 Write-Up: Performance Shift Knob
Go to page : Previous  1, 2
Merit : 127
PostSubject: Re: Write-Up: Performance Shift Knob   Sun Dec 12, 2010 2:44 pm
Got it workin! Once I got Scott's DHP going, I was able to upload the edited code as I showed above and it works. It can be confirmed with a scanner if you look at the perfshift status.
Merit : 179
PostSubject: Re: Write-Up: Performance Shift Knob   Sun Dec 12, 2010 3:15 pm
Awesome man. Great info. Somehow I see a plethora of perf shift buttons being added to Rivieras..... twisted . You got a + from me!
PostSubject: Re: Write-Up: Performance Shift Knob   Sun Dec 12, 2010 3:32 pm
Great info. Have you noticed that shift pressures programmed for 3rd gear lock-out don't seem to take? I tried but didn't see any difference (would be nice to have perf shift activate by shifting into 3rd).
Merit : 127
PostSubject: Re: Write-Up: Performance Shift Knob   Tue Jan 25, 2011 9:27 pm
I forgot to get back to you on this. I'm not sure about that. If there a good way for me to test that?
PostSubject: Re: Write-Up: Performance Shift Knob   Tue Mar 27, 2012 7:13 pm
NOOOOOOOO!
http://www.rivman.com/perfshift.htm
NOTICE: This domain name expired on 03/26/2012 and is pending renewal or deletion.
RivMan
PostSubject: Re: Write-Up: Performance Shift Knob   Thu Dec 20, 2012 10:25 am
Hey guys, ran across this randomly. Here's an archive of the writeup I had on my old site.
Code:
http://web.archive.org/web/20041015215319/www.rivman.com/perfshift.htm
On the 97 PCM's I believe it's Pin 33 on the clear connector, not 21.
-Rob
http://www.RivMan.com
kylan_13
PostSubject: Re: Write-Up: Performance Shift Knob   Mon Aug 07, 2017 1:52 am
Can any one confirm that pin 21 on the clear connector is for performance shift on the 1998 riv? That's what this pdf say it is, www.gmtuners.com/files/Fiero_L67_PCM_wiring.pdf All the other pins are the same as what my service manual says they are. My manual just says "not used" for pin 21. Also when grounding that pin does it need a resistor? if so what ohms and wattage? Thanks
