T Riley Guru
| Subject: Narrowband A/F gauge Mon Apr 20, 2009 8:17 pm | |
| I got one for a steal... like 10 bucks... i hooked up the ground and the power wire... and i have the sending wire left.. where do i hook that up on the O2 sensor?? | |
T Riley Guru
| Subject: Re: Narrowband A/F gauge Mon Apr 20, 2009 8:38 pm | |
| I heard its the purple wire going to the O2..im gonna try this.. | |
| Subject: Re: Narrowband A/F gauge Mon Apr 20, 2009 9:32 pm | |
| Be careful. I believe you can damage the O2 by shorting it or hooking up the wrong voltage. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Narrowband A/F gauge Tue Apr 21, 2009 1:44 am | |
- Be careful. I believe you can damage the O2 by shorting it or hooking up the wrong voltage.
you are correct! | |
| Subject: Re: Narrowband A/F gauge | |
