 wiring diagram
wootzgarage
wiring diagram Empty
PostSubject: wiring diagram   wiring diagram EmptySat May 23, 2009 10:24 pm
Hello all you would not believe what i found out today i aquired a factory indash player out of a 2005 avalanche and guess what all i had to do was drill one hole and make another one a little larger to make it fit now all i need is the wiring for both radios so i can plug it in and have a listen. Is there anyone out there that has the wiring for the plug side of the factory 1996 riviera and the wiring for the 2005 avalanche if you dont have the wiring do you have any suggestions where to get it i have some pics of the install but i cant seem to find how to post them once i do i will be sure and post for all to see it looks real cool and i dont think the factory could have done a much better job
Thanks in advance for your help
PostSubject: Re: wiring diagram   wiring diagram EmptySat May 23, 2009 10:44 pm
wootzgarage
PostSubject: Re: wiring diagram   wiring diagram EmptySun May 24, 2009 12:36 am
Aaron you are the bomb this will be perfect now i need to see if the avalanche group has as great a group of guys as the riviera guys and i can get the pinout for the head unit i cant wait to get this thing working i should have xm dvd gps the works. wish me luck... thanks again aaron
wiring diagram
» 4 pin solenoid wiring diagram?
» wiring diagram/pic
» Briggs Engine Wiring Diagram
» wiring diagram for a 18hp vtwin b&s I/c
» Minelab DD and MONO coil plug pin wiring diagram
