 engine help
95rivy
95rivy
engine help Empty
PostSubject: engine help   engine help EmptySat Apr 04, 2009 9:47 am
I have a 95 riviera for about a week now and fell in love with it. The problem now is that motor is smoked. Just wondering what you guys though about rebiulding this one or just putting in a used motor. Or maybe switching to a series ll since the motor has to come out anyway. thanks for yuor help.
engine help Empty
PostSubject: Re: engine help   engine help EmptySat Apr 04, 2009 4:48 pm
Easiest will be to find a low mile used motor. They generally last forever, so pretty much anything that comes with a basic warranty should be fine. (there's a junkyard near us that warranties every motor for 90 days, so you can determine that it all works...)
engine help Empty
PostSubject: Re: engine help   engine help EmptySat Apr 04, 2009 6:56 pm
depends on how much you want to spend on fixing it up.
a series 2 motor would be your best approach if you plan on modding down the road. you would need a new pcm too. you may also need a transmission out of the series 2 car as well.
probably looking at $2000 for a used motor/trans/pcm package in decent shape.
or if money is tight you can get a used series 1 for pretty cheap.
engine help Dsc_0110
95rivy
95rivy
engine help Empty
PostSubject: Re: engine help   engine help EmptySat Apr 04, 2009 9:52 pm
will any gm 3800 bolt up to my supercharger or do i need to find a supercharged engine to swap in
engine help Empty
PostSubject: Re: engine help   engine help EmptySat Apr 04, 2009 10:05 pm
the n/a has higher compression and different injectors than the /sc motor. and the some of the trans are HD for the s/c motor.
95rivy
95rivy
engine help Empty
PostSubject: Re: engine help   engine help EmptySat Apr 04, 2009 10:26 pm
ok i see .what if i was to use just the n/a block and put the heads in intake from my s/c motor?
engine help Empty
PostSubject: Re: engine help   engine help EmptySun Apr 05, 2009 7:37 am
Is your current motor supercharged (Series I) or N/A (Series II)? Hard parts from the SII engine won't bolt onto the SI engine.
95rivy
95rivy
engine help Empty
PostSubject: Re: engine help   engine help EmptySun Apr 05, 2009 9:03 am
boy this is turning out to be harder than i thought. im not shure which block i have ,but it is a supercharged motor now but that one is toast. can i tell which block a have in my car by the vin number?
engine help Empty
PostSubject: Re: engine help   engine help EmptySun Apr 05, 2009 11:35 am
I believe all L67 engines share the same cast iron block.
If it is the stock engine in a '95 Riviera, it uses the Series I SC 3.8L engine, which uses the L67 block.
95rivy
95rivy
engine help Empty
PostSubject: Re: engine help   engine help EmptySun Apr 05, 2009 7:20 pm
thanks for all your help guys, i guess ill know for sure when i pull the motor out and see it out in the open. i love this web site, its been so much help. i do so some things about cars but new to the s/c 3800 so your help is greatly needed. thanks guys
engine help Empty
PostSubject: Re: engine help   engine help EmptySun Apr 05, 2009 9:15 pm
Please add some info about your car to your signature under user preferences, and turn on signatures, so we don't have to ask what year/motor your car is in every question.
Thanks!
engine help Empty
engine help
» RCGF 45cc Petrol Engine
» Tecumseh engine
» How man cc is an 11hp engine?
» Poss. sale of 09 RZR "S" engine
» Please help me diagnose Engine trouble on a 18.5 hp v twin.
