 ac compresser is shot
etosino2009
etosino2009
ac compresser is shot Empty
PostSubject: ac compresser is shot   ac compresser is shot EmptySat Apr 04, 2009 4:43 pm
Well i never really use the ac or airconditioning and when i was taking someone home i turned it on since they were cold. Thats when i noticed the acceleration and strange noises starting to happen. Drove it for ahwile then the car starts to smoke looked under the hood and could tell it was coming from there. i guess its shot and fluid is leaking and i took it to a shop and im quoted 1,186.97 $ for the compressor, service, and fluids.Im going to take it to another shop and see what they say. Now im wondering how hard is it to fix it yourself and could i just take the belt off the ac compressor? My parents and i have decided to not go ahead and fix the car things keep on breaking down and need to be replaced and we have spent way to much fixing it but i guess thats what you get with an older car. Im keeping the car but storing it and getting another car as my daily driver. its still drivable and drives fine but there is always a loud screeching noise coming from it even with the ac or aircondtioning off. thanks
Merit : 122
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySat Apr 04, 2009 4:59 pm
Anyone know if you can do an AC delete on the series one?
http://intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IR&Product_Code=IAD-380&Category_Code=PBF
I've often wondered what it would take to use the series 2 kit, but currently my AC still works....
captshiner
captshiner
Merit : -1
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySat Apr 04, 2009 5:55 pm
I've been wondering, what exactly are the advantages of an AC delete kit?
https://www.facebook.com/profile.php?id=572362129
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySat Apr 04, 2009 6:58 pm
saved weight. you can remove a lot of components with the a/c gone.
ac compresser is shot Dsc_0110
captshiner
captshiner
Merit : -1
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySat Apr 04, 2009 7:46 pm
Ok, I wasn't sure if it had to do with anything else. Thanks Mr. Riv.
etosino2009
etosino2009
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySun Apr 05, 2009 3:03 pm
Well i talked to some people and they said if i do an ac delete or take the belt off it that there is another pullie that runs off it and that there is the issue with the length of the belt with it gone too.Is there a way i can just put a pullie in place of the ac compressor that does not do anything so the belt issue does not come up?
Merit : 122
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySun Apr 05, 2009 5:51 pm
That is what this thing is supposed to do:
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySun Apr 05, 2009 9:13 pm
But keep in mind that thing was designed for the SII motor, not sure if it will work on the series I. You'll want to take some measurements on the A/C bracketry and see if it's the same size.
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySun Apr 05, 2009 9:36 pm
according to some part comparisons at rockauto the S2 compressor pulley is 5.12" while the series 1 clutch pulley is 5.5".
the brackets look very similar though.
96 s/c riv
http://info.rockauto.com/FourSeasons/FourSeasonsDetail.html?58994.jpg&58994html.jpg
95 s/c riv
http://info.rockauto.com/FourSeasons/FourSeasonsDetail.html?57959.jpg&57959html.jpg
Merit : 122
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyMon Apr 06, 2009 2:52 pm
smile Like i said in my first post:
so someday when my AC craps out Ill buy the braket and findout what it takes to make it fit, and If i can't I'll just use it on the 98 sometime. Of course Evan might find out first.
steve314159
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyThu Apr 09, 2009 4:58 pm
You could just buy another compressor at a junk yard. I found one for $100 and didn't replace anything else, just refilled with R134 and it's worked fine for two years now. You wouldn't even have to add freon if you didn't care if it worked. You really need it though so at least the defrost works on wet days.
etosino2009
etosino2009
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptySat Apr 11, 2009 6:47 pm
Thanks guys i think i just might fix it myself. Its going to be pretty expensive to have it fixed so i might just go to the junkyard if the ac is the same on na series I. Any of you guys know how hard it is to change out the compressor?
steve314159
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyTue Apr 14, 2009 9:45 am
I thought it was pretty easy. Bolt off/on. Before I replaced it I took it to a repair shop and they drained the R134 for free. You may not have any left in the system but you can check by poking the fill valve to see if any comes out. I'd definitely say try it yourself.
KillaKeninaRiv
KillaKeninaRiv
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyTue Jun 16, 2009 3:23 pm
you can try a junkyard for the compressor. the ones here usually charge like $30 for them or so
etosino2009
etosino2009
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyWed Jun 17, 2009 7:51 pm
Yah im going to try that and take it to a shop and see if they will install it. I really need this fixed as i found out yesterday from the rain but i need it done as cheaply as i can.
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyWed Jun 17, 2009 8:17 pm
A/C fix and Cheap rarely work in the same sentance. The cheapest way out is to have a shop capture the freon, then replace the compressor and o-rings yourself, then have the shop evacuate and recharge it. Many A/C shops will work with you on this, but it would really suck to replace the compressor only to have it die in 6 months or a year, you are better off in the long run getting a new/reman compressor, one from a junkyard is likely to be in the same condition as the one you are replacing!
KillaKeninaRiv
KillaKeninaRiv
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyWed Jun 24, 2009 5:08 pm
true, but just as i learned with a fuel pump, i can buy them used for $20 and pop it in, rather than pay $300 from Autozone. I can buy 10 for that price. If I buy two or three, chances are good at least one is going to work. So for $40-50 I can buy it and have a spare. The place I go has warranties so if its bad I just take it back. I havent had any problems so far.
Merit : 17
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyWed Jul 20, 2011 1:30 pm
Why would not having a/c make it so that you couldn't defrost your window? Mine doesn't work and i can defrost mine. I just use the heat ha
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyWed Jul 20, 2011 3:24 pm
read
Frost is moisture. What does the A/C system do? It removes the moisture from the cabin air. The A/C compressor is commanded on whenever defrost is selected (even when heat is needed). This way, the air hitting the windshield is dry, and can effectively melt the frost. Ever notice on some days when you have the vents or floor selected (heat), sometimes you'll get "fog" just above the defroster vents? Or if you come out on a hot day after the A/C has been running, car sitting, there's "fog" above the defroster vents? This is because the air "leaking" into the defroster vents isn't dried by the A/C system.....
Merit : 17
PostSubject: Re: ac compresser is shot   ac compresser is shot EmptyWed Jul 20, 2011 8:52 pm
Thanks abaddon, I never noticed any of that. I wonder what part of my A/C system went bad, my father and i checked the freon and it's full, but it still only sends out warm air.
» Big Shot Images Senior Game Summaries
» Air compresser -- how this look?
» Dogs shot dead in Bolton
» Alexei Cherepanov in serious condition
» Michael Liambis hit
