 Climate control plug... anyone unplugged one before?
PostSubject: Climate control plug... anyone unplugged one before?   Sat Apr 18, 2009 9:02 pm
I can't figure out how to get this sucker off. Bought one off ebay and the seller cut the wires before the pig tail. There's two blue clips that I thought were holding the plug into the back of the unit. I took those out and the plug still doesn't budge. WTFhelp... puzzled
Merit : 131
PostSubject: Re: Climate control plug... anyone unplugged one before?   Sat Apr 18, 2009 9:44 pm
for your '97 RIv?
PostSubject: Re: Climate control plug... anyone unplugged one before?   Sun Apr 19, 2009 1:41 am
Yep. I'm probably being wicked stupid with this but I can't figure out WTF I'm missing.
PostSubject: Re: Climate control plug... anyone unplugged one before?   Sun Apr 19, 2009 11:21 am
If you are talking about pulling the pins out, after you remove the blue clip there is still a "clip" that sticks out from the pin that holds them in. You use something like a paper clip, I'm sure there is a proper tool, and slide it into the cavity beside the pin and release the clip that sticks out from the pin.
HTH
EDIT:
I just realized you meant pulling the connector not the pins, the blue clips don't release it, there would be another "hook" that holds it into the socket.
PostSubject: Re: Climate control plug... anyone unplugged one before?   Sun Apr 19, 2009 8:27 pm
I got it. Was being really ginger with the plug. All I needed was a flathead between the plugs and they came apart really easy.
