 pm
Any update on your neighbor? lol
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptySat Mar 21, 2009 11:25 pm
No haven't had much time between work and my brothers wife giving birth to a beautiful set of twins i haven't been able to run over there. I work tommorow all day but if i run into him i'll ask.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptySun Mar 22, 2009 1:37 pm
Alright, let me know if you do hear anything.
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptySun Mar 22, 2009 1:44 pm
You did try removing the batt. cable for a while...just in case?
Bert tavis
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptySun Mar 22, 2009 3:27 pm
Bert tavis
Yup, didn't do a thing. I left it removed for a good 10 minutes.
Merit : 154
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyTue Mar 24, 2009 3:53 am
About that fuse - did you just check visually or did you use a tester (those Littelfuse or Buss LED gadgets). Reason I ask is that sometimes - not very often - a fuse blows such that it looks OK visually but actually is blown, can;t tell without actually testing.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyFri Mar 27, 2009 3:29 pm
Well apparently it was two separate fuses under the rear seat that blew. So you were right albert, apparently it was just blown enough to make it hard to detect it visually. Now I have a problem with my rear driving lights not going off...
Merit : 154
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyFri Mar 27, 2009 9:31 pm
you are welcome.
voice of experience.
Merit : 154
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyFri Mar 27, 2009 9:32 pm
rear driving lights or rear brake lights? Probably you have a bum brake switch or a short - but we need more detail.
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyFri Mar 27, 2009 9:43 pm
Quote:
It's me again. Yesterday everything was working great in the car. Today I go out and I notice my tail lights look like they are on. I figured it was the sun so I try to start it just to make sure. Sure enough I had a dead battery. Upon closer inspection the rear lights are constantly on. It's separate from the brake lights, it's the actual driving lights that are stuck on. I thought maybe it was the brake light switch, but that rules that out. Has anyone experienced this or does anyone know where I could look to locate an issue with this? Thanks for any help in advance. Kyle.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Gauges, Odometer, Climate Control No Longer Working   Gauges, Odometer, Climate Control No Longer Working EmptyFri Mar 27, 2009 11:13 pm
It's the rear driving lights. When stepping on the brake the third brake light lights up and the separate brake lights within the tail light assembly come on. Letting up on the brake shuts the lights off. The regular driving lights will remain on until the battery dies.
» Micron Radio Control
» Transaxle stopped working out of nowhere
» DragonFire Racing UTV gauges
» Working overtime again
» control lines
