 Write-Up: FWI - 4" Spectre intake for N* & LQ4maf
Goto page : 1, 2  Next
Merit: 89
PostSubject: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed May 20, 2009 12:03 am
This is a mildly involved and not very economical solution to making a good true 4" intake system to be used on rivieras modded with a northstar throttle body and LQ4/LS6 maf sensor.
One great thing about this setup is that it is ever-modular and could be changed with the addition of other modifications such as an intercooler. You could also use it on another car if so desired. Another plus is that it's built out of parts actually meant for automotive intakes so you can imagine the benfits there.
Downside is the way I'm doing it myself and the writeup anyway, it requires changing the coolant overflow bottle and opening up the fenderwell hole (which would be required with any 4" FWI).
To start off, here's what my fendewell passage looks like opened up for easy fit of 4" pipe.
from the bottem
with extended spectre 4" filter installed (I used a standard size filter because this one was too tight of a fit to let me angle the pipe the way I needed to)
I cut the 3 outter sides of the passage out about a pinky each with a dremel. It took me about 2 1.5" cutting discs to do it and then i filed the edges by hand just to smooth it a little bit. I used U-style black door edge trim to line the edges with mainly to keep from scratching the new piping going through it and make it look a little nicer.
to be continued soon...
Merit: 61
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed May 20, 2009 12:39 am
Glad to see a write-up on this. How about a parts list?
Merit: 89
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed May 20, 2009 10:11 pm
That pic right there shows you what the special sleeve does for you on the maf sensor. It's thicker so it takes up the space in the coupler and effectively cancels the annoying notch thats on the housing.
98riviera98
Merit: 7
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed May 20, 2009 10:27 pm
looks cute..
Merit: 89
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed May 20, 2009 10:28 pm
Part numbers in order of installed location (all part numbers are Spectre parts)
*northstar TB
*9771 coupler (with included sleeve on the TB side)
*9709 4" long pipe
*9771 coupler (with included sleeve on maf side if you skip the special sleeve, part number 990003 for the special sleeve if you use it)
*LQ4/LS6/etc maf sensor assembly
*9771 coupler (no sleeve required)
*9749 45 degree pipe
*9771 coupler (no sleeve)
*9709 4" long pipe
*9781 90 degree silicone elbow
*9719 6" long pipe
*8138 air filter (that I used)
Again, the special GM-specific maf sensor sleeve (990003) that Spectre makes is optional. It really doesn't make the install any easier or better, funtionally. It just looks a little tiny bit better if you're picky.
The filter you use is really up to you. If you already have a 4" fit K&N or something else that looks about the same size, there's no reason not to use it.
You must move or remove the OEM coolant overflow bottle in order to use this exact intake setup. I've tried different things puzzeling around with pieces and it seems like it would be near impossible to do this without modifying individual pieces. Once you get a feel for how much it costs for all these parts, you probably won't want to be cuting them... quiet Installing an aftermarket overflow bottle is not much of a hassel. It's just one hose and then figuring out a mounting solution. Some creativity with a few long zipties did the job very well for me. Make sure that the tank is vented since the factory tank is vented. It will not work properly if it is sealed.
Merit: 13
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Thu May 21, 2009 12:30 pm
i noticed the filter things stickin out of 2 of ur looks like oil and collant areas...do those make a difference?
Merit: 83
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Thu May 21, 2009 3:33 pm
Nice parts detail, thanks for that and the pics. Good job!
Merit: 89
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Thu May 21, 2009 10:52 pm
The oil breather is necessary to use a northstar throttle body with ZZP's adaptor as is because the adaptor blocks off the PCV inlet. You can also drill that piece of the adaptor and use it like the original setup but the experienced 3800 tuners say that it's better to run a breather with moderate to heavy mods anyway because the factory PCV system may have trouble "keeping up".
The smallest breather on my coolant tank is just my method of venting it. The factory tank has a vented cap. Under normal circumstances, air should be the only thing moving in and out of the vent, if that. If you want to, you could also run a hose from the top vent port of the new tank and route it to the ground somewhere so if for any reason, it overfills (possibly from overheating, overfilling, not burped, etc), the coolant can come out without making a mess under the hood.
crlombardi69
Merit: 5
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Sat Jan 30, 2010 9:22 pm
Very clean install. Totally custom and one of the best options w/out cutting and welding your own stainless steel tubing!Most of us aren't tig welding SS in our garages and polishing it to show quality like these pieces.Good write-up I would like to have that set-up for sure.
http://crlombardi69@yahoo.com
Merit: 96
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Sat Jan 30, 2010 9:40 pm
Turtleman,
Maybe you should put a price together for all pieces and shipping for the people that want that set-up.
You can get all that together and make a kit for everybody interested. You work where you can all the pieces don't you.?
98riviera98
Merit: 7
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Sun Jan 31, 2010 5:55 am
Turtleman,
Although that would be convenient.. This set-up with the same parts HE has wouldn't work for you.. it would want to go into your coolant tank like 4 inches.. Goood idea though
Apprentice
Merit: 0
PostSubject: Fellow 96 Owners, Need Some Help with a FWI   Wed Feb 08, 2012 3:30 pm
I've looked at a lot of FWI designs, and my favorite would have to be that of J. Chris Davis. He chose to build an aluminum FWI system using parts from Spectre performance, and I really love the way it shines under the hood. However, I'm concerned about the clearance issues some 96 owners have stated about their coolant tank. Apparently its a different design or in a slightly different location than the 97-99s? Anyways, I want to know if this system is going to work. Or will I have to modify his setup? Thanks.
Link to Chris's Spectre FWI is http://rivperformance.editboard.com/t7418p30-my-98-buick-riviera
Merit: 172
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed Feb 08, 2012 3:50 pm
J.Chris Davis's Spectre FWI build:
Only took a couple of hours since after all the pics and reading on here it went rather easily. First the parts I used were spectre 3.5" aluminum. So it went like this: 4" to 3.5" reducer, 45 degree, 3.5" coupler, 22 degree, 3.5" coupler, 90 degree, 3.5" to 3" reducer, 3" diameter 6" straight into the filter. Part numbers I used were 9741, 9541, 9549, 9529, 9599, 9419, (2) 9571 and the E-0774 K&N Filter.
- John R. White, Boston Globe
Apprentice
Merit: 0
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed Feb 08, 2012 3:59 pm
AA, do you know anything about the difference in the coolant tank locations?
Merit: 172
PostSubject: Re: Write-Up: FWI - 4" Spectre intake for N* & LQ4maf   Wed Feb 08, 2012 4:07 pm
I don't know for sure. I thought they were the same or close. Can you take a picture of yours?
Page 1 of 2Goto page : 1, 2  Next
» Seiko 7S26 Movement on an "Orange Monster" (SKX781)
» Seiko 6138-7000 "Slide Rule"
» Request for "SAY" + "YOU"
» Nugget finder 24" Elipt Mono
» Write-Up: FWI - 4" Spectre intake for N* & LQ4maf
