 Scottys Riv Problem Thread update 8/13
Scottys Riv Problem Thread update 8/13 - Page 3 Empty
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jun 04, 2009 3:10 pm
like i said, fill it up, watch the gauge, and then when it looks to be lower then normal after only a few miles fill it up again and see if it is actually using that much fuel.
you still smell no fuel around the car? is the exhaust smoking? have the guy at aamco at least read the code, but i dont know that i'd pay them to do anything other than double check the work the've already done. (just my 2cents)
Scottys Riv Problem Thread update 8/13 - Page 3 Dsc_0110
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 5:36 pm
we definetly got way off topic. well put it in here...
the good thing about when i take it home..i dont have to know..i say dad..hes the keys. theres an exhaust leak...tell dom to fix it lol. he calls me and says...this is what needs done...heres the cost..wanna do it? i go yupp. thats one of the benefits of me moving back home. cheap labor and parts cuz he can get them wholesale.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 5:48 pm
Wellll, that's a whole different thing then.
That's good that you have that support at home. Nothing like someone else figuring out the problem for you.
I've been working on someone's motorcycle for the past few days and it's kicking my ass. I'm supposed to be the expert on these things and this one is giving so much trouble I'll never make any money on this job.
Thought it was a simple electrical problem to start with and it's turned into a nightmare. I'll figure it out though, not giving up.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 5:56 pm
im guessin ur a motorcycle mechanic? u got more patience with that stuff than i do. if i cant figure sumthing out like that within like an hour..i can completely annoyed and either give up..or go find someone to help me out more. maybe u should ask sum1?
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 6:07 pm
I've already consulted with some people I know in the business. This is one of those problems that comes along once in a great while that defies logic.
I just have to stick with it and go over everything I've already done and triple check wiring until I find the Gremlin causing the problem.
I don't do this for a living anymore but I have a fully equipped shop at home and a few of my own motorcycles. I just take in occasional work. Sometimes the problem jobs that nobody else could fix. This is one of those bikes. It belongs to my carpenters wife and she has had it to a few shops that couldn't fix it and she begged me to take it in and I said YES.
What a mistake. But like I said I'll eventually find the problem, it just takes patience and a clear head. I have to take breaks frequently and just think this one through.
Merit : 153
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 6:18 pm
broken ballast resistor
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 6:26 pm
oo sounds like a rough job. goood luck Rick.
jw..how old are u? and what do u do for a living?
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 6:46 pm
albertj wrote:
broken ballast resistor Albertj
If only it was that simple.!!!!!
Merit : 153
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptySun Jun 28, 2009 10:56 pm
One of the worst gremlins I dealt with was when a Fram gas filter fragged and stuck the needle valve open on an '83 Mercury Lynx (Ford Escort).
The symptom was the car would run OK for a while then act flooded---on opening the gas tank filler cap to check for vapor lock, the fuel poured out of the opening onto the street in a stream - kind of like the car version of the Brussels Boy.
after troubleshooting for a while (days)between jobs and asking for "advice" from mechanics and Ford's district manager, I got frustrated and tore the carb apart myself. Found the problem and reported it. About month and a half later Ford issues a recall.
Bottom line for me RIck is you've offered some of the best advice on this board. Isn't there any way we can help you with this one?
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyMon Jun 29, 2009 6:29 am
Thank you for the offer Albert but I'm too deep into this to bring anyone else up to speed quickly, As I've said I WILL find this problem or I should say problem(s). Hopefully I'll finish it up today and everyone will live happily ever after.
Thanks again for the offer,
Rick
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyMon Jun 29, 2009 10:23 am
Scottys Riv Problem Thread update 8/13 - Page 3 4425_112067527323_580057323_3242119_7624511_n
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyMon Jun 29, 2009 10:28 am
Do you mean FAIL or PHucked.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyMon Jun 29, 2009 11:36 am
dont listen to travis...hes a moron lol
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 02, 2009 8:19 pm
so...i drive pretty much no where....5 miles at most for food..then back home...seriously...so i had my cam sensor "fixed" (using the term loosely) id say maybe 2-3 weeks ago. i drove it 2.2 miles to the store...JUST as i am about to pull into the parkin lot. corner of my eye...bright and yellow...checkk engine light. my blood pressure jumps around 30 points.. so i go in and get my stuff. 10-15 mins go by and go drive home...no light....
2morro will be my true test...im driving about 50-60 miles.
Who wants to bet its the Cam Sensor error?
since its been a few weeks...do i still have the right to have the guy who fixed it to not only rescan it...but to fix it, at his cost. NOT mine
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 02, 2009 8:33 pm
Yes, of course. If you went to shop and have a copy of the Repair Order it may have a statement regarding warranty.
Most shops have either 90 day, 6mo or 12 mo. parts and labor.
It all depends on where you went.
If it is indeed the sensor again you can expect it to be fixed for nothing.
But don't get in anybody's face about it until they scan it and tell you what they plan to do.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 02, 2009 8:44 pm
i have the bill in front of me..it doesnt say anything about a warranty..
it was called
Adelphia Auto Service
not sure if its a small business or a national name...
i dont plan on gettin into anyones face...im not that type of person...if it gets to that point...i call my father..him being a service guy and all..and have him talk to them. i avoid confrontation. lol
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyFri Jul 03, 2009 2:29 am
O rly?
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyWed Jul 08, 2009 6:58 pm
ok...so how unlucky/weird as hell is this...
so as mentioned a couple posts up the SES light popped on..was off on the way home...well i did my drive to the marlins game..about 80 miles total..NOT ONE SES LIGHT the ENTIRE time. i figured maybe the previous day was a fluke...
it wasnt.
today i went to drive my little 2.2 miles to the store..and back..
light was on the ENTIRE way to and from. i shut if off...restarted it..still there..i can notice a difference in its driving too.
im going oto call the guy 2morro..but cmon now...how weird is this..80 miles nothing...5 miles..lights solid from start to finish
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyWed Jul 08, 2009 7:00 pm
let us know what the code is when you get it checked out.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyWed Jul 08, 2009 7:07 pm
im gonna bet Cam sensor.
thats what happens when someone doesnt pay full attention when they do work. they were always going back and forth with different jobs. it was quite annoying to watch them do this.
but ill post when i get out there. grrrrrr
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 09, 2009 6:42 pm
called the guy who fixed my car today....just my luck....hes goin out of town 2moro-monday. i double checked to see if hes charging me to have him look at it. said nope..hed scan it and diagnose it for free, and well go from there. i am pretty sure the cam sensor itself was not the problem.
man i cant win! lol
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyTue Jul 14, 2009 10:17 am
so yes..it was the same problem...hes goin to take it 2morro to look at it more. yippe me.
lets make this more interesting shall we. my tire is going flat...not interesting enough?
lets add a speeding ticket cuz i went 10 mph over.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 16, 2009 5:37 pm
How much is the wire harness for w.e. has to do with the cam sensor?
i will be needing one.
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 16, 2009 6:04 pm
i just got an email from rockauto saying most of their wires connectors are on closeout. i'd check their site to see if they can get you one for cheap!
PostSubject: Re: Scottys Riv Problem Thread update 8/13   Scottys Riv Problem Thread update 8/13 - Page 3 EmptyThu Jul 16, 2009 6:10 pm
i dont know what im lookin for though..i dunno what it looks like...or anything. just by what the guy said is what i know.
btw matt..im gonna have to pass on the calipers. not the best time for me lol.
» Custom Chassis Build Thread
» The Costume Thread....
» A55 Update
» EA NHL 2011 Discussion thread
» Eye Candy thread removed!
