| Author | Message |
98riviera98 Aficionado
Name: Travis Age: 22 Location: Passing you Joined: 2007-02-08 Post Count: 4773 Merit: 7
 | Subject: Turn Signals don't work Thu Mar 19, 2009 1:26 am | |
| -My four way hazards work! and they flash -My brake lights work -ALL the exterior and interior lighting fuses are GOOD
could it be the flasher itself? |
deekster_caddy Guru
Name: Derek Age: 40 Location: Reading, MA Joined: 2007-01-31 Post Count: 6091 Merit: 83
 | Subject: Re: Turn Signals don't work Thu Mar 19, 2009 6:40 am | |
| More likely the multifunction switch  |
Name: Aaron Age: 34 Location: C-bus, Ohio Joined: 2007-01-13 Post Count: 14467 Merit: 172
 | Subject: Re: Turn Signals don't work Thu Mar 19, 2009 12:26 pm | |
| Try changing the flasher unit first. The multifunction switch costs 100x as much and takes 10x as long to install. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
"I think that in any racing engine, the nearer you are to disintegrating, in general the better its performance will be." - Keith Duckworth, Cosworth Engineering
3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco F/Rsway bars • ES links/bushings • GM strut brace • Enkei 18" EV5s • Dunlop DZ101 tires F-body calipers • EBC bluestuff/Hawk HP plus • SS lines • slotted discs • ATE superblue fluid • DHP tuned • Aeroforce • Hidden Hitch
 | Subject: Re: Turn Signals don't work Thu Mar 19, 2009 3:42 pm | |
| | AA wrote: | | Try changing the flasher unit first. The multifunction switch costs 100x as much and takes 10x as long to install. |
so to do the flasher unit do i unscrew that plastic piece under the steering wheel??? and where do i get a flasher unit? |
 | Subject: Re: Turn Signals don't work Thu Mar 19, 2009 4:41 pm | |
| Yes, take out screws, pull down plastic panel, flasher is silver thing that looks like this:  Sorry, I mean like this:  Get it at any auto parts store. I think it's around $5-$10. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
 | Subject: Re: Turn Signals don't work Thu Mar 19, 2009 9:08 pm | |
| DAMN i can't pull it out.. its in there PRETTY GOOD... |
 | Subject: Re: Turn Signals don't work Thu Mar 19, 2009 11:30 pm | |
| DUDE... AA your a lifesaver THANK YOU VERY MUCH... it was the flasher  although.. there is TWO flasher up there.. its the one with the red end thing on it.. ugh that was confusing.. anyway THANKS for the help A LOT |
 | Subject: Re: Turn Signals don't work Fri Mar 20, 2009 8:12 am | |
| The other one is for the hazards! _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
 | Subject: Re: Turn Signals don't work Fri Mar 20, 2009 1:27 pm | |
| | AA wrote: | | The other one is for the hazards! |
i figured that much out  |
texasfan010 Member
 | Subject: blinker help Wed Jun 17, 2009 4:09 pm | |
| when i go to turn on my left blinker the cornering light lights up but the turning signal doesnt work. the left arrow light inside my car is also stuck lit up. the right signal and the hazards work fine. what do i do to fix this? thanks |
 | Subject: Re: Turn Signals don't work Wed Jun 17, 2009 4:10 pm | |
| It is odd that only one side works. Could be something in the multi-function stalk. You could try replacing the turn signal flasher under the dash. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
L67 Fanatic
Name: Matt Joined: 2007-06-05 Post Count: 1115 Merit: 37
 | Subject: Re: Turn Signals don't work Wed Jun 17, 2009 4:51 pm | |
| | texasfan010 wrote: | | when i go to turn on my left blinker the cornering light lights up but the turning signal doesnt work. the left arrow light inside my car is also stuck lit up. the right signal and the hazards work fine. what do i do to fix this? thanks |
My car did this as well, the arrow would stay lit up and not flash on the dash. Change the bulb in the taillight and your problem should be solved. Although it is strange that your hazards still work, I never tried mine while experiencing that problem. |
Rickw Expert
Name: Rick Age: 53 Location: Lancaster, MA Joined: 2008-09-13 Post Count: 5957 Merit: 96
 | Subject: Re: Turn Signals don't work Wed Jun 17, 2009 5:33 pm | |
| 99.9% of the time it is a burned out bulb. Turn key on and turn signal lever to left and check front and back to find bad bulb. The reason the hazards work is they are on the brake light circuit. Different filament. |
texasfan010 Member
 | Subject: Re: Turn Signals don't work Wed Jun 17, 2009 5:53 pm | |
| with the left signal on i can see the front or back flashing. so how do i find the bad bulb? |
