 Battery Location/Relocation????
mayfair4life187
PostSubject: Battery Location/Relocation????   Sun May 13, 2007 6:36 pm
i know this might sound silly. Where the hell is my battery located in my 96 riv SC?????????????? can anyone help me out?
gosloriv
PostSubject: Re: Battery Location/Relocation????   Sun May 13, 2007 6:45 pm
under ur rear seat !!!!!
PostSubject: Re: Battery Location/Relocation????   Mon May 14, 2007 9:36 am
Hah I had the same problem when I first got the riv. I first tried the hood. Then searched all through the trunk. Finally i popped up the back seat about 40 minutes later and found it. wink
Audio72
PostSubject: Re: Battery Location/Relocation????   Fri Sep 05, 2008 1:38 am
Hi,
Great forum. Just got me 95 Riv. OK, so it's in the rear seat. How do you get to it?
Thanks,
Audio72
PostSubject: Re: Battery Location/Relocation????   Fri Sep 05, 2008 2:13 am
Audio72 wrote:
Hi,
Thanks,
Audio72
ok
Step ONE: pop hood
Step TWO: realize there is NO battery there
Step THREE: pull up on the back seat at the front edge Pretty firmly it will take some force
Step FOUR: THERE LIES THE TROUBLED BATTERY
PostSubject: Re: Battery Location/Relocation????   Fri Sep 05, 2008 10:53 am
i had that problem when i first got mine im like some one stole the f 'n battery then i realized there wasnt a place for it under the hood so i searched
http://www.Chitownracing.com
PostSubject: Re: Battery Location/Relocation????   Fri Sep 05, 2008 6:11 pm
LOL I did the same thing! I looked under the hood and was like WTF? Then I remembered my friends olds aulora had it under the seat so I looked and bam there it was! LOL
Audio72
PostSubject: Re: Battery Location/Relocation????   Sat Sep 06, 2008 1:29 am
Found it! smile
Thanks
Dad
PostSubject: Battery Location????   Tue Mar 24, 2009 9:37 pm
Help! My daughters Rivera is dead in my driveway. She had it towed to my house for repair??? I'm new to Riveras and cant find the battery. I think it's a 95 or 96 with a3.8 L Supercharged six. I'm not new to mechanics, I have a 4.OL Jeep that I have replaced both front and rear axels, transmission and transfer case etc.and a Corvette that I do my own work on. If I can charge the battery I'll have a chance to try and trouble shoot the problem with your help.
Ironclad-454
PostSubject: Re: Battery Location/Relocation????   Tue Mar 24, 2009 9:44 pm
Its under the backseat.
oh and welcome.
Dad
PostSubject: Re: Battery Location/Relocation????   Tue Mar 24, 2009 10:23 pm
Nate!! thanks, I found it!!!
She tells me It died on the freeway? some help huh, I'm giving it a 1/2 hour of so to charge up, then I'll give it a try. I'll get more specifics later this evening or tomorrow around this time. I'll check spark and fuel tomorrow. I can hear the fuel pump(very noisy) pressure up then stop. Where is the OBD II connector located?
96riv
PostSubject: Re: Battery Location/Relocation????   Tue Mar 24, 2009 10:38 pm
If it is a 96 it is under the drivers dash about half way to the firewall.
http://www.arizonagn.com
Ironclad-454
PostSubject: Re: Battery Location/Relocation????   Tue Mar 24, 2009 10:50 pm
You are welcome. If it died on the freeway and the battery is dead then I'd look at the alternator.
curious riv
PostSubject: Re: Battery Location/Relocation????   Wed Mar 25, 2009 8:04 am
Welcome! and when I turn my key- the air compressor in the back is fairly loud. When I first got my Riv I thought it was the fuel pump
PostSubject: Re: Battery Location/Relocation????   Wed Mar 25, 2009 8:58 am
Good luck!
Dad
PostSubject: Re: Battery Location/Relocation????   Thu Mar 26, 2009 11:28 pm
I'd like to thank everyone who responded, but she done gone and did it this time. bonk
I put a 1/2" drive ratchet with a 2 foot extention on the crank bolt and couldn't turn it over. nono
Looks like she siezed it up.
Whats the market for a 95 in good condition inside and out., or would a new engine be more reasonable?
PostSubject: Re: Battery Location/Relocation????   Thu Mar 26, 2009 11:45 pm
Used decent condition should be around $500-$600, check car-part.com for localized listings...
Dad
PostSubject: Re: Battery Location/Relocation????   Fri Mar 27, 2009 8:02 am
Thanks Derek, I guess it would be worth more in parts, if you'd want to sit on it for a few months?
PostSubject: Re: Battery Location/Relocation????   Fri Mar 27, 2009 11:29 am
Sorry, I was talking about a used engine should cost you $500-$600, not that's what the car was worth. I think it's worth putting an engine in, if it's in nice enough shape...
Merit : 131
PostSubject: Re: Battery Location/Relocation????   Fri Mar 27, 2009 9:35 pm
Yep. *if you shop for it* used engines are plentiful for the 3800. If you are in a major metro area you just *might* find a place to put it in for you and everything...
Merit : 102
PostSubject: Re: Battery Location/Relocation????   Thu May 14, 2009 3:05 pm
One of the heavy modders around here could tell you how much is involved to "improve on the original", possibly just the matching PCM, but right now there is an almost complete Series II in the For Sale thread...
http://rivperformance.editboard.com/for-sale-f22/series-ii-supercharged-engine-for-sale-update-pictures-t5440.htm
Regardless, good luck with everything...
sall
PostSubject: Battery Relocation   Wed May 14, 2014 7:55 pm
Anyone ever relocate the battery in their Riv to trunk? The battery under the backseat is huge PITA when you have a little one in a car seat. I mod a lot and disconnect battery frequently. Curious to see build pictures. Thanks.
Merit : 49
PostSubject: Re: Battery Location/Relocation????   Wed May 14, 2014 8:28 pm
I haven't, but I bet under the carpet by the antenna would be a near perfect spot for one.
sall
PostSubject: Re: Battery Location/Relocation????   Wed May 14, 2014 8:39 pm
I wonder where the best ground location would be back there. Planning to do a big 3 upgrade eventually can always plan to run it to the rear and test some locations. Just looking to see if anyone has done successfully!
Merit : 49
PostSubject: Re: Battery Location/Relocation????   Wed May 14, 2014 10:36 pm
There are a few existing chassis grounds by the antenna, but you should be fine running a ground wire back (it's under the right side of the back seat about 1ft away from the battery IIRC). I don't see any harm in running some nice 0 gauge wire back to the factory location, but I'm not an expert and I don't do this for a living.
