 Write-up: stereo system install
sqrivi
Merit : 52
Write-up: stereo system install - Page 3 Empty
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 08, 2011 10:18 pm
Okay........... finally looking to spend some time on the dash again.
Working on the gauge cluster now. Again with the foam.
Write-up: stereo system install - Page 3 ConfirmPO75102007
Write-up: stereo system install - Page 3 ConfirmPO75102005
Write-up: stereo system install - Page 3 ConfirmPO75102006
Now for some rough shaping.
Write-up: stereo system install - Page 3 ConfirmPO75102009
Write-up: stereo system install - Page 3 ConfirmPO75102015
I am thinking the cluster might be too tall, but I'm not going to shave any more until I get it in the car tomorrow to take a look.
Write-up: stereo system install - Page 3 ConfirmPO75102014
Write-up: stereo system install - Page 3 ConfirmPO75102013
More to come.
Merit : 64
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 08, 2011 11:04 pm
never noticed this thread before. Very nice.
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 08, 2011 11:07 pm
can't wait 'til tomorrow to see how it'll look in the car
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySat Apr 09, 2011 11:30 am
Here are some shots with the dash in the car.
Write-up: stereo system install - Page 3 IMG_0567
Write-up: stereo system install - Page 3 IMG_0569
Definitely to tall, time for more trimming.
Write-up: stereo system install - Page 3 IMG_0573
Write-up: stereo system install - Page 3 IMG_0574-1
Write-up: stereo system install - Page 3 IMG_0575
Now back in the car to see how it looks.
Write-up: stereo system install - Page 3 IMG_0576
Write-up: stereo system install - Page 3 IMG_0578
Write-up: stereo system install - Page 3 IMG_0580
I like this much better.
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySun Apr 10, 2011 6:53 pm
Now for a couple of layers of fiberglass.
Write-up: stereo system install - Page 3 IMG_0583
Write-up: stereo system install - Page 3 IMG_0582
Write-up: stereo system install - Page 3 IMG_0581
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySun Apr 10, 2011 7:04 pm
Awesome as usual!
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySun Apr 10, 2011 7:09 pm
yeah ,awesome
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyTue Apr 12, 2011 10:28 pm
I removed the form from the dash to remove the tape and foam. Then replaced the form on the dash and applied a couple more layers of fiberglass. Now the gauge pod is permanently attached to the dash.
Write-up: stereo system install - Page 3 IMG_0587
Write-up: stereo system install - Page 3 IMG_0584
Write-up: stereo system install - Page 3 IMG_0585
It was at this point I realized I had plenty of fiberglass mat but no more resin.... oops
I am determined to make some progress on the car this week so I am starting on the amplifier rack. I have a tendency to try to "hide" the audio components as much as possible in my installs. I know it doesn't look like that will be possible at this point in the build. When everything is finished the only gear that will be visible, without removing panels or pushing buttons, will be the radio in the dash.
Here are the amplifiers. There is two amplifier chassis placed back to back to try to save some space, after all these things are NOT small. This is a lot of amp to try to hide.
Write-up: stereo system install - Page 3 IMG_0589
Write-up: stereo system install - Page 3 IMG_0588
Write-up: stereo system install - Page 3 IMG_0592
The idea is to make a motorized drawer under the rear deck in the trunk.
First I will be removing the end plates from the amps and making new ones that will span both amps attaching them together (this is tomorrows project).
Write-up: stereo system install - Page 3 IMG_0600
Here is the idea.....I will be attaching drawer rails to the amp rack to allow it to slide from under the rear deck to reveal the amps.
Write-up: stereo system install - Page 3 IMG_0598
Write-up: stereo system install - Page 3 IMG_0597
This is going to be a tight fit, but if it was easy everyone would do it right. At least that is what I keep telling myself.
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyWed Apr 13, 2011 12:08 am
Great idea! Im diggin all your Jet equipment!
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyWed Apr 13, 2011 12:47 am
man your car's going to become one sick showroom vehicle.
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyWed Apr 13, 2011 9:20 pm
Here is today's progress. I got a late start so I didn't get as much done as I would have liked.
Here is the new end cap. 16ga steel, should be plenty strong.
Write-up: stereo system install - Page 3 IMG_0601
Now both amps are attached together to make one huge amplifier.
Write-up: stereo system install - Page 3 IMG_0604
Write-up: stereo system install - Page 3 IMG_0607
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyWed Apr 13, 2011 9:28 pm
Amp Armour.I like that
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 15, 2011 2:00 pm
Got some 1/2" square tube steel for the framework of the drawer.
Here is the base for the amplifiers. I stink at welding, but I can grind, fill, and paint..... wink
Write-up: stereo system install - Page 3 IMG_0609
Write-up: stereo system install - Page 3 IMG_0610
Checking fit and marking mounting locations.
Write-up: stereo system install - Page 3 IMG_0612
Write-up: stereo system install - Page 3 IMG_0613
Amp mounted to the base.
Write-up: stereo system install - Page 3 IMG_0615
Write-up: stereo system install - Page 3 IMG_0616
Rails mounted to the amp.
Write-up: stereo system install - Page 3 IMG_0620
Plenty of travel.
Write-up: stereo system install - Page 3 IMG_0621
Now to move into the trunk to make the mounts and locate the rails.
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 15, 2011 2:40 pm
What are you going to use to keep that metal rack tight? The steel drawers may experience some rattling in a hard hitting system, Yes/No?
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 15, 2011 4:27 pm
The ball bearing rails are very smooth and tight, plus the weight of the amp will keep everything from rattling. Also keep in mind the subs are in the dash. There will be a second pair of rails on the bottom of the drawer as well. I have found that putting rails on two different planes keeps the drawer tracking straight. This will allow me to place the motor wherever I can fit it and the drawer won't bind up.
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 15, 2011 5:45 pm
Wow, very well thought out m8! Can't wait to see the finished product looks stellar thus far. clap
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 15, 2011 11:59 pm
ohh yes,yes....lookin' great bro.
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 22, 2011 6:35 pm
Got the amp rack mocked up today. Still have a lot of work on the mount in the trunk, but this is the idea.
Here is the amp drawer in the "closed" position. Looks fairly stock. happy
Write-up: stereo system install - Page 3 IMG_0626
Write-up: stereo system install - Page 3 IMG_0624
Write-up: stereo system install - Page 3 IMG_0625
Here is a lower angle.
Write-up: stereo system install - Page 3 IMG_0627
Here the wire cover is clamped in place to check clearance. I don't want the amp scraping on the trunk as the drawer opens.
Write-up: stereo system install - Page 3 IMG_0629
Here is the drawer in the "open" position.
Write-up: stereo system install - Page 3 IMG_0630
The wood is to just there to support the weight until I finish with the brackets in the trunk.
Write-up: stereo system install - Page 3 IMG_0633
Write-up: stereo system install - Page 3 IMG_0635
Write-up: stereo system install - Page 3 IMG_0634
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 22, 2011 6:50 pm
Looks sweet don't blow your ears . boohoo
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 22, 2011 8:26 pm
sicker and sicker every day.....
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptyFri Apr 22, 2011 11:07 pm
Looks wild!! how will you keep the amp from sliding rearward on acceleration? will you have a lock or velcro??
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySat Apr 23, 2011 12:03 am
The amp rack will have a linear actuator attached that will move the drawer in and out. The actuator will hold the drawer in whatever position it is in.
I used the same type of motor in a previous install. In the video you can see the motor mounted to the side of the piece of wood that is going up and down at the left side of the picture.
This guy races his Porsche from time to time so the mechanism had to be sturdy and not move around when on the track.
I wouldn't feel right not showing the car with the trim panels in place so here are a couple of finished pics. (sorry to go off topic, just trying to explain the motor)
Write-up: stereo system install - Page 3 18
Write-up: stereo system install - Page 3 19
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySat Apr 23, 2011 12:24 am
pretty slick!!
sqrivi
Merit : 52
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySat Apr 23, 2011 7:48 pm
No more wood supporting the amplifier, the mounting fabrication is finished.
Its not easy to hide 2000 watts worth of amplifier, but I am happy with the results. The rack is very sturdy. When the trim panels for the trunk are done you won't be able to see anything at all. wink
Write-up: stereo system install - Page 3 IMG_0640
Write-up: stereo system install - Page 3 IMG_0641
Write-up: stereo system install - Page 3 IMG_0638
Write-up: stereo system install - Page 3 IMG_0642
Write-up: stereo system install - Page 3 IMG_0639
Write-up: stereo system install - Page 3 IMG_0643
Now I just have to get the actuator and limit switches and the rack will be motorized.
PostSubject: Re: Write-up: stereo system install   Write-up: stereo system install - Page 3 EmptySat Apr 23, 2011 10:21 pm
cool!
Page 3 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Rhino stereo
» Rhino Radio?
» Cheap SXS stereo set-ups. Lets see em
» JVC KW-XG700 car stereo
» Cheapskate''s stereo install
