| Snowdog's Riv | |
+54charlieRobinson joshuadalegrimes Andysdorm 97buickriviera ghpcnm Abaddon bigdave J. Chris Davis Rosario 96rivi 97rivsc flyineagle96 Jason Eldo JT Newman Mr.Riviera 97 park ave L67 BMD woggy robotennis61 jenkkijussi ewolfe0050 99Rivman xxsupergman25xx curious riv nothincame2mind arttu80 turtleman EatDirtFartDust AA R1V 1T UP dscott2000 Shintsu Ironclad-454 BoattailBob Jack the R captshiner Sweepspear djlorenzana 95SuperRiv albertj jimmyriv TonySmooth89 ibmoses Karma 1wickedninja deekster_caddy Rickw IBx1 SuperRiv07 T Riley stan Snowdog 58 posters |
Snowdog Addict
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:13 pm | |
| i know that they sell one... this repair hase costed me in tottal now +1600euro...guess i have a litle pause...maybe next year. will thistime keep the stock one. | |
L67 Aficionado
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:15 pm | |
| Did you polish the supercharger rotor coating off?
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:18 pm | |
| You mean the supercharger rotor coating? I think he just cleaned the crap off the rotors and is polishing the external aluminum casing. | |
L67 Aficionado
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:20 pm | |
| - Rickw wrote:
- You mean the supercharger rotor coating?
I think he just cleaned the crap off the rotors and is polishing the external aluminum casing. Yeah, I just wasnt sure because of the big difference in coloring in the before and after shots of the rotors. Hopefully its not the case or they wont seal as well | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:37 pm | |
| i think i polish just the part what holds the rootors...the rest of sc will b black...just the ridges(lines on sc) will be polished.. | |
L67 Aficionado
Snowdog Addict
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:50 pm | |
| yes....but not through the soft coating whats on the rootors. | |
L67 Aficionado
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:51 pm | |
| - Snowdog wrote:
- yes....but not through the soft coating whats on the rootors.
Ok good | |
97 park ave Addict
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 2:59 pm | |
| what can you use to clean the rotors without taking the coating off? | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Fri Nov 06, 2009 3:21 pm | |
| brake cleaning fluid. or Nitro thinner., sprit whipe will work tho. | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 8:41 am | |
| as clean as i cold get and polished it inside. painted mat black whit heat paint. cleaned intake manifault..polished the water outlet hope to get the manifault/sc and so on..back in again today. | |
L67 Aficionado
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 9:16 am | |
| SC looks great, good work! | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 11:01 am | |
T Riley Guru
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 11:46 am | |
IBx1 Expert
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 12:50 pm | |
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 1:36 pm | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 5:21 pm | |
| Need to get rid off the spageti vacum lines and get some real silicon black or red tubes. also dont liek the boost gauges blue line will change it as black tho....and it needs a better fuelrail what wont go ower SC. but maybe next year....IC, bulley, cam, fuel rails maybe?will see. anyways tomorrow will but new full syntetic oil/filter and new cooltant fluid. and start whit exhaust pipe build. got the pipes, 2 muflers 2 tips and steel sokk, atm will use stock cat. and whitout resonator. if the sound will be too anoying will get one. after that have done all i could do...need to wait for sideskirt clips. don't want do take riv out whitout them.(been in garage now ower 1 1/3months) after that its FINISHED for this time. | |
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 7:44 pm | |
| Timo.. you must be the envy of all the euro car drivers in finland | |
BMD Aficionado
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 8:35 pm | |
| Excellent work Timo, and beautiful results! | |
| Subject: Re: Snowdog's Riv Sat Nov 07, 2009 8:53 pm | |
| looks similar to what i just did! nice job painting too. Yours defiantly looks better than mine, but i'm going to steal your silver/black idea when i pull the valve covers this next weekend. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Sun Nov 08, 2009 2:31 am | |
| just be sure you clean them good. so that there will not be any oil/silicon on surfice. paint 1st the stripes silver....then tape them and cut in the rict size so that the stripes are covered. then paint the rest black. | |
JT Newman Amateur
Name : Jari Age : 42 Location : Tampere, Finland Joined : 2009-10-05 Post Count : 38 Merit : 0
| Subject: Re: Snowdog's Riv Sun Nov 08, 2009 9:15 am | |
| Looks nice! Keep that quality up. | |
Snowdog Addict
| Subject: Re: Snowdog's Riv Mon Nov 09, 2009 2:02 pm | |
| Exhaust... today thinked a long time but finaly desided to do the downpipe when i get a highflow cat. atm did after cat whit 2,5'' pipes. been lots of welding cuting and thinking... here some pictures of the work. Stock. it's weard that the stock exhaust starts from downpipe whit 3'' till cat, after cat whit 2,5'' to resonator? and from there whit 2,2'' till Y...and there 2'' till muflers...uhh....did they wanted to save monney thats why they did all the sections diferent size? New idea.. tips will ve hanging just half CM from the bumper, so they will stay pretty close, for protectign the rear bumper will have do but some thin stainless steel plate on the bumper so it will protect it of heat. Resonator deleted. will deside later if i want do but a newone or keep it whitout it. the pipe goes after resonator whit 30+30 and again 30+30degree angle pipes....after that 70cm and comes a Y what whe made of 2 30 degree angles, they will spread again whit 30degree and after that 90 degree angles to mufflers. Well i'm not sure if i have any time tomorrow. will have to buy 2 90degree pipes then it should be done. | |
| Subject: Re: Snowdog's Riv Mon Nov 09, 2009 5:27 pm | |
| thats a nice system timo. love it. | |
IBx1 Expert
| Subject: Re: Snowdog's Riv Mon Nov 09, 2009 5:53 pm | |
| The tips look very Euro! | |
| Subject: Re: Snowdog's Riv | |
| Snowdog's Riv | |
