 how to remove plastic splash guard to get to fenderwell
97rivsc
97rivsc
how to remove plastic splash guard to get to fenderwell Empty
PostSubject: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 9:25 pm
I did my fenderwell intake without removing the plasticy material above the wheel, and was wondering how do you guys pull out the little tabs, I tried to get one out with a flathead screwdriver, and accidentally broke one of them off with it still holding the plastic in place.....
https://www.facebook.com/album.php?aid=2007661&id=1593150315#/pro
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 9:44 pm
how to remove plastic splash guard to get to fenderwell TLH020225%20Ampro%20Door%20Upholstery
97rivsc
97rivsc
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 9:48 pm
lol, alright thx AA
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 10:02 pm
Serious, that's what I use. The pop-up fasteners do break from old age. I went to the dealership and asked for a deal on 20 of them - got a very good discount, and replaced almost all of mine.
The replacements you see in the auto parts aisle aren't exactly the same. OEMs fit the best.
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 10:13 pm
I have been meaning to axesk the same question myself.
clap
Bert tavis
97rivsc
97rivsc
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 10:22 pm
AA, where did you buy the ampro tool? I checked autozone, but their tools looked fairly shoddy
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 10:31 pm
You know, I can't remember for sure, but try Advance Auto parts if you have them in your area.
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 10:57 pm
I have that tool also, but I just pried them up slightly with a flat blade screwdriver, then pulled them out with a needle nose pliers.
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 11:02 pm
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySat Mar 28, 2009 11:05 pm
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySun Mar 29, 2009 8:09 pm
I grab the center with pliers and pull them out, then the rivety things just pop right out.
Merit : 122
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySun Mar 29, 2009 11:01 pm
yeah, I've always used needle nose pliers...
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySun Mar 29, 2009 11:25 pm
needle nose here to!!
sqrivi
Merit : 52
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptySun Mar 29, 2009 11:46 pm
Are these the fasteners with the "pin" in the middle, kind of looks like a plastic rivit?
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptyMon Mar 30, 2009 12:07 am
Yes, they look like this:
how to remove plastic splash guard to get to fenderwell GMretainer
If anyone needs new clips, I have a few I will sell for cheap, just let me know.
97rivsc
97rivsc
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptyMon Mar 30, 2009 12:31 am
AA I need one clip how much?
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptyMon Mar 30, 2009 12:37 am
Just one? I'll give it away if the shipping isn't too much. PM me your address and I'll let you know.
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptyMon Mar 30, 2009 9:28 am
FYI they are readily available at NAPA if you wreck a couple.
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptyMon Mar 30, 2009 10:03 am
I've tried to find a match at NAPA and other parts places, and could not. GM uses about 50 different push-lock retainers, all different. If you find out which one NAPA stocks that is the same, please let us know. Thx.
PostSubject: Re: how to remove plastic splash guard to get to fenderwell   how to remove plastic splash guard to get to fenderwell EmptyMon Mar 30, 2009 12:23 pm
I have a bag of them on my workbench. I'll see what number they are when I get a chance.
» Plastic Panels for Removed OEM Sub
» XTR's now have Rim Guard
» Plastic Waste in Rivers
» Plastic? Bolts and wingnut for your coils. Where to get them?
» Can you remove Engine Counter Weights from a Briggs?
