 Watch -n-listen
gosloriv
PostSubject: Watch -n-listen   Thu Mar 29, 2007 8:35 pm
Today after work I put the Rivi up on the lift to check an exaust leak, found the cat was coming apart at the seem so i welded that, then i took a torch and blew two holes into the mufflers one on each side of the tail pipe,and now the air clreaner sounds like this !!!! ITS ONE OF THE COOLEST SOUNDS I HAVE EVER HEARD BESIDES THE WASTE GATE ON A hp TURBO!!!! LIsten to the air being sucked thru the air filter !! Remember the otherday I ported and polished the LIM!!
Merit : 124
PostSubject: Re: Watch -n-listen   Thu Mar 29, 2007 10:24 pm
sweet man. It sounds like my 3100 gran dam did after exhaust and intake except with a lot more air. nice!
SoCal Riv
PostSubject: Re: Watch -n-listen   Fri Mar 30, 2007 2:21 am
Please tell me you weren't smoking, eating, on your cell phone—all the while holding a camcorder too?!
popcorn
Merit : 239
PostSubject: Re: Watch -n-listen   Fri Mar 30, 2007 8:21 am
When my cat split at the seam, the dealership mechanic explained that it was probably clogged, as they are designed to split like that when they go bad. Ordered headers 2 days later.
Sounds good, btw. Needle was really movin, too!
'98 SC Riviera • 280k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30
^^^ RIV IS FOR SALE! ^^^
'05 GTO • 49k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26
'95 Celica • 150k miles • 0-60: yes
gosloriv
PostSubject: Re: Watch -n-listen   Fri Mar 30, 2007 9:50 pm
Beatin on it on the way home tonite, think i blew the motor.......makein bad noise....clue ya'll in on it tomorrow.....
PostSubject: Re: Watch -n-listen   Fri Mar 30, 2007 11:17 pm
do u think it has anything to do with the Port and polish job??
gosloriv
PostSubject: Re: Watch -n-listen   Sat Mar 31, 2007 3:15 pm
Well the bearings are wasted !!!!!Think they may have got washed !!
Hmmmmm......Now what slap sum bearings in or Supercharged engine ?
Watch -n-listen
