 park ave brakes & suspension?
95ParkAveUltra
PostSubject: park ave brakes & suspension?   Mon Mar 30, 2009 5:08 pm
i think i have an h body but wasnt sure. was reading up on f body brake upgrades. was wondering if theres any for my car. calipers rotors anything?
Ash
PostSubject: Re: park ave brakes & suspension?   Fri Apr 03, 2009 6:12 pm
95ParkAveUltra
PostSubject: Re: park ave brakes & suspension?   Mon Apr 06, 2009 4:01 pm
lol i actually read that page when i first got the car but didnt realize it said c body. so back to my original question. is there any brake mods i can do to the C BODY?
Merit : 99
PostSubject: Re: park ave brakes & suspension?   Mon Apr 06, 2009 5:43 pm
body style doesnt really matter when it comes to brake or engine mods. we are a G-body that can do the same brake upgrade as the W-body cars, and the brakes themselves are off of a F-body (duh).
take a look and compare part numbers for your lower spindles to a 98 riv or 98 regal to see if they are the same.
more than likely your caliper brackets are welded to the lower knuckles making any caliper upgrade impossible without replacing the spindles too. (but the struts dont match up either, so those will need to be swapped out too. ...and the top mounts are different.)
so to be able to do a fbody upgrade on your park ave you will need to do major part comparisons to see if you can even swap out your spindles and suspension with that of another car.
arttu80
PostSubject: Re: park ave brakes & suspension?   Sat Apr 11, 2009 5:08 pm
Well, front calipers in PA Ultra are same for all 1994-1997 Camaros (including Z28),so I think you can use brake upgrades inteded for these cars. Ofcourse you couldn't use Camaro rotors, because of wheel lug pattern is 5x4,75" and yours is 5x115mm, but I think there's crossdrilled rotors on eBay for PA...
I do have 1994 PA Ultra myself, and my only concerns are way too soft suspension and speed limiter at about 170Kph (is it 110Mph). This thing accelerates like a beast, brakes pretty well, but is frustrating at corners. Oh, maybe it just my 15" wheels with tall tires.. lol
95ParkAveUltra
PostSubject: Re: park ave brakes & suspension?   Tue Apr 14, 2009 2:40 am
well i went of autozone to compare brakes between the camaro and my PA. when i checked part numbers on rotors, they were the same. so the bolt pattern for a 95 camaro and 95 PA are the same. or am i missing something?
so just for fun i went to wilwoods website to look at brake upgrades. for the 95 camaro. ( http://info.wilwood.com/BrakeKitsProd.aspx?itemno=140-6743 ) they had a big brake upgrade kit. (what kinda space am i limited to with stock rims) pretty damn sweet. would like someone with some knowledge about these kinds of things to take a look and let me know if it would work or point me in a different direction. thanx
arttu80
PostSubject: Re: park ave brakes & suspension?   Tue Apr 14, 2009 3:28 pm
I'm confused about wheel pattern, because as you mentioned the rotor P/N:s are same for PA and Camaro of 1995 model year, but if you check wheelmarket, for example here--->
http://www.discountedwheelwarehouse.com/Chevrolet___Vehicle_Bolt_Pattern_Reference.cfm
and there ----->
http://www.discountedwheelwarehouse.com/Buick___Vehicle_Bolt_Pattern_Reference.cfm
you'll notice, that Camaro have standard GM RWD bolt pattern of 5X120.7 and PA is standard GM FWD pattern of 5X115, so it's misleading?? ?
Merit : 99
PostSubject: Re: park ave brakes & suspension?   Tue Apr 14, 2009 4:04 pm
a rotor's holes are much larger than the lug bolts so that 1 rotor can fit several different cars with different bolt patterns.
gm parts bin FTW (although all companies do this)
that is another reason it is important to put lug nuts on in a star pattern and tighten evenly. otherwise the rotor can become off center and warp.
97 park ave
Merit : 21
PostSubject: park ave suspension   Fri Apr 24, 2009 8:18 pm
hi guys im new to the board and i have a park ave. from my understanding the park avenue is a C body and the riviera is a G body, now my question is:
are the suspension components on both cars similar in any way?
will the eibach pro kit for a sts work on my park ave like it does for the rivs?
any help is appreciated cause id love to stiffen the suspension
Buickman104
PostSubject: Re: park ave brakes & suspension?   Fri Apr 24, 2009 9:23 pm
The C body and G bodies are completely different.
Their suspensions are also completely different. In the sense of Mods a C body is a stretched out H body. So their suspension components are transferable, but nothing is compatible between the G and C bodies.
97 park ave
Merit : 21
PostSubject: Re: park ave brakes & suspension?   Sat Apr 25, 2009 8:00 pm
so the cadillac sts eibach pro kit wont work with my park ave?
» Brake light always on except when on park position
» Complete GM F41 suspension upgrade
» 73-77 A vs 77-96 B suspension swaps
» Write-Up: 1996 to 1998 Front Suspension Swap w/F-Body Brakes
» Kingsbury Water Park
