I found this video on youtube showing how you can find out alot of things through the cars climate control. i have not truyed yet but...i wonder if its possible whit our riv's tho??
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8593 Merit : 180
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 12:02 pm
Not on the Riviera, as far as I know. There are comprehensive diagnostics but the codes can only be seen with a scan tool, such as the Tech II.
Older GM cars did, IIRC.
TonySmooth89 Aficionado
Name : Anthony Age : 35 Location : Florida Joined : 2007-11-14Post Count : 2410 Merit : 16
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 8:11 pm
I wonder if we could get our temperature readout to show boost.... Hmmm....
IIRC the 95 rivs have the same climate control as that car , so it probably will work for them.
Name : Matthew Age : 37 Location : Florida Joined : 2007-01-17Post Count : 4394 Merit : 101
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 9:23 pm
i've done this with my dads 93 park ave, and his old 88 caddy. IIRC pressing the heat and off buttons reset the oil light on the caddy. i think i tried it on the riv and all it did was reset the temp.
_________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 9:36 pm
just tried it on our cars and got nothing
i was all excited about the boost idea tony mentioned
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 9:47 pm
Man.....
EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27Post Count : 284 Merit : 2
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 10:59 pm
That dudes steering wheel is identical to the one in my riv... minus the radio/temp buttons.
I have a 95 riv, so I'm going to go check it now....
Subject: Re: Buick Climate control diagnostics. Sat Apr 04, 2009 11:21 pm
My climate control looks nothing like the roadmaster's. And I tried combinations of every two buttons on mine, and found nothing.
Subject: Re: Buick Climate control diagnostics. Sun Apr 05, 2009 7:39 am
Our '86 Riv had the famous CRT touch screen... in that you could hold Heat and Off together and enter diagnostic mode, and scroll through EVERY sensor the PCM saw. An incredible diagnostic tool.
