 new riv owner
5 posters
eagleblanks13
Name : mike 95 riv stock but lookin for more
new riv owner Empty
PostSubject: new riv owner   new riv owner EmptyTue Mar 31, 2009 3:42 pm
i got a 95 riv sc series I its my daily driver that im tryin to get a little more out of it. it has 104,000 so its not to bad. ive done all the new car things (oilchange, plugs,wire ect.) I want to put a intake, exaust, and susp. mostly nothin to insane. but if u guys kno which way to go on this i would like to hear it
curious riv
curious riv
new riv owner Empty
PostSubject: Re: new riv owner   new riv owner EmptyTue Mar 31, 2009 4:10 pm
welcome!!! do a search for modding 101- great info
curious riv
curious riv
new riv owner Empty
PostSubject: Re: new riv owner   new riv owner EmptyTue Mar 31, 2009 4:12 pm
eagleblanks13
new riv owner Empty
PostSubject: Re: new riv owner   new riv owner EmptyWed Apr 01, 2009 2:20 am
im lookin for series 1 stuff i kno wat i want to do i just am lookin for somwhere i can get some series 1 parts
new riv owner Empty
PostSubject: Re: new riv owner   new riv owner EmptyWed Apr 01, 2009 12:24 pm
Welcome! Unfortunately you'll find the S1 mod parts hard to find. Good luck though!
new riv owner Empty
PostSubject: Re: new riv owner   new riv owner EmptyWed Apr 01, 2009 12:29 pm
Welcome!
ZZPerformance.com has a limited selection of series I parts...I think they have pullies for the blower and 1.8:1 roller rockers , but thats about it.
Otherwise , custom exhaust , homemade fender well intake , and if you're up to it you can get a dremel and port the blower and throttle body. Beyond that there aren't too many options without custom work.
Merit : 123
new riv owner Empty
PostSubject: Re: new riv owner   new riv owner EmptyWed Apr 01, 2009 1:39 pm
Here are a few links you may find helpful:
https://rivperformance.editboard.com/series-i-engine-transmission-f13/what-series-2-mods-fit-the-series1-t5203.htm
https://rivperformance.editboard.com/series-i-engine-transmission-f13/series-i-supercharged-faq-t2060.htm
https://rivperformance.editboard.com/series-i-engine-transmission-f13/ideas-for-95-sc-t4832.htm
For parts as is mentioned in some of the above links, many series 2 parts will fit with the major exceptions of cam, headers, injectors, transmission stuff
As mentioned you can get couplers from zzp, and smaller pulley, though you can also get a 2.55" pulley from an older series 1 sc with the older supercharger(93-94).
Before consitering a pulley drop you MUST be familier with this list for the series one:
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=44&t=1660
The list in the above link is a very good guide to normal modding of a series one.
there are only a few things that can be done to the series 1 without getting into some major fabrication and changes, so the ORDER that you mod is very important. The life of your engine depends on it.
If you are looking at going upgraded rockers I'd reccomend the intense ones over the ZZP ones because they also will come with lighter pushrods, wheras the ZZP ones don't.
Intense Rockers:
http://intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IR&Product_Code=3800-YTRR-6659&Category_Code=HCV
ZZP Rockers:
http://www.zzperformance.com/grand_prix/products1.php?id=606&catid=104
new riv owner Empty
new riv owner
» New owner
» New Owner. Took a While
» 95 and 99 Owner
» new owner of a 95 NA
» New owner of a 98. S/c Riv.
